![]() "Kevin Brooks" wrote in message .. . I think there are two issues here. The first is when the sensor is attached to the weapon, as it is in a sensor in a missile. Here, there is no sensor/shooter cycle, unless you choose to have a human involved in the decision to fire. That is way beyond even our capabilities. You are talking autonomous combat systems. The closest thing we have to that in service are the intelligent antiarmor submunitions, which are already in service in cluter munitions to include WCMD dispensers, and will soon be available as a warhead option for the Army's ATACMS missiles. But they still require a sensor in the loop, because you can't just fire them "in that direction, more or less", and hit anything--you have to have a pretty narrow determination of where the target is right at the time the weapon arrives. I think that Phil is probably talking about weapons like the IAI Harpy. It is a relatively inexpensive "CM" used in SEAD operations. The only significant technology employed by this vehicle is in the sensor (and even there, a "middle-ranking country" should not have a problem developing or procuring). The question really is if it is possible to integrate different sensors (TV, IR) on such vehicles, if you can accurately identify targets (based on some signature characteristics or library), and how effective it could be (at not killing your own or being easily defeated by the enemy). Now if you want to send a flock of CM's out and about to go on a hunter-killer mission, you have some real problems to confront, like: (a) How do you prevent fratricide or targeting of the local version of the Sanford garbage truck (remember that not every enemy is going to be able to discount collateral damage like the insurgents we are no facing in Iraq do)? That depends on the programming of the weapon. The same thought process that goes into autonomously targeted systems (ALARM, Harpy, SMArt, etc.) - systems that can be launched against enemy positions and where the weapon autonomously selects on locks on to its target - would be used. (b) Are you going to send it in low, where it MIGHT have a chance at surviving, but its field of view is extremely limited, so it is that much more likely to not find any target to hit, but which also requires oodles of (very accurate, and likely unavailable to most potential foes) digital topographic data to be uploaded and a complex navigation system) or up high where the view is better, but also where it becomes easy meat for the layers of Patriots and Avengers fielded by the resident duckhunters, along with any covering Aegis controlled Standards in the littoral zone, and the ubiquitous F-15/F-22 CAP? and, Good questions for the side employing them. If you are indeed talking about a "massive" use of such weapons, I think that the Patriots (and other anti-aircraft systems) would be quickly (and quite expensively) overwhelmed. Overwhelming, confusing, and otherwise countering the sensor might be a better approach. (c) Development of a reliable, compact, onboard sensor suite that provides enough resolution to find likely targets, and a darned intelligent software package to handle target discrimination (from background clutter, earlier posited garbage truck, etc.), and can also recognize an entire range of potential targets and select the one you would want hit from amongst all of them. If you are talking about a "massive" deployment of such inexpensive weapons, you might not need to concern yourself with those that "miss". Depending on the cost of the vehicles, the total number acquired, and the budget allocated, the user might be satisfied with a success rate well below 100%. Sorry, but I don't see ANY potential foes we might face in your near term overcoming one, much less all, of those hurdles, and I am sure I have missed a few more. [snip] The Harpy has been around for a while. And in the mean time, technology has progressed and costs of acquisition declined (for commercially available components). |
![]() "Dionysios Pilarinos" wrote in message ... "Kevin Brooks" wrote in message .. . I think there are two issues here. The first is when the sensor is attached to the weapon, as it is in a sensor in a missile. Here, there is no sensor/shooter cycle, unless you choose to have a human involved in the decision to fire. That is way beyond even our capabilities. You are talking autonomous combat systems. The closest thing we have to that in service are the intelligent antiarmor submunitions, which are already in service in cluter munitions to include WCMD dispensers, and will soon be available as a warhead option for the Army's ATACMS missiles. But they still require a sensor in the loop, because you can't just fire them "in that direction, more or less", and hit anything--you have to have a pretty narrow determination of where the target is right at the time the weapon arrives. I think that Phil is probably talking about weapons like the IAI Harpy. It is a relatively inexpensive "CM" used in SEAD operations. The only significant technology employed by this vehicle is in the sensor (and even there, a "middle-ranking country" should not have a problem developing or procuring). The question really is if it is possible to integrate different sensors (TV, IR) on such vehicles, if you can accurately identify targets (based on some signature characteristics or library), and how effective it could be (at not killing your own or being easily defeated by the enemy). And those questions are the kind that even the US, with its multi-billion dollar R&D structure, is tangling with--do you really see some second/third world potential foe solving that dilemma over the posited period of the next ten years? I don't. Now if you want to send a flock of CM's out and about to go on a hunter-killer mission, you have some real problems to confront, like: (a) How do you prevent fratricide or targeting of the local version of the Sanford garbage truck (remember that not every enemy is going to be able to discount collateral damage like the insurgents we are no facing in Iraq do)? That depends on the programming of the weapon. The same thought process that goes into autonomously targeted systems (ALARM, Harpy, SMArt, etc.) - systems that can be launched against enemy positions and where the weapon autonomously selects on locks on to its target - would be used. Those home on active emitters, keeping their last transmitting location in their memory in case they drop off the air. That is a big difference from going after targets that are purely passive and are not radiating (or not radiating anything you can actually read with a system that could be placed in such a small weapon--detecting the frequency agile signals from vehicle FM radios is not going to work). (b) Are you going to send it in low, where it MIGHT have a chance at surviving, but its field of view is extremely limited, so it is that much more likely to not find any target to hit, but which also requires oodles of (very accurate, and likely unavailable to most potential foes) digital topographic data to be uploaded and a complex navigation system) or up high where the view is better, but also where it becomes easy meat for the layers of Patriots and Avengers fielded by the resident duckhunters, along with any covering Aegis controlled Standards in the littoral zone, and the ubiquitous F-15/F-22 CAP? and, Good questions for the side employing them. If you are indeed talking about a "massive" use of such weapons, I think that the Patriots (and other anti-aircraft systems) would be quickly (and quite expensively) overwhelmed. Overwhelming, confusing, and otherwise countering the sensor might be a better approach. I disagree. On the one hand you are going to have to use a pretty complex CM of sorts, as we have already seen from the discussion to this point, if you are going to engage previously unlocated targets, so the idea that these things will be cheaply turned out in some converted auto garage is not going to cut it. They will also be expensive--the R&D effort is still required, since what has been postulated is essentially an autonomous attack system that does not currently exist even in the US. Third, the number of Patiots that can be made available is not a trivial number--count the number of missiles available in the uploaded canisters of a single battery, not to mention the reminder of its ABL that is accompanying them. Finally, we have a rather substantial stock of Stingers, including ones mounted on Avengers and BFV-Stinger, along with the regular MANPADS. Sorry, this just does not look realistic to me. Other posters have taken the more proper tack--don't try to confront the US on conventional terms and instead go the unconventional warfare route--much more likely to at least stand a chance at success of sorts. (c) Development of a reliable, compact, onboard sensor suite that provides enough resolution to find likely targets, and a darned intelligent software package to handle target discrimination (from background clutter, earlier posited garbage truck, etc.), and can also recognize an entire range of potential targets and select the one you would want hit from amongst all of them. If you are talking about a "massive" deployment of such inexpensive weapons, you might not need to concern yourself with those that "miss". Depending on the cost of the vehicles, the total number acquired, and the budget allocated, the user might be satisfied with a success rate well below 100%. I'd be surprised if this approach yielded a system that acheived a success rate that reaches even double digits--for the commitment of significant resources that would have been better used training irregulars and creating caches of weapons and explosives. Sorry, but I don't see ANY potential foes we might face in your near term overcoming one, much less all, of those hurdles, and I am sure I have missed a few more. [snip] The Harpy has been around for a while. And in the mean time, technology has progressed and costs of acquisition declined (for commercially available components). Again, there is one heck of a difference between going after an active emitter like an AD radar and passive targets, especially if you are the disadvantaged party in terms if ISR and C-4, which we can bet the opposition would be in such a scenario. Brooks |
