asymetric warfare
Old December 19th 03, 05:02 AM
Kevin Brooks
"Dionysios Pilarinos" wrote in message
"Kevin Brooks" wrote in message
I think that Phil is probably talking about weapons like the IAI
Harpy.
It
is a relatively inexpensive "CM" used in SEAD operations. The only
significant technology employed by this vehicle is in the sensor (and
even
there, a "middle-ranking country" should not have a problem developing
or
procuring).
The question really is if it is possible to integrate different
sensors
(TV,
IR) on such vehicles, if you can accurately identify targets (based on
some
signature characteristics or library), and how effective it could be
(at
not
killing your own or being easily defeated by the enemy).
And those questions are the kind that even the US, with its
multi-billion
dollar R&D structure, is tangling with--do you really see some
second/third
world potential foe solving that dilemma over the posited period of the
next
ten years? I don't.
The US has a number of programs all employing various degrees of
technological innovation. While money has been allocated into the research
of new UAV/UCAV's, obviously that is a relatively small investment (when
compared to the total budget). Even with those programs, human involvement
seems to be essential in the operation of the system and targeting of the
enemy. Obviously the program selection, funding, and priority given
differs
from country to country. I'm just stating that another country could take
a
position on this matter that might differ from that of the US.
That depends on the programming of the weapon. The same thought
process
that
goes into autonomously targeted systems (ALARM, Harpy, SMArt, etc.) -
systems that can be launched against enemy positions and where the
weapon
autonomously selects on locks on to its target - would be used.
Those home on active emitters, keeping their last transmitting location
in
their memory in case they drop off the air. That is a big difference
from
going after targets that are purely passive and are not radiating (or
not
radiating anything you can actually read with a system that could be
placed
in such a small weapon--detecting the frequency agile signals from
vehicle
FM radios is not going to work).
There is a reason I included the SMArt artillery round. It's advanced
sensor
will detect and target armored vehicles (MBT's, AIFV's, APC's, etc.) while
"loitering" over enemy positions. Depending on the target, different
sensors
can be used that can target different target characteristics. The SMArt
155mm artillery shell is already in service, so the technology for fusing
such sensors to UAV's (like the Harpy) is surely not a decade away.
SMArt is a contemporary of the (since cancelled?) SADARM. Both are
terminally guided munitions--emphasis on TERMINALLY. A far cry from being an
autonomous hunter/killer system capable of finding a target cluster and then
engaging it. You can add the BAT and even the Skeet terminally guided
submunitions to this same category, and the US has only recently fielded
cluster bombs capable of delivering these (including WCMD variant--CBU-105
IIRC). Great terminal killers--incapable of being wide area hunter killers
as this scheme posits.
Good questions for the side employing them. If you are indeed talking
about
a "massive" use of such weapons, I think that the Patriots (and other
anti-aircraft systems) would be quickly (and quite expensively)
overwhelmed.
Overwhelming, confusing, and otherwise countering the sensor might be
a
better approach.
I disagree. On the one hand you are going to have to use a pretty
complex
CM
of sorts, as we have already seen from the discussion to this point, if
you
are going to engage previously unlocated targets, so the idea that these
things will be cheaply turned out in some converted auto garage is not
going
to cut it.
A UAV is not an expensive proposition when you take away every aspect of
human control after launch. It can also be deployed in such a fashion that
few soldiers are needed in their transporation, targeting, and launch.
For example, Turkey recently purchased roughly 100 Harpy's. While the cost
has not been disclosed (at least to any sources I have access to), it is
not
considered to be "prohibitive" or even "substantial". A single
truck-transporter can carry 18 such weapons in canisters, and a battery of
3
can launch 54 of them simultaneously.
Again, these are not autonomous systems you bring up. If you expect the
average second/third world foe to be able to (a) develop a UAV that is
capable of performing this kind of autonomous attack, (b) Make it small
enough to be survivable and useable in a field environment, while also
packing in all of the sensors and computers it needs to get there, and
weapons it needs to be lethal once it arrives, (c) Have it retain a
significant degree of survivability in the face of US defensive systems, and
(d) do all of this over the next ten years; then we are just going to have
to disagree, because I don't see all of that coming together until hell
freezes over.
They will also be expensive--the R&D effort is still required,
since what has been postulated is essentially an autonomous attack
system
that does not currently exist even in the US.
