On Sep 27, 2:57*pm, JJ Sinclair wrote:
Alas, yes they both require old fashioned dial altimiters. With todays glass cockpits, I'm wondering if this requirement isn't outdated? JJ JJ - Can you, or anyone else, reference a regulation on altimeters that includes the word DIAL. 91.205.b.2) requires for VFR flight an "altimeter" 91.205.d.5) requires for IFR flight "a sensitive altimeter adjustable for barometric pressure". Neither requires a dial and neither requires a mechanical instrument. Andy |
On Sep 27, 3:51*pm, Andy wrote:
On Sep 27, 2:57*pm, JJ Sinclair wrote: Alas, yes they both require old fashioned dial altimiters. With todays glass cockpits, I'm wondering if this requirement isn't outdated? JJ JJ - Can you, or anyone else, reference a regulation on altimeters that includes the word DIAL. 91.205.b.2) *requires for VFR flight an "altimeter" 91.205.d.5) requires for IFR flight "a sensitive altimeter adjustable for barometric pressure". Neither requires a dial and neither requires a mechanical instrument. Andy I am also building a homebuilt sailplane and talked with the DAR (designated airworthiness representative) about the instrumentation. The answer I got was that it's pretty much up to him. I can have a compass out of a child's toy if that's what I want and he's willing to sign it off. Ditto for most of the other instruments. |
Good point, Andy.....................maybe we can use one of the many
altitude displays available. As you may have guessed, I removed the big dial altimeter about a year ago when I installed a transponder. I set field elevation on the SN10 which is on the first (custom) page and set-up to be displayed at twice normal height. When not otherwise being used I leave the black cursor on altitude.................works like a charm! Yes, my flight manual says I need an altimiter approved for use on certified aircraft, but it also says I must use the Prandtl tube, but I'm using a triple probe instead. The guy that's sign'n off my annual condition inspections doesn't sweat the little stuff. JJ Andy wrote: On Sep 27, 2:57�pm, JJ Sinclair wrote: Alas, yes they both require old fashioned dial altimiters. With todays glass cockpits, I'm wondering if this requirement isn't outdated? JJ JJ - Can you, or anyone else, reference a regulation on altimeters that includes the word DIAL. 91.205.b.2) requires for VFR flight an "altimeter" 91.205.d.5) requires for IFR flight "a sensitive altimeter adjustable for barometric pressure". Neither requires a dial and neither requires a mechanical instrument. Andy |
Looking for TSO Altimeter | Rob Turk | Home Built | 0 | June 9th 07 03:52 PM |
Direct dial FSS phone numbers being suggested as work-around to long hold times | Peter R. | Piloting | 3 | May 15th 07 01:16 PM |
ADV: Please Dial Up My New Aviation Gear E-Store! | Kates Saloon and Knife Emporium | Products | 0 | January 18th 04 06:40 AM |
