Mick schrieb:
| Glider pilots use them on occasion for rapid descent and they are expected | to demonstrate proficiency in them on the practical exam. How do you maintain alignment with the tow plane? When *descending*? ![]() BTW, some glider pilots use short slips to take up slack from the tow rope, should there happen to occur some in turbulence. Most prefer the use of airbrakes, though. |
Stefan wrote in
: Mick schrieb: | Glider pilots use them on occasion for rapid descent and they are | expected to demonstrate proficiency in them on the practical exam. How do you maintain alignment with the tow plane? When *descending*? ![]() BTW, some glider pilots use short slips to take up slack from the tow rope, should there happen to occur some in turbulence. Most prefer the use of airbrakes, though. No, they don;t fjukkktard. They skid. Bertie |
![]() "Bertie the Bunyip" wrote in message ... | Stefan wrote in | : | | Mick schrieb: | | | Glider pilots use them on occasion for rapid descent and they are | | expected to demonstrate proficiency in them on the practical exam. | | How do you maintain alignment with the tow plane? | | When *descending*? ![]() | | BTW, some glider pilots use short slips to take up slack from the tow | rope, should there happen to occur some in turbulence. Most prefer the | use of airbrakes, though. | | | No, they don;t fjukkktard. | | | They skid. | | | | Bertie You're a dumb ass. I seriously doubt you have ever flown a sailplane. |
"Mick" #$$#@%%%.^^^ wrote in :
"Bertie the Bunyip" wrote in message ... | Stefan wrote in | : | | Mick schrieb: | | | Glider pilots use them on occasion for rapid descent and they are | | expected to demonstrate proficiency in them on the practical exam. | | How do you maintain alignment with the tow plane? | | When *descending*? ![]() | | BTW, some glider pilots use short slips to take up slack from the tow | rope, should there happen to occur some in turbulence. Most prefer the | use of airbrakes, though. | | | No, they don;t fjukkktard. | | | They skid. | | | | Bertie You're a dumb ass. I seriously doubt you have ever flown a sailplane. I know you do. Bertie |
![]() "Stefan" wrote in message ... BTW, some glider pilots use short slips to take up slack from the tow rope, should there happen to occur some in turbulence. Most prefer the use of airbrakes, though. I never use the spoilers/airbrakes to take up slack, (though really slippery sailplanes will sometimes start a tow while holding just a tad of spoiler). That much control authority is simply not necessary. A glider tow is a very delicate dance, it takes timing and (usually) tiny control inputs. Usually a little climb will do the job to take up the slack. If you screwed up and got a really bad slack rope, you push rudder a bit to yaw, which increases drag a bit but perhaps more importantly puts your tow hook off center from the CG. Then, when the inevitable 'snatch" happens, some of the excess energy goes into pulling the nose around rather than suddenly accelerating the glider and causing the rope to go slack yet again. Vaughn |
On Sep 24, 5:12*am, "Vaughn Simon"
wrote: * *I never use the spoilers/airbrakes to take up slack, (though really slippery sailplanes will sometimes start a tow while holding just a tad of spoiler). That much control authority is simply not necessary. *A glider tow is a very delicate dance, it takes timing and (usually) tiny control inputs. *Usually a little climb will do the job to take up the slack. *If you screwed up and got a really bad slack rope, you push rudder a bit to yaw, which increases drag a bit but perhaps more importantly puts your tow hook off center from the CG. *Then, when the inevitable 'snatch" happens, some of the excess energy goes into pulling the nose around rather than suddenly accelerating the glider and causing the rope to go slack yet again. The bit where you see the towplane 'yoing' into the atmosphere and you know that you're going to hit that same lift in a second or two with the towplane now almost above you :-) Makes life interesting |
Vaughn Simon wrote:
you push rudder a bit to yaw, which increases drag a bit but perhaps more importantly puts your tow hook off center from the CG. unless ya have a CG hook like me. Which doesn't mean the slip doesn't help even with a CG hook. I use either method, except the climb method. I don't like having that much more potential energy to have to relinquish on the rope. We all have our little dances on tow. -- Message posted via http://www.aviationkb.com |
Vaughn Simon schrieb:
If you screwed up and got a really bad slack rope, I'm not sure I'd call a slack rope while towing through a rotor a screw up. As always, it all depends. |
Slips and skids | William Hung[_2_] | Piloting | 25 | March 17th 08 02:27 AM |
slips to landing in PTS | BB | Soaring | 6 | April 17th 07 05:58 AM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
A reluctance to take the controls | Jay Honeck | Piloting | 161 | December 1st 06 08:27 PM |
About forward slips | Mxsmanic | Piloting | 77 | November 2nd 06 11:35 PM |