On Thu, 18 Dec 2003 18:22:34 GMT, Kevin Brooks wrote:
I think that Phil is probably talking about weapons like the IAI Harpy. It is a relatively inexpensive "CM" used in SEAD operations. The only significant technology employed by this vehicle is in the sensor (and even there, a "middle-ranking country" should not have a problem developing or procuring). The question really is if it is possible to integrate different sensors (TV, IR) on such vehicles, if you can accurately identify targets (based on some signature characteristics or library), and how effective it could be (at not killing your own or being easily defeated by the enemy). And those questions are the kind that even the US, with its multi-billion dollar R&D structure, is tangling with--do you really see some second/third world potential foe solving that dilemma over the posited period of the next ten years? I don't. The problems listed above are information-processing problems, that is, software problems. Does it really require billions of dollars to solve these problems? I say no: a few small groups of really competent programms can be many times more productive than how software is traditionally written. I've worked as a programmer for defense contractors (and for other large organisations), and believe me, there is a *lot* of waste and inefficiency. If the software was written right, it could probably be done with several orders of magnitude more efficiency. Those home on active emitters, keeping their last transmitting location in their memory in case they drop off the air. That is a big difference from going after targets that are purely passive and are not radiating (or not radiating anything you can actually read with a system that could be placed in such a small weapon--detecting the frequency agile signals from vehicle FM radios is not going to work). Most ground vehicles radiate visible lightr, at least during daytime. At light they radiate IR, which can bre picked up with similar sensors. I disagree. On the one hand you are going to have to use a pretty complex CM of sorts, as we have already seen from the discussion to this point, if you are going to engage previously unlocated targets, so the idea that these things will be cheaply turned out in some converted auto garage is not going to cut it. Wrong. The complexity is in the *software*. CM hardware can be -- and historically has been -- put together by unskilled slave labour in squalid conditions. They will also be expensive--the R&D effort is still required, Yes. But once software has been written once (and we're talking millions not billions of dollars) it can be duplicated at zero cost. since what has been postulated is essentially an autonomous attack system that does not currently exist even in the US. Third, the number of Patiots that can be made available is not a trivial number--count the number of missiles available in the uploaded canisters of a single battery, not to mention the reminder of its ABL that is accompanying them. Do you have actual numbers here? Finally, we have a rather substantial stock of Stingers, including ones mounted on Avengers and BFV-Stinger, along with the regular MANPADS. It would be quite easy for an attack by lots of cruise missiles to overload the defences at a point. -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: , but first subtract 275 and reverse the last two letters). |
![]() "phil hunt" wrote in message . .. On Thu, 18 Dec 2003 18:22:34 GMT, Kevin Brooks wrote: snip since what has been postulated is essentially an autonomous attack system that does not currently exist even in the US. Third, the number of Patiots that can be made available is not a trivial number--count the number of missiles available in the uploaded canisters of a single battery, not to mention the reminder of its ABL that is accompanying them. Do you have actual numbers here? Six firing batteries per Patriot battalion, with eight launchers per battery, equals 48 launchers per battalion. Each launcher has 4 rounds onboard, so you are talking 192 missiles loaded out and ready to fire--not sure what the ABL is, but safely assume at least two rounds per tube in the battery/BN trains structure, so we are looking at what, another 384 rounds readily available? So total Pats equals about 576 rounds for a single battalion? Then you have the Avengers, with 36 Avengers in each corps level ADA Avenger battalion, each with 8 tubes uploaded, so just taking into account their initial upload you are talking 288 missiles without bothering to consider their ABL in the trains. But that's not all, folks--each division has its own ADA battalion, with another 24 Avengers, 24 BSF-V's, and 40 MANPADS (or a heavy division), so again minus the ammo in the trains, you have another 328 Stingers there. So your nominal corps force is going to have somewhere in the neighborhood of beween 576 and 1,100 Patriots covering it, another thousand plus Stingers (conservative estimate). Are you beginning to understand why trying to out-tech the US is an unwise move if you are really interested in asymetric warfare? Brooks |