But it does exist in the form of an artillery shell that can be fired 40
km
away from its target (in the case of weapons against armored vehicles).
Why
not extend that range to perhaps 100+ km by fusing it onto the body of a
UAV
(like the one used against radar transmissions)?
TERMINAL guidance only! They do not employ systems capable navigating the
delivery vehicle from launch point to attack point (preferably in a
survivable mode), of scanning wide areas, detecting a target, classifying
it, deciding to attack it, and then executing said attack, OK? BIG
difference from what the original poster posited.
Third, the number of Patiots
that can be made available is not a trivial number--count the number of
missiles available in the uploaded canisters of a single battery, not to
mention the reminder of its ABL that is accompanying them.
How many Patriots are used against incoming artillery shells? Imagine that
instead of artillery shells you have hundreds of self-guided UAV's. Even
against a Harpy battery (54 incoming vehicles that will loiter until they
detonate), what exactly can a Patriot battery do? Now imagine a few
hundred
more, some targeting AD and others armored vehicles or ships.
The likely expeditionary corps will include some 500-1000 Patriots in its
ABL, with some one-third of those ready for immediate use. Add in another
boatload of Stingers mounted on everything from Avenger and BSFV to the
traditional MANPADS mount. What that adds up to is anything but asymetric
warfare--it is just about the opposite, with the foe trying to out-tech the
US--bad move IMO.
As to arty--let 'em fire. First rounds get picked up by the Firefinder
radars, and before their first volley has arrived the MLRS and ATACMS are on
the way towards smothering their firing locations. The intelligent foe does
NOT want to get into an arty duel with US forces--ask the Iraqis who tried
that during ODS (those that survived the counter-battery effort, that is).
Finally, we have
a rather substantial stock of Stingers, including ones mounted on
Avengers
and BFV-Stinger, along with the regular MANPADS.
Perhaps I'm not informed on the subject, but how many UAV's or CM's have
been shot down by heat-seeking MANPADS (ever)? Some UAV's have been lost
in
the Balkans, Iraq, and Afghanistan due to ground fire (AAA), but I've
never
heard of a confirmed loss due to a MANPAD.
I doubt we know exactly what system has accounted for many of the various
UAV losses over the years. Suffice it to say thet the RIM-92 Stinger is
capable of engaging both UAV's and CM's (there has been a fair amount of
work here in the US on developing the TTP's for use of Avenger specifically
in the anti-CM role).
Sorry, this just does not
look realistic to me. Other posters have taken the more proper
tack--don't
try to confront the US on conventional terms and instead go the
unconventional warfare route--much more likely to at least stand a
chance
at
success of sorts.
I'm not trying to get into the mind of every despot in the world. However,
many of them invest time and money on conventional programs (like
ballistic
missiles). Compared to a ballistic missile system, wouldn't a sensor-fused
CM be a better investment?
Not if they lack the ISR system to be able to get it into the right target
box where it can release its SFW's, and that is not a very large footprint
that it has to hit. Not if they lack the ability to give the CM a pretty
good chance of survival. And most assuredly not if it is to be, as this
theory was posited, an autonomous attack system--that is just beyond the
capabilities of likely threats during the near-term period under
consideration.
If you are talking about a "massive" deployment of such inexpensive
weapons,
you might not need to concern yourself with those that "miss".
Depending
on
the cost of the vehicles, the total number acquired, and the budget
allocated, the user might be satisfied with a success rate well below
100%.
I'd be surprised if this approach yielded a system that acheived a
success
rate that reaches even double digits--for the commitment of significant
resources that would have been better used training irregulars and
creating
caches of weapons and explosives.
Irregulars are not going to stop the advance of any regular army (their
mission is quite different). What the army of a country needs to do is to
target the enemy formations. As was proved once again in Iraq, it is
suicidal to stand up against a better equipped and trained military in
order
to fight a "conventional" war. The speed, accuracy and lethality ( the
"punch") cannot be countered with 1960's defensive technology. You can
however try to expose any weakness that might exist in the defenses of
your
superior opponent (much like the Iraqi irregulars tried doing).
Sorry, but you are missing the whole concept of asymetric warfare. What you,
and the opriginal poster, are proposing is attacking the US military's
strengths, not its vulnerabilities--that is not asymetric. It is, however, a
good way to acheive martyrdom.
