Crab, slips, and crossed controls
Old September 25th 08, 04:40 PM posted to rec.aviation.piloting
Mick[_2_]
Default Crab, slips, and crossed controls
"Stealth Pilot" wrote in message
| On Mon, 22 Sep 2008 14:10:50 GMT, Robert Moore
| wrote:
| Stealth Pilot wrote
| Sideslips are a very useful tool because they allow you to
| substantially increase the drag, which makes you descent like a
| plumbers toolbag, but doesnt change the forward speed. so you have no
| increased risk of stalling as you wash off the height.
| What you have described is the "forward slip". Although control usage
| is the same in both, a "side slip" is used to correct for a crosswind,
| and a "forward slip" is used to descend more rapidly on final without
| having the airspeed increase. If one is not landing, I suppose that it
| would just be a "slip".
| Airliners normally do not use either because of the increased discomfort
| caused the passengers....both being uncoordinated flight.
| Amine wrote:
| PS: I have read about many cases of jetliners that had to make
| emergency descents at abnormally high speeds, but the AC143 seems the
| only one to have used the sideslip.
| AC 143 was constrained by "touchdown speed" runway length. An "emergency
| descent" has no such constraint and therefore is able to use the
| aircraft's maximum certificated speed for the descent...far in excess of
| what would be possible in an approach/landing situation.
| In an engine failure situation, keep it as high as possible for as long
| as possible to insure that the field can be reached, and then slip as
| much as required to lose the excess altitude without gaining airspeed.
| Bob Moore
| Flight Instructor ASE-IA
| ATP B-707 B-727
| PanAm (retired)
| in my country the manouver I describe is always called a side slip.
| side slips are used as I indicate to dirty up the aircraft
| aerodynamically.
| they can be used to counter a crosswind but the crabbed approach is
| preferred because it doesnt change the approach profile.
| it is a side slip.
| youalls mileage may vary :-)
| Stealth Pilot
Yeah, but you're a dumb ass.
  #113
Old September 25th 08, 04:41 PM posted to rec.aviation.piloting
Mick[_2_]
| " wrote in
| On Sep 22, 5:29 pm, Bertie the Bunyip wrote:
| george wrote in news:7f5d8c7e-2345-427c-bec6-
| On Sep 23, 8:17 am, John Godwin wrote:
| That's incredible. When I took my CFI Ride, I had to demonstrate
| a maximum effort forward slip on final. Kicked out when I was
| over th
| e
| fence and hit the numbers. Seems as if your instructor didn't
| know
| the
| difference between a slip and a skid.
| A number of aircraft that I've flown do not have flaps and the
| sideslip was an everyday common maneuver .
| I found the practice was frowned upon in the modern aircraft as
| there were claims that the elevators were shielded and all manner
| of problems could develop
| Some early big flap cessnas got a little wobbly, but that's all. The
| Bird dog gets very funky when slipped with full flaps ~( 60 deg) but
| mostly it
| 's
| just another skill falling into decline because it's "too hard"
| Bertie
| I'm a student with 70 hrs and my CFI teaches slips to bleed off
| altitude, especially for engine failure practice. The only restriction
| is not to use full flaps in a 172SP. Apparently it causes too much
| vibration.
| You're one of the fortunate ones!
| Bertie
Your not, you're a dumb ass.
  #115
Old September 25th 08, 04:44 PM posted to rec.aviation.piloting
Mick[_2_]
| Gezellig wrote in news:6jsl4oF4u1b1U1
| @mid.individual.net:
| On Mon, 22 Sep 2008 06:59:34 -0700 (PDT), Gene Seibel wrote:
| Slips were in common use for bringing an aircraft down in the days
| before flaps, and were taught for that purpose when learned to fly in
| the 70's. They work very well. Is that no longer being taught?
| A power-out slip to landing? I had to beg for it.
| Your instructor was jewish?
| Bertie
I thought you were Jewish?
Bertie the Jew!
