Preflighting my plane - Video
Old September 26th 08, 09:25 PM posted to rec.aviation.piloting
john smith
Default Preflighting my plane - Video
In article 8ac82ae29a700@uwe,
"Kloudy via AviationKB.com" u33403@uwe wrote:
I Haven't flown an airplane for around 20+ years but I remember most of the
preflight procedure from memory. One thing we did was after taking the fuel
sample, we would chuck it out on the ground.
You make reference to EPA's take on that.
I'm certain there are recommendations against- if not outright prohibitions
on tossing fuel on the ground nowadays.
What are current approaches to fuel sample disposal and such.
Fuel at $8.00+ per gallon is too precious to "chuck on the ground".
There is a device known as a Gatt Jar that one holds up to the sump to
drain a fuel sample. The top of the Gatt Jar has a lid with a fine mesh
strainer, which is attached to a large (0.5 l) plastic bottle to hold
the fuel. The fuel is then poured back into the tank through the filler
cap.
Some states have environmental laws against "chucking it on the
ground"due to the lead content and potential contamination.
Old September 26th 08, 09:41 PM posted to rec.aviation.piloting
I haven't found anything on the web about gatt jar and aviation fuel.
How does potential water contamination get separated?
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200809/1
Old September 27th 08, 10:45 PM posted to rec.aviation.piloting
john smith
In article 8ac9263a27232@uwe,
http://www.sportys.com/acb/showdetl....roduct_id=1821
This fuel tester allows you to put preflight fuel samples back into your
airplane (a great alternative to tossing sampled fuel onto the ground: a
practice now discouraged by the EPA). Sample and check your fuel as
always. Then, as sampled fuel is returned to the tank, a unique,
built-in screen separates solids and non-petroleum contaminants, so only
clean, pure fuel is returned to the tank. Reversible sump actuator fits
both pin and petcock actuators. Wide mouth collector helps protect hands
and clothing. Resilient plastic construction makes the GATS Jar
virtually indestructible with normal handling.
Plane 172 fun video [email protected] Piloting 23 February 2nd 08 01:59 AM
Video of building a plane in the air Jim Logajan Home Built 1 November 20th 06 10:43 PM
Video from the plane Jacob Olsen Soaring 6 December 16th 05 05:23 PM
A Plane is Born Video FLYWITHJAY Home Built 0 July 17th 04 02:27 PM
Preflighting has changed for ever! Robert M. Gary Piloting 9 March 31st 04 08:20 PM