The Harpy has been around for a while. And in the mean time,
technology
has
progressed and costs of acquisition declined (for commercially
available
components).
Again, there is one heck of a difference between going after an active
emitter like an AD radar and passive targets, especially if you are the
disadvantaged party in terms if ISR and C-4, which we can bet the
opposition
would be in such a scenario.
How difficult was it for the Iraqi's to know the general geographic
position
of the US troops? Turning on CNN being one easy way. Imagine if they could
send self-targeting systems into the general location from 40 km away
(using
SMArt), what the US position would be. Obviously the Air Force would have
something to target (those nice artillery pieces), so that could not last
for long. But what if some regular-looking trucks a few hundred km's away
were achieving the same result? In that scenario, all I can do is remember
the "Scud hunt" from GW1.
You just don't get it--you send all of the SMArt's you want at the "general
position" of a ground unit and you will most likely succeed in (a) littering
the desert with a lot of wasted SFW's, and (b) open your delivery forces up
to immediate, and lethal, return fires. SFW's have to be fired into a
position directly over the desired target--not 500 meters this way, or 500
meters that way--right over it. In realtime. Against a moving US force. Use
CNN all you want and it is not going to solve those problems.
Brooks
Brooks
Old December 22nd 03, 06:37 AM
Dionysios Pilarinos
sensor
while
sensors
fusing
an
then
Define what you mean by "terminal killer". The SMArt (actually the
submunition) is delivered to the general location of enemy forces after
being expelled from an artillery piece some 40km away. The artillery piece
or battery that fired the round made the initial targeting based on
information gathered. How would all this change if you changed the delivery
vehicle of the submunition?
The aerial vehicle (UAV) would deliver the submunition to a specific area
(much like the arty shell does). Instead of loitering for a limited time (as
the SMArt does while it descends with a parachute), the UAV could follow a
programmed pattern until a target is identified.
Obviously some work would be required in fusing the UAV and SMArt (or
whatever else) sensors, and writing the software that would make it work
effectively. I'm just saying that the technology is currently present where
this would not require 10 years to develop.
that
cost
not
of
3
The Harpy sure is. And all I'm saying is that fusing other sensors to a
vehicle like the Harpy (to allow the targeting of MBT's, APC's, etc.) would
not require 10 years.
If you expect the
They can also acquire them (or certain technologies needed). Most countries
in the world do not have a serious problem gaining access to these (often
times commercially available) systems. Not everyone is facing an arms
embargo.
(b) Make it small
How easy do you think it would be for any military to find and destroy the
Harpy's that the Turkish forces have in their arsenal? I'm honestly quite
curious to know how you would counter such a threat (which in this case is
directed only against AD and surface ships).
and
The point of the original poster was that if you can deploy them on a
massive scale, you might not have to worry about the defensive systems
(which even if effective would be overwhelmed).
freezes over.
So what horizon do you believe in? Obviously UCAV's are operational as we
speak, so what will it take to remove the human operator from the terminal
guidance of the system (and I say terminal because I will assume that
auto-pilot takes care of post-launch navigation and piloting)?
km
Why
UAV
Target identification need only be "terminal" in nature. We are talking
about UAV's that would be directed to fly to a location and loiter until a
target is presented.
survivable mode),
There are many UAV's and CM's that do just that (with no immediate human
interaction).
The sensor (like that in the SMArt submunition) does NOT need to scan a wide
area. The UAV's flight pattern will determine the areas the sensor would be
exposed to.
that
they
hundred
US--bad move IMO.
Figthing the US is a "bad move IMO"!
But regardless of that fact, someone out there might just try to do so.
Developing such autonomous weapons appears to be a more logical decision
than those reached (like for example ballistic missiles and WMD).
on
does
It is not suicide when they cannot detect you and when you are out of range
(of their guns). Certainly the available arty out there (plus the required
expenditures) does make their use SUICIDAL against any enemy that employs
fire-finding radars and weapon systems with longer ranges. This is exactly
why an autonomous CM-type weapon system would be better (being outside the
range of both radar and even the ATACM).
in
never
specifically
I have serious reservations about the use of the Stinger (or other MANPAD
systems)against UAV's or other small low-flying targets. How much time is
the target exposed to your sensor, and how quickly can you acquire it? It's
hard enough against helo's, so I don't think they'd be too effective against
a massive UAV/CM-type assault.
