![]() "Tman" x@x wrote in message . .. Flying a lot of 152s and 172s with carb heat lately. When inbound, I've been taught to pull the carb heat "on" downwind, hey actually use it as a power control to slow the plane just a bit mid-field, and then more importantly, just leave the thing on till clear of the runway and cleaning up. No matter what the temp, humidity. And to have it on at all times when the RPM is less than the green band. Kind of a preventative. A few times I have been coming in on short final and needed a burst of power due to a sudden downdraft, or needed to pour on a little juice cause my approach was coming up just a bit short. Moving the throttle forward 1/4 to 1/2 inch, i.e. giving it a little juice but certainly not a go around type of thing, often times I would get a stumble, hicuup, drop in RPM'S for 2-3 seconds before the horses responded. Lot of convective turb lately and that power really comes in handy at times on mid to short final. Kind of a shocker when the engine doesn't respond quite nicely. This has happened on a few birds, especially on hot days. I think what's happening is the engine is just too rich, hey I've got the mixture all the way in, it's hot (air less dense), and it's (way) hotter with the carb heat on ( air much less dense), all enriching the mixture, and when I put on a little power the accelerator pump in the carb over-enriches the engine for just a little bit; causing the stumble. Other pilots and the A&P just tell me to pour on the power a little slower. I think I'm going to follow a new SOP. Turn the carb heat off on mid-final. Reasoning: no carb, esp a warm one is going to ice up in 30 seconds, sets me up better for a go-around, and will prevent this stumble business (I did test it out at altitude, and it prevents or at least seriously mitigates the stumble). thoughts? T Shouldn't be a problem, but sometimes it happens. Apply power a little slower. or Carry just a tiny bit of power on final. Sounds like you might be approaching at cut off. or Bump a little power every 15 to 20 seconds to keep the engine clear. Personally I wouldn't cut the carb heat. |
"Lonnie" @_#~#@.^net wrote in message
... "Tman" x@x wrote in message . .. Flying a lot of 152s and 172s with carb heat lately. When inbound, I've been taught to pull the carb heat "on" downwind, hey actually use it as a power control to slow the plane just a bit mid-field, and then more importantly, just leave the thing on till clear of the runway and cleaning up. No matter what the temp, humidity. And to have it on at all times when the RPM is less than the green band. Kind of a preventative. A few times I have been coming in on short final and needed a burst of power due to a sudden downdraft, or needed to pour on a little juice cause my approach was coming up just a bit short. Moving the throttle forward 1/4 to 1/2 inch, i.e. giving it a little juice but certainly not a go around type of thing, often times I would get a stumble, hicuup, drop in RPM'S for 2-3 seconds before the horses responded. Lot of convective turb lately and that power really comes in handy at times on mid to short final. Kind of a shocker when the engine doesn't respond quite nicely. This has happened on a few birds, especially on hot days. I think what's happening is the engine is just too rich, hey I've got the mixture all the way in, it's hot (air less dense), and it's (way) hotter with the carb heat on ( air much less dense), all enriching the mixture, and when I put on a little power the accelerator pump in the carb over-enriches the engine for just a little bit; causing the stumble. Other pilots and the A&P just tell me to pour on the power a little slower. I think I'm going to follow a new SOP. Turn the carb heat off on mid-final. Reasoning: no carb, esp a warm one is going to ice up in 30 seconds, sets me up better for a go-around, and will prevent this stumble business (I did test it out at altitude, and it prevents or at least seriously mitigates the stumble). thoughts? T Shouldn't be a problem, but sometimes it happens. Apply power a little slower. or Carry just a tiny bit of power on final. Sounds like you might be approaching at cut off. or Bump a little power every 15 to 20 seconds to keep the engine clear. Neither of which would do anything to prevent potential problems. Personally I wouldn't cut the carb heat. Because flight sim doesn't care either way. |
Carb Heat | [email protected] | Rotorcraft | 11 | April 30th 07 06:34 PM |
Carb Heat | vlado | Piloting | 9 | January 22nd 07 03:08 PM |
Use of Carb Heat | John Kirksey | Piloting | 4 | November 30th 04 07:26 PM |
Carb heat specs? | Rich S. | Home Built | 2 | November 13th 04 04:39 PM |
Cherokee Carb Heat. | Greg Esres | Piloting | 15 | July 29th 03 02:25 PM |
