On Sep 16, 10:08*am, "Mick" @_#`~#@.^net wrote:
"Dudley Henriques" wrote in message ... On Sep 16, 8:38 am, "Mick" @_#`~#@.^net wrote: "Stealth Pilot" wrote in message .. . On Mon, 15 Sep 2008 12:55:09 -0700 (PDT), Dudley Henriques wrote: The way I would present this issue is to simply say that brakes are put on the airplane to hold it for the run up check and for use ONLY when your pre-planned use of aerodynamic forces available to you, or your steering capabilities won't make the necessary change in direction. In other words, you shouldn't be using them on takeoff, landing, and even while taxiing if your planning is adequate for the situation. I like the general rule that dictates that brakes on an airplane should be used as little as possible. Dudley Henriques you know that I posted a comment along this exact line of thought about a month ago I got bagged by nearly everyone for over a week. I'm still correct in what I wrote and you evidently are in agreement. :-) Stealth Pilot No, it just mean you are both wrong. Don't think so. --------------------------------------- Sure, jump on the band wagon Dumley. So brakes were no put on aircraft to stop them. You're both full of it. Well Hello Maxie! Nothing but the usual I see :-)) |
On Sep 16, 9:08*am, "Mick" @_#`~#@.^net wrote:
"Dudley Henriques" wrote in message ... On Sep 16, 8:38 am, "Mick" @_#`~#@.^net wrote: "Stealth Pilot" wrote in message .. . On Mon, 15 Sep 2008 12:55:09 -0700 (PDT), Dudley Henriques wrote: The way I would present this issue is to simply say that brakes are put on the airplane to hold it for the run up check and for use ONLY when your pre-planned use of aerodynamic forces available to you, or your steering capabilities won't make the necessary change in direction. In other words, you shouldn't be using them on takeoff, landing, and even while taxiing if your planning is adequate for the situation. I like the general rule that dictates that brakes on an airplane should be used as little as possible. Dudley Henriques you know that I posted a comment along this exact line of thought about a month ago I got bagged by nearly everyone for over a week. I'm still correct in what I wrote and you evidently are in agreement. :-) Stealth Pilot No, it just mean you are both wrong. Don't think so. --------------------------------------- Sure, jump on the band wagon Dumley. So brakes were no put on aircraft to stop them. You're both full of it. Using brakes to stop a plane is like using a pier to stop a boat. And you are, in truth if not in fact, a waste of air. |
![]() wrote in message ... On Sep 16, 9:08 am, "Mick" @_#`~#@.^net wrote: "Dudley Henriques" wrote in message ... On Sep 16, 8:38 am, "Mick" @_#`~#@.^net wrote: "Stealth Pilot" wrote in message .. . On Mon, 15 Sep 2008 12:55:09 -0700 (PDT), Dudley Henriques wrote: The way I would present this issue is to simply say that brakes are put on the airplane to hold it for the run up check and for use ONLY when your pre-planned use of aerodynamic forces available to you, or your steering capabilities won't make the necessary change in direction. In other words, you shouldn't be using them on takeoff, landing, and even while taxiing if your planning is adequate for the situation. I like the general rule that dictates that brakes on an airplane should be used as little as possible. Dudley Henriques you know that I posted a comment along this exact line of thought about a month ago I got bagged by nearly everyone for over a week. I'm still correct in what I wrote and you evidently are in agreement. :-) Stealth Pilot No, it just mean you are both wrong. Don't think so. --------------------------------------- Sure, jump on the band wagon Dumley. So brakes were no put on aircraft to stop them. You're both full of it. Using brakes to stop a plane is like using a pier to stop a boat. And you are, in truth if not in fact, a waste of air. ---------------------------------- And you, a half assed sock puppet. |
On Sep 25, 9:26*pm, Bertie the Bunyip wrote:
"Mick" #$$#@%%%.^^^ wrote : wrote in message news:4817e8f1-a5c6-46f0-89ee-fc21b8c95634 @k13g2000hse.googlegroups.com. .. On Sep 16, 9:08 am, "Mick" @_#`~#@.^net wrote: "Dudley Henriques" wrote in message news:4f4bb25a-a5ed-4a39-a5dd- ... On Sep 16, 8:38 am, "Mick" @_#`~#@.^net wrote: "Stealth Pilot" wrote in message .. . On Mon, 15 Sep 2008 12:55:09 -0700 (PDT), Dudley Henriques wrote: The way I would present this issue is to simply say that brakes are put on the airplane to hold it for the run up check and for use ONLY when your pre-planned use of aerodynamic forces available to you, or your steering capabilities won't make the necessary change in direction. In other words, you shouldn't be using them on takeoff, landing, and even while taxiing if your planning is adequate for the situation. I like the general rule that dictates that brakes on an airplane should be used as little as possible. Dudley Henriques you know that I posted a comment along this exact line of thought about a month ago I got bagged by nearly everyone for over a week. I'm still correct in what I wrote and you evidently are in agreement. :-) Stealth Pilot No, it just mean you are both wrong. Don't think so. --------------------------------------- Sure, jump on the band wagon Dumley. So brakes were no put on aircraft to stop them. You're both full of it. Using brakes to stop a plane is like using a pier to stop a boat. And you are, in truth if not in fact, a waste of air. ---------------------------------- And you, a half assed sock puppet. Wow. A sock puppet lame from Maxie. That musta stung Andrew. Bertie Now I have a boo-boo! Someplace...searches...nope, apparently not...DARN SOCKS!! Hmmm...was that an epithet or an imperative? If we darn socks then what will Maxipad do for therapy? And he/she/it's still a waste of air. OTOH, if it's an attempt at a Turing program than the programmer should be shot- too limited responses, esp. the repost without a reply- juvie at best. I wonder if he/she/it holds its breath and turns blue after 'send'? |
Brakes? | WingFlaps | Piloting | 69 | March 4th 08 06:27 AM |
Good news for scratch builders of metal airplanes - Home Depot rents bending brakes | flybynightkarmarepair | Home Built | 7 | January 6th 07 04:22 PM |
Carbon brakes | [email protected] | Piloting | 3 | August 19th 06 07:01 AM |
Trailer brakes | Bert Willing | Soaring | 1 | October 31st 03 07:55 AM |
Cobratrailer&brakes | Greg Arnold | Soaring | 5 | October 6th 03 03:14 PM |