However,
ballistic
sensor-fused
How much intelligence is needed to have a UAV fly a pattern in some general
geographic area? If you know the enemy and his supply chain is X km from a
given point (say your friendly positions) why not send out scores of the
weapons to fly patterns over the area, picking off any target that matches
your search criteria?
consideration.
I'll have to respectfully disagree.
to
order
your
you,
a
Who says that the US's (or a modern army's) defenses are not a
vulnerability? Who exactly was the last foe to have really tested them out?
How is using irregulars to destroy positions and forces (away from the
"front lines") different from using the kind of weapons we are discussing?
How can you call one "asymmetric" and exclude the other one simply because
it utilizes technology and not martyrs?
position
could
(using
have
last
away
remember
"general
littering
You would if you were using the SMArt as it exists today. Of course it
"loiters" from the point its chute deploys until it hits the ground. What if
it were able to loiter for hours, scanning hundreds of miles?
How would you identify where a UAV was launched from? Minimal heat
signature, non-ballistic track, difficulty in radar-tracking (from AWACS or
ground radar), non-distinct launch platform.
Use
It's not "directly over" the desired target. And obviously the various
weapons I have mentioned differ due to their sensors and delivery method.
However, have a UAV fly a pattern over "predicted" locations in a general
geographic area you know forces are present in. Soon enough, that sensor
will lock onto something.
Brooks
Old December 22nd 03, 11:26 AM
peter
I think almost everyone is missing the point about assymetric warfare. All
the comments are based on US/NATO type equipment standards, and military
objectives. The whole point of assymetric warfare is that you don't follow
the standards, you go for what you can achieve where you can achieve it with
what you can get. 9/11 was a classic example.
If some one out there is planning on using cruise missiles for example, he
wont build them to Tomahawk standards, he wont select tomahawk like targets
and so on.
Assymetric warfare is about doing the unexpected, with the unexpected by
surprise, that negates the defences and allows success.
If you haven't got the budget of the US, you dont try to emulate them and
expect to win, you have to think out of 'our' box.
Peter
Old December 22nd 03, 04:14 PM
Jack Linthicum
"peter" wrote in message ...
and so on.
Brings to mind the VC etc. use of 122mm and 240mm rockets as short
range boosters for oil drums, etc. filled with explosives. The new
variant is the Improvised Explosive Device, in this case the delivery
system comes to you in the form of patrols. Just saw a refernce to
600,000 tons of explosives in Iraq:
"There is approximately 600,000 tons of ordnance out on the ground
throughout the country," said Army Maj. Adam Boyd, of the 1138th Mine,
Explosive and Ordnance Information Coordination Center, "and the enemy
is getting smarter every single day on how to use it."
Old December 22nd 03, 11:38 PM
Derek Lyons
Yep. 9/11 is a demonstration of what happens when you *don't* have a
strategy or an operations plan. You raise a great sound and fury, but
accomplish nothing.
That works when the asymmetries as small. (For instance the Japanese
never expected our submarine campaign.) It fails when the asymmetries
are large as there is not military way to overcome them.
If you haven't got the budget of the US, you are not going to win
many, if any, victories of sufficient size. Your goal instead must be
to win on the political front, and there the 2nd-2rd tier nations have
the advantage.
D.
The STS-107 Columbia Loss FAQ can be found
at the following URLs:
Text-Only Version:
http://www.io.com/~o_m/columbia_loss_faq.html
Enhanced HTML Version:
http://www.io.com/~o_m/columbia_loss_faq_x.html
Corrections, comments, and additions should be
e-mailed to , as well as posted to
sci.space.history and sci.space.shuttle for
discussion.
Old December 23rd 03, 12:33 AM
John Schilling
"peter" writes:
and so on.
Aren't you forgetting something? In addition to Thinking Outside The
Box, don't they have to implement a Paradigm Shift or something like
that?
You're about ten years too late to pat yourself on the back for dispensing
privileged knowledge to the masses on this one. Everyone here gets the
point about Asymmetric Warfare. We understand it, really.
We are trying to explain to you that Asymmetric Warfare is not a Magic
Word that wipes away some very hard problems in weapons technology or
military science. There are *reasons* the US/NATO do things the way
they do, and if it is't the most efficient way possible it does at
least allow the concentration of enormous resources on those Very Hard
problems with the result that the US/NATO and company have some Very
Impressive capabilities.
