Airplanes and Brakes?
Old September 16th 08, 03:34 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default Airplanes and Brakes?
On Sep 16, 10:08*am, "Mick" @_#`~#@.^net wrote:
On Sep 16, 8:38 am, "Mick" @_#`~#@.^net wrote:
"Stealth Pilot" wrote in message
On Mon, 15 Sep 2008 12:55:09 -0700 (PDT), Dudley Henriques
The way I would present this
issue is to simply say that brakes are put on the airplane to hold it
for the run up check and for use ONLY when your pre-planned use of
aerodynamic forces available to you, or your steering capabilities
won't make the necessary change in direction.
In other words, you shouldn't be using them on takeoff, landing, and
even while taxiing if your planning is adequate for the situation.
I like the general rule that dictates that brakes on an airplane
should be used as little as possible.
Dudley Henriques
you know that I posted a comment along this exact line of thought
about a month ago I got bagged by nearly everyone for over a week.
I'm still correct in what I wrote and you evidently are in agreement.
Stealth Pilot
No, it just mean you are both wrong.
Don't think so.
Sure, jump on the band wagon Dumley.
So brakes were no put on aircraft to stop them. You're both full of it.
Well Hello Maxie! Nothing but the usual I see :-))
Brakes? WingFlaps Piloting 69 March 4th 08 06:27 AM
Good news for scratch builders of metal airplanes - Home Depot rents bending brakes flybynightkarmarepair Home Built 7 January 6th 07 04:22 PM
Carbon brakes [email protected] Piloting 3 August 19th 06 07:01 AM
Trailer brakes Bert Willing Soaring 1 October 31st 03 07:55 AM
Cobratrailer&brakes Greg Arnold Soaring 5 October 6th 03 03:14 PM