On Thu, 18 Dec 2003 22:17:34 GMT, Derek Lyons wrote:
(phil hunt) wrote: The problems listed above are information-processing problems, that is, software problems. Does it really require billions of dollars to solve these problems? I say no: a few small groups of really competent programms can be many times more productive than how software is traditionally written. The issue isn't programmers Phil. The issue the massive amounts of R&D to develop the information needed to specify the sensor that the programmers will process the output of. The sensors needed are visual and IR imaging. It doesn't require a massive R&D program to determine that, or to decide which combinations of number of pixels and widths of field of view are appropriate. The issue is the massive amount of R&D needed to develop the algorithms the programmers will implement to analyze the output of the sensor. Do you know anything about programming? If you did, you'd know that developing algorithms is what programmers do. -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: , but first subtract 275 and reverse the last two letters). |
ess (phil hunt) wrote:
On Thu, 18 Dec 2003 22:17:34 GMT, Derek Lyons wrote: (phil hunt) wrote: The problems listed above are information-processing problems, that is, software problems. Does it really require billions of dollars to solve these problems? I say no: a few small groups of really competent programms can be many times more productive than how software is traditionally written. The issue isn't programmers Phil. The issue the massive amounts of R&D to develop the information needed to specify the sensor that the programmers will process the output of. The sensors needed are visual and IR imaging. It doesn't require a massive R&D program to determine that, or to decide which combinations of number of pixels and widths of field of view are appropriate. Ah, another problem handwaved away. You not only lack a clue, you are aggressive in avoiding obtaining one. The issue is the massive amount of R&D needed to develop the algorithms the programmers will implement to analyze the output of the sensor. Do you know anything about programming? If you did, you'd know that developing algorithms is what programmers do. Do *you* know anything about programming? If you did, you'd know that developing the algorithm and implementing the same are two different, howsoever intertwined, processes. D. -- The STS-107 Columbia Loss FAQ can be found at the following URLs: Text-Only Version: http://www.io.com/~o_m/columbia_loss_faq.html Enhanced HTML Version: http://www.io.com/~o_m/columbia_loss_faq_x.html Corrections, comments, and additions should be e-mailed to , as well as posted to sci.space.history and sci.space.shuttle for discussion. |
Derek Lyons wrote:
(phil hunt) wrote: [...] The issue isn't programmers Phil. The issue the massive amounts of R&D to develop the information needed to specify the sensor that the programmers will process the output of. The sensors needed are visual and IR imaging. It doesn't require a massive R&D program to determine that, or to decide which combinations of number of pixels and widths of field of view are appropriate. Ah, another problem handwaved away. You not only lack a clue, you are aggressive in avoiding obtaining one. Hmm. I've done several iterations of this problem, though not with systems that went to full scale development or production. I believe that for suitably moderated operational requirements, the problem can be much simpler than I believe Derek thinks it is. I belive that Phil is grossly underestimating the real requirements, even for those suitably moderated operational requirements. There is a fair amount of open source material on various small guided weapon R&D and proposals. Unless those were all wrong, it can be a lot simpler than current 'standard' weapons programs. But few of those have progressed to production. The new Marines/Navy Spike missile is one exception, and to some degree is the exception that probably proves the rule. Their R&D budget essentially was hidden in the slush funds at China Lake for a couple of years, and the missile itself is estimated to cost at most a few thousand dollars. -george william herbert |
On Sat, 20 Dec 2003 21:45:56 GMT, Derek Lyons wrote:
(phil hunt) wrote: The issue is the massive amount of R&D needed to develop the algorithms the programmers will implement to analyze the output of the sensor. Do you know anything about programming? If you did, you'd know that developing algorithms is what programmers do. Do *you* know anything about programming? I've already told you, it's my profession. Now, are you going to anwser my question: have you every done any programming, and if so, how much and in what languages? Failure to answer will be considered as evidence of trolldom. -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: , but first subtract 275 and reverse the last two letters). |
Australia F111 to be scrapped!! | John Cook | Military Aviation | 35 | November 10th 03 11:46 PM |
