Stefan wrote in news:9cc9b$48d7b746$54487392
: Robert Moore schrieb: A slip is a slip is a slip. From The FAA H-8083-3a, Airplane Flying Handbook Ok, so in the USA there exist several different brands of slips. In the rest of the world however, a slip is a slip is a slip. Which is how airplanes see it, too, I suppose. You're full of ****, stefan. Slips are slips no matter where you are and slips, while aerodynamically identical have different references. Bertie |
Bertie the Bunyip schrieb:
You're full of ****, stefan. Still better than completely hollow like you. Slips are slips no matter where you are and slips, while aerodynamically identical have different references. Of course they have different references... visual references, that is: In one, you look straight ahead, in the other, you look slightly to one side. I'm fully aware that this difference is enough for simple minded like you to think they are two different maneuvres. |
Stefan wrote in
: Bertie the Bunyip schrieb: You're full of ****, stefan. Still better than completely hollow like you. Slips are slips no matter where you are and slips, while aerodynamically identical have different references. Of course they have different references... visual references, that is: In one, you look straight ahead, in the other, you look slightly to one side. I'm fully aware that this difference is enough for simple minded like you to think they are two different maneuvres. Yeah, right backpedaling boi. Bertie |
Stefan wrote in : Bertie the Bunyip schrieb: You're full of ****, stefan. Still better than completely hollow like you. Slips are slips no matter where you are and slips, while aerodynamically identical have different references. Of course they have different references... visual references, that is: In one, you look straight ahead, in the other, you look slightly to one side. I'm fully aware that this difference is enough for simple minded like you to think they are two different maneuvres. Yeah, right backpedaling boi. You're halluzinating, as usual. And the follow-up trick is soooooo old and soooo booooring. |
![]() "Bertie the Bunyip" wrote in message ... | Stefan wrote in | : | | Bertie the Bunyip schrieb: | | You're full of ****, stefan. | | Still better than completely hollow like you. | | Slips are slips no matter where you are and slips, while | aerodynamically identical have different references. | | Of course they have different references... visual references, that | is: In one, you look straight ahead, in the other, you look slightly | to one side. I'm fully aware that this difference is enough for simple | minded like you to think they are two different maneuvres. | | | Yeah, right backpedaling boi. | | | Bertie |
On Mon, 22 Sep 2008 20:00:14 +0000 (UTC), Bertie the Bunyip wrote:
Stefan wrote in : Bertie the Bunyip schrieb: You're full of ****, stefan. Still better than completely hollow like you. Slips are slips no matter where you are and slips, while aerodynamically identical have different references. Of course they have different references... visual references, that is: In one, you look straight ahead, in the other, you look slightly to one side. I'm fully aware that this difference is enough for simple minded like you to think they are two different maneuvres. Yeah, right backpedaling boi. Bertie Bert, first time Little Luke took me up in his Velocity, he failed to inform me that the rudder system is different from ˇ§conventionalˇ¨ aircraft in both design and performance. In most aircraft the rudder pedals are interconnected. Pushing down on one rudder pedal causes a corresponding movement in the opposite (upward) direction of the other. LL says to me, let's slip this baby home. Taje the center stick." Uh, like first of all, I'm not LHanded. Then I find the rudder pedals. lol I was quick to note that the rudder pedals in the Velocity operate independent from each other,what I they failed to notice is that much of the sensory feedback with respect to rudder deployment is ****faced gone. Push one rudder pedal in the Velocity and the other remains motionless. Cessna and Piper pilots like me learn to rest both feet on the rudder pedals to get a ˇ§feelˇ¨ for the rudder position. Transferring this habit to the Velocity invites a common mistake ˇV the unintentional deployment of one (or both!) rudder(s) in flight. I passed the slip back to Little Puker. |
Ari wrote in
: On Mon, 22 Sep 2008 20:00:14 +0000 (UTC), Bertie the Bunyip wrote: Stefan wrote in : Bertie the Bunyip schrieb: You're full of ****, stefan. Still better than completely hollow like you. Slips are slips no matter where you are and slips, while aerodynamically identical have different references. Of course they have different references... visual references, that is: In one, you look straight ahead, in the other, you look slightly to one side. I'm fully aware that this difference is enough for simple minded like you to think they are two different maneuvres. Yeah, right backpedaling boi. Bertie Bert, first time Little Luke took me up in his Velocity, he failed to inform me that the rudder system is different from ˇ§conventionalˇ¨ aircraft in both design and performance. In most aircraft the rudder pedals are interconnected. Pushing down on one rudder pedal causes a corresponding movement in the opposite (upward) direction of the other. LL says to me, let's slip this baby home. Taje the center stick." Uh, like first of all, I'm not LHanded. Then I find the rudder pedals. lol I was quick to note that the rudder pedals in the Velocity operate independent from each other,what I they failed to notice is that much of the sensory feedback with respect to rudder deployment is ****faced gone. Push one rudder pedal in the Velocity and the other remains motionless. Cessna and Piper pilots like me learn to rest both feet on the rudder pedals to get a ˇ§feelˇ¨ for the rudder position. Transferring this habit to the Velocity invites a common mistake ˇV the unintentional deployment of one (or both!) rudder(s) in flight. I passed the slip back to Little Puker. Yes, I've heard about this feature in that type of airplane. I'm going to get a chance to fly a Long Eze pretty soon and I believe it works the same way. You can use both together as a speed brake, yes? Bertie |