Invoking the Asymmetric Warfare buzzword does nothing to counter those
capabilities. It isn't clear that they even *can* be countered, save
in kind, but if it is possible it will involve a whole slew of very
hard problems in its own right, and that the amateurish solutions
posited here are not going to cut it.
*John Schilling * "Anything worth doing, *
*Member:AIAA,NRA,ACLU,SAS,LP * is worth doing for money" *
*Chief Scientist & General Partner * -13th Rule of Acquisition *
*White Elephant Research, LLC * "There is no substitute *
* for success" *
*661-951-9107 or 661-275-6795 * -58th Rule of Acquisition *
Old December 24th 03, 05:04 AM
George William Herbert
Pushback. While you are generally correct... I think that some of
the enthusiasts here are not paying enough attention either to
details or to the big picture... I believe that there are some
unconventional and asymmetrical things which could be done which
would severely hamper western style warfare.
One of the things which could be done looks a lot like one of the
things under discussion here. There are many others, and the
overall strategy of defense by and only by massive cheap cruise
missiles is a grand scale loser, but as part of doing a lot of
other things it might well be a viable strategy component.
-george william herbert
Old December 30th 03, 07:16 PM
John Schilling
(George William Herbert) writes:
Yes, but even there it's important not to get caught up in the
game of winning the last war, designing the optimal force package
and tactical doctrine to defeat the US Military of 2003.
Because, e.g., cruise missile swarms are not going to be effectively
fielded without an extensive period of R&D, testing, procurement,
training, and deployment, which will be noticed and which will mean
you only get to use the cruise missile swarms against a US Military
that has accomodated itself to the idea of being hit by cruise missile
swarms.
So it's not enough to have a cheap guidance package that can distinguish
a tank from a rock, you now have to distinguish a tank from an inflatable
tank decoy. The United States Army of 2003 doesn't use inflatable decoys
because nobody has a precision deep strike capability against it, but if
an adversary changes the latter, the former is going to change as well.
Likewise, if your idea is that it doesn't matter how easy an individual
missile is to find and kill because you are going to saturate US/NATO
style air defenses with numbers, you don't match it against the present
standard of an F-15 with four each AMRAAMs and Sidewinders but against
an F-22 packed to the limit with air-to-air Stingers; fourty-five stowed
kills at 0.8 Pk per shot, if my math is correct.
* for success" *
Old December 31st 03, 03:06 AM
William Baird
grrr. I hate all these crossposts. Are they really necessary?
(John Schilling) wrote in message
This is definitely true. Defeating the US Military of 2003 would
be one thing. Defeating the US military of the time period that
it took to be able to develop the technology to defeat of the US
military of 2003 would be a different story altogether.
Actually, I'm willing to bet that by the time that the R&D is done for
the cheap and effective cruise missiles is completed that the US
military
will have trotted out a very effective defense already. In fact, if I
am
not mistaken, they're working on it already.
"Next," Wilson said, "we're going after mortars."
http://www.ausa.org/www/news.nsf/0/0...t&Auto Framed
(THEL shot down a 152mm in the article)
LLNL is working on the 100+ kw solid state laser prototype for HELSTF
as we speak. (http://www.llnl.gov/nif/lst/helstf.html) At that point
it gets cheaper to knock down the cheap but effective cruise missiles
than it does to make them. After all, it's just the cost of the
gasoline
(or kerosene if its a turbine and prolly would be) to power the
laser...
First couple generations I'd expect the lasers to be in dedicated AA
platforms. After that, I wouldn't be surprised at all if they
proliferated
into the slot of the AA .50 cal on tanks. assuming they still have
MBTs
around then, of course.
http://www.spacedaily.com/news/laser-03k.html
I have my very strong doubts that a chemical laser will make its way
onto the battlefield, at least in an armored vehicle. I can't see
soldiers embracing something that if the tanks get blow open by
artillery
or mines will wipe out a company easy...flourine bad. Very bad.
Will
William P Baird Do you know why the road less traveled by
Speaking for me has so few sightseers? Normally, there
Home: anzha@hotmail is something big, mean, with very sharp
Work: wbaird@nersc teeth - and quite the appetite! - waiting
Add .com/.gov somewhere along its dark and twisty bends.
Australia F111 to be scrapped!! John Cook Military Aviation 35 November 10th 03 11:46 PM
