Mode S transponder display to ATC?
Old September 10th 08, 05:45 AM posted to rec.aviation.ifr
Mike[_22_]
Default Mode S transponder display to ATC?
"Jon" wrote in message
On Sep 8, 9:54 pm, "Mike" wrote:
"Peter" wrote in message
"Mike" wrote
Some of the ModeS features will never be implemented and the ModeS
Extended
Squitter will mainly be used by the airlines. For GA, I don't
think
you're
going to see much in the way of new ModeS features as the ADS-B
UATs
will
be
the preferred new technology path for data link.
Indeed. You won't get Mode S on the UAT link. Two completely different
schemes.
I'm not really sure what you mean by "get Mode S".
What I meant was the UAT datalink is not equipped to receive (or
transmit) Mode S. But I misread what you wrote, so I guess it doesn't
matter.
1090 only gives you TIS. UAT adds FIS (Weather, NOTAMs).
1090 is capable of considerably more than TIS. Some of that capability
has
already been realized, but it remains to be seen how much more will. The
airlines already get the products you mentioned through ACARS.
Are those products received over 1090?
1090 ES doesn't have the bandwidth necessary to do much in the way of large
data transfers, however as far as the big airplanes go, there's really not
much need. ACARS gives them far more and would not go away even if it were
possible to put those products on 1090 ES.
Old September 10th 08, 05:51 AM posted to rec.aviation.ifr
Jon
Extended
think
you're
UATs
will
be
schemes.
matter.
has
much need. *ACARS gives them far more and would not go away even if it were
No doubt. I was mainly commenting on what UAT provides, not about
whether an existing 1090 user could receive those equivalent products
with a 3rd box.
Old September 10th 08, 02:45 PM posted to rec.aviation.ifr
Mike[_22_]
large
were
What does ACARS run on? Satellite data, or shortwave radio?
You can read all about it on Wiki:
http://en.wikipedia.org/wiki/ACARS
I don't have that much knowledge about ACARS. All I know is ARINC maintains
that service and ACARS equipped aircraft can receive clearance delivery
service on it at major airports in the US without ever talking to ATC. I've
heard Jet-A burners say they can receive METARs, NOTAMs, and digital ATIS
information on it. I would assume airline dispatchers can send and/or
receive short text messages on it with the aircrews, but I have no idea if
this is the case.
Garrecht Mode S transponder - USA? Eric Greenwell Soaring 3 August 20th 07 09:05 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
KT76C Mode C transponder - what is it worth? Mike Rapoport General Aviation 1 November 21st 04 05:56 AM
KT76C Mode C transponder - what is it worth? G.R. Patterson III Owning 0 November 21st 04 05:56 AM
WTB: Mode C Transponder Chris Batcheller Aviation Marketplace 0 February 21st 04 01:31 PM