On Sep 24, 12:26*pm, Bertie the Bunyip wrote:
Ari wrote : On Mon, 22 Sep 2008 20:00:14 +0000 (UTC), Bertie the Bunyip wrote: Stefan wrote in . ch: Bertie the Bunyip schrieb: You're full of ****, stefan. Still better than completely hollow like you. Slips are slips no matter where you are and slips, while aerodynamically identical have different references. Of course they have different references... visual references, that is: In one, you look straight ahead, in the other, you look slightly to one side. I'm fully aware that this difference is enough for simple minded like you to think they are two different maneuvres. Yeah, right backpedaling boi. Bertie Bert, first time Little Luke took me up in his Velocity, he failed to inform me that the rudder system is different from conventional aircraft in both design and performance. In most aircraft the rudder pedals are interconnected. Pushing down on one rudder pedal causes a corresponding movement in the opposite (upward) direction of the other. LL says to me, let's slip this baby home. Taje the center stick." Uh, like first of all, I'm not LHanded. Then I find the rudder pedals. lol I was quick to note that the rudder pedals in the Velocity operate independent from each other,what I they failed to notice is that much of the sensory feedback with respect to rudder deployment is ****faced gone. Push one rudder pedal in the Velocity and the other remains motionless. Cessna and Piper pilots like me learn to rest both feet on the rudder pedals to get a feel for the rudder position. Transferring this habit to the Velocity invites a common mistake V the unintentional deployment of one (or both!) rudder(s) in flight. I passed the slip back to Little Puker. Yes, I've heard about this feature in that type of airplane. I'm going to get a chance to fly a Long Eze pretty soon and I believe it works the same way. You can use both together as a speed brake, yes? Bertie Do those fins deploy in only one direction -- ie,outward, or inward -- and are spring loaded to neutral? Is the change in the airplane's axis pointing direction just caused by the drag increase when one side or the other is deployed? It looks to me almost like the way the MU aircraft used spoilers on top of the wings instead of ailerons (I think). |
![]() "Bertie the Bunyip" wrote in message ... | Ari wrote in | : | | On Mon, 22 Sep 2008 20:00:14 +0000 (UTC), Bertie the Bunyip wrote: | | Stefan wrote in | : | | Bertie the Bunyip schrieb: | | You're full of ****, stefan. | | Still better than completely hollow like you. | | Slips are slips no matter where you are and slips, while | aerodynamically identical have different references. | | Of course they have different references... visual references, that | is: In one, you look straight ahead, in the other, you look slightly | to one side. I'm fully aware that this difference is enough for | simple minded like you to think they are two different maneuvres. | | | Yeah, right backpedaling boi. | | Bertie | | Bert, first time Little Luke took me up in his Velocity, he failed to | inform me that the rudder system is different from ˇ§conventionalˇ¨ | aircraft in both design and performance. In most aircraft the rudder | pedals are interconnected. Pushing down on one rudder pedal causes a | corresponding movement in the opposite (upward) direction of the | other. | | LL says to me, let's slip this baby home. Taje the center stick." | | Uh, like first of all, I'm not LHanded. Then I find the rudder pedals. | lol | | I was quick to note that the rudder pedals in the Velocity operate | independent from each other,what I they failed to notice is that much | of the sensory feedback with respect to rudder deployment is ****faced | gone. Push one rudder pedal in the Velocity and the other remains | motionless. Cessna and Piper pilots like me learn to rest both feet on | the rudder pedals to get a ˇ§feelˇ¨ for the rudder position. | Transferring this habit to the Velocity invites a common mistake ˇV | the unintentional deployment of one (or both!) rudder(s) in flight. | | I passed the slip back to Little Puker. | | Yes, I've heard about this feature in that type of airplane. I'm going | to get a chance to fly a Long Eze pretty soon and I believe it works the | same way. You can use both together as a speed brake, yes? | | Berti Let us know when, so we can hide in our bunkers. |
Slips and skids | William Hung[_2_] | Piloting | 25 | March 17th 08 02:27 AM |
slips to landing in PTS | BB | Soaring | 6 | April 17th 07 05:58 AM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
A reluctance to take the controls | Jay Honeck | Piloting | 161 | December 1st 06 08:27 PM |
About forward slips | Mxsmanic | Piloting | 77 | November 2nd 06 11:35 PM |
