Mode S transponder display to ATC?
Old September 9th 08, 05:50 PM posted to rec.aviation.ifr
Mike[_22_]
Default Mode S transponder display to ATC?
"Jay Maynard" wrote in message
On 2008-09-09, Jon wrote:
1090 if you're one of the bigger operators, or perhaps smaller folks
with deep pockets. UAT is lower cost.
A GTX330 doesn't exactly imply "deep pockets". Wasn't a UAT estimated to
cost several thousand bucks?
It's going to run you considerably north of $10K for a full certified
installation and somewhat less if you already have a MFD.
Hardly. My airplane already has a GTX330 and a GNS430W. Garmin says that
they'll implement ADS-B on those two boxes; the GTX330 will require a
$1200
upgrade, but the PowerPoint I saw was unclear on what the GNS430W would
need.
I was referring to UAT. The GDL 90 costs around $7K, a MFD costs around
$3-4K, and installation adds to the cost.
I doubt that a UAT will be that inexpensive; there's also the minor
problem
of needing panel space for it, something that's in short supply in my
airplane.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
Old September 29th 08, 04:56 AM posted to rec.aviation.ifr
Scott Moore
they'll implement ADS-B on those two boxes; the GTX330 will require a $1200
need.
I doubt that a UAT will be that inexpensive; there's also the minor problem
airplane.
Dudes, the implementation of ADS-B with an existing GTX 330 system makes
sense for two simple reasons:
1. UATS are currently vaporware, or very costly ($10,000 or more).
2. Even after this "golden child" UAT shows up, you are going to want to
use 1090 to talk directly to airlines, which will be implementing that
only. Unless you believe that the FAA is going to faithfully translate
that information for you, after bouncing that down to a ground station and
back up, perhaps with a mountain in the way or two.
If you search back in this group you will see that I brought this issue up
years ago. The "dual system" will have to go down as one of the most
spectacularly bad ideas the FAA has ever perpetrated, and it WILL result
in the FAA performing a power shrug while trying to explain to the press
why two ADS-B equipped aircraft, a light airplane and a regional heavy,
collide with loss of life.
As for me, Garmin has once again (apparently) saved me from the FAA. I'll
get ADS-B capability long before GA gets it, via the GTX 330, and after
UAT becomes reasonable, the GTX 330 link will make sure that the heavys
know I am flying around, whether the FAA gear is working or not.
Scott Moore
Old September 9th 08, 02:45 PM posted to rec.aviation.ifr
Mike[_22_]
"Jon" wrote in message
On Sep 8, 9:54 pm, "Mike" wrote:
"Peter" wrote in message
"Mike" wrote
Some of the ModeS features will never be implemented and the ModeS
Extended
Squitter will mainly be used by the airlines. For GA, I don't think
you're
going to see much in the way of new ModeS features as the ADS-B UATs
will
be
the preferred new technology path for data link.
Indeed. You won't get Mode S on the UAT link. Two completely different
schemes.
I'm not really sure what you mean by "get Mode S".
As far as providing other services (ok, "features" , I believe one
of the things they are looking at, is taking ADS-B In to drive a TCAS
display (ADS-B is *not* currently certified for collision avoidance).
You can count on that as TCAS currently has accuracy limitations which is
why the range is quite limited, but this is more of a recent development.
As far as what I mean by "features", I'm talking about everything that ModeS
was originally intended to be capable of doing. You have to remember that
the technology is over 30 years old now. Much of what was originally
conceived will never be implemented.
AIUI, most of the rest of the world (those bits that are planning
ADS-B) are looking to do it that way.
1090 only gives you TIS. UAT adds FIS (Weather, NOTAMs).
1090 is capable of considerably more than TIS. Some of that capability has
already been realized, but it remains to be seen how much more will. The
airlines already get the products you mentioned through ACARS.
Old September 10th 08, 05:27 AM posted to rec.aviation.ifr
Jon
Extended
you're
will
be
schemes.
What I meant was the UAT datalink is not equipped to receive (or
transmit) Mode S. But I misread what you wrote, so I guess it doesn't
matter.
1090 only gives you TIS. *UAT adds FIS (Weather, NOTAMs).
1090 is capable of considerably more than TIS. *Some of that capability has
already been realized, but it remains to be seen how much more will. *The
Are those products received over 1090?
Old September 10th 08, 05:45 AM posted to rec.aviation.ifr
Mike[_22_]
Extended
think
you're
UATs
will
be
schemes.
matter.
has
1090 ES doesn't have the bandwidth necessary to do much in the way of large
data transfers, however as far as the big airplanes go, there's really not
much need. ACARS gives them far more and would not go away even if it were
possible to put those products on 1090 ES.
Old September 10th 08, 05:51 AM posted to rec.aviation.ifr
Jon
Extended
think
you're
UATs
will
be
schemes.
matter.
has
much need. *ACARS gives them far more and would not go away even if it were
No doubt. I was mainly commenting on what UAT provides, not about
whether an existing 1090 user could receive those equivalent products
with a 3rd box.
Old September 10th 08, 02:45 PM posted to rec.aviation.ifr
Mike[_22_]
large
were
What does ACARS run on? Satellite data, or shortwave radio?
You can read all about it on Wiki:
http://en.wikipedia.org/wiki/ACARS
I don't have that much knowledge about ACARS. All I know is ARINC maintains
that service and ACARS equipped aircraft can receive clearance delivery
service on it at major airports in the US without ever talking to ATC. I've
heard Jet-A burners say they can receive METARs, NOTAMs, and digital ATIS
information on it. I would assume airline dispatchers can send and/or
receive short text messages on it with the aircrews, but I have no idea if
this is the case.
Garrecht Mode S transponder - USA? Eric Greenwell Soaring 3 August 20th 07 09:05 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
KT76C Mode C transponder - what is it worth? Mike Rapoport General Aviation 1 November 21st 04 05:56 AM
KT76C Mode C transponder - what is it worth? G.R. Patterson III Owning 0 November 21st 04 05:56 AM
WTB: Mode C Transponder Chris Batcheller Aviation Marketplace 0 February 21st 04 01:31 PM