  #116
Old September 25th 08, 04:45 PM posted to rec.aviation.piloting
Mick[_2_]
| Stefan wrote in
| Mick schrieb:
| | Glider pilots use them on occasion for rapid descent and they are
| | expected to demonstrate proficiency in them on the practical exam.
| How do you maintain alignment with the tow plane?
| When *descending*? )
| BTW, some glider pilots use short slips to take up slack from the tow
| rope, should there happen to occur some in turbulence. Most prefer the
| use of airbrakes, though.
| No, they don;t fjukkktard.
| They skid.
| Bertie
You're a dumb ass. I seriously doubt you have ever flown a sailplane.
  #117
Old September 25th 08, 04:47 PM posted to rec.aviation.piloting
Mick[_2_]
| "Mick" #$$#@%%%.^^^ wrote in :
| | "Mick" #$$#@%%%.^^^ wrote in news:rb_Bk.17810$wr1.16736
| @newsfe02.iad:
| | "Jim Logajan" wrote in message
| | | Amine wrote:
| | | Now I thought that sideslips (and crabs--whatever the difference
| | | between the two is...) were only to be used to handle
| crosswinds. I
| | | didn't read anywhere that they could be used to bleed excessive
| | | speed, although it makes sense from an aerodynamics perspective.
| | | Anyone out there used sideslips for anything other than
| crosswind
| | | approaches?
| | What's it to you, you don't fly.
| | Bertie
| Prove it dumb ass.
| Don't need to.
| No more than I need to prove that you are a halfwit or that the sun will
| rise in the east tomorrow.
| Bertie
But you are good at proving you are so totally full of ****.
You're a perpetual fountain of bull****.
  #118
Old September 25th 08, 04:48 PM posted to rec.aviation.piloting
Mick[_2_]
Default Bertie's Crab, his mothers slips, and crossed legs everywhere he drools.
| | Amine wrote in news:18e46a13-6294-4b68-9775-
| | Hey,
| | Some of you may have heard of Air Canada 143
http://www.youtube.com/
| | watch?v=dfJIpA2gv1g] which ran out of fuel in mid air and had to
| make
| | an emergency descent at velocities way above the normal limits. The
| | pilot's makeshift technique was to engage a sideslip to decelerate
| the
| | aircraft (which by then had no flaps, and only minimal hydraulics).
| | between the two is...) were only to be used to handle crosswinds.
| | They're different and they aren't just used for crosswinds.
| | I
| speed,
| | although it makes sense from an aerodynamics perspective. Anyone
| out
| | there used sideslips for anything other than crosswind approaches?
| the
| | it isn't.
| | Bertie
You do a good job of being stupid.
  #119
Old September 25th 08, 04:49 PM posted to rec.aviation.piloting
Mick[_2_]
| | "RandyL" rlink(AT)cableone(DOT)net wrote in
| | Hi Amine,
| | I'll sometimes use a sideslip on final when I want to practice an
| | approach without using any flaps.
| | That's actually a forwad slip.
| | Bertie
| That's a slip.
| Like you'd know wannabe boi with a stutter
| Bertie
You are answering every post twice again, they must have upped your meds.
  #120
Old September 25th 08, 04:54 PM posted to rec.aviation.piloting
Mick[_2_]
Default Bertie's has crabs, wears his mothers slips, and crosses his legs everywhere he drools.
news:bfb42c23-8a15-4706-b1a6-
Many air show pilots use a slip to simply scrub off some altitude or
airspeed entering a show line if the entry is a bit high or fast or
both. I usually employed this in the entry turn which was almost
always a descending turn into the show line. It's quite common to see
pilots of high performance tail wheel airplanes like a Pitts for
example, using a slipping turn onto final approach, then holding in
the slip correcting the turn into a slipping transition to a short
straight slipping final.
I like to think of slips not so much as a maneuver per se, but simply
an application of diliberate crossing of controls to achieve a
specific result from the airplane. In other words, a slip should be
considered as much of the pilot's normal control application as any so
called "coordinated" input of controls.
And of course you would know that, because you are an aviation legend.
Slips and skids William Hung[_2_] Piloting 25 March 17th 08 02:27 AM
slips to landing in PTS BB Soaring 6 April 17th 07 05:58 AM
Slips and spins in FSX? Chris Wells Simulators 0 December 14th 06 08:24 PM
A reluctance to take the controls Jay Honeck Piloting 161 December 1st 06 08:27 PM
About forward slips Mxsmanic Piloting 77 November 2nd 06 11:35 PM
