Does the best ROC indicated airspeed change with the engine and prop
upgrade? If it did and you are flying the old numbers, perhaps that is affecting your performance. Regards, Mike. http://flickr.com/photos/mikenoel/ http://photoshow.comcast.net/mikenoel wrote in message ... Hey all. As some of you may recall, about a year ago I posted a question regarding two different power loss issues I was having with my PA-28-140 with an O-360-A4A 180hp upgraded engine. I'll summarize what's transpired and figure to get some opinions on what I might try next. Basically, I had an intermittent slightly low power on about 1 in 25 takeoffs. Not enough to make you abort, but enough to realize upon climbout that it wasn't quite doing what it usually did in terms fo FPM. Never rough, did mag checks, fuel pressure good, EGT correct, CHT correct, etc, etc... just a little low on power, and after a minute or so it would quietly come back. After checking cam lift and lifters, etc, I realized that the dry tappet clearance was too much on about 5 of the 8 pushrods. I fixed that, and the problem has not come back after a year. The *other* problem is that this engine has never been very strong. It's always been barely able to make the minimum static RPM required by the TCDS, and climbs out at about 2400 RPM at Vy. This problem persists.... it feels more like a -160 than a -180 and I've checked all sorts of things that would be common: - Compressions great... 78/80-80/80 on all four chrome cylinders. No hissing out exhaust or crankcase. - Mags internally timed when we replaced the points and condensers, and externally set at 25 degrees as per spec - Does it with new plugs. - Manifold pressure (added as part of the engine upgrade and measured at the intake port on #3) is good for full-power takeoff... about 1-1.5" or so less than the ambient pressure (e.g. 30.00 altimeter here at 2100' MSL airport gives me about 26.5-27" MP on takeoff) - EGT reads 1350 on all cylinders at full rich, so it's not starved for fuel. - Fuel pressure stays at 3-4 psi. - Does it on 100LL or 93 AKI cargas or any mixture of the two. - Did the "wobble test" SB on the valves. Acceptable, although somewhat worn. - Brand new exhaust system... no change - Measured cam lift last year... all lobes show 0.353" +- 0.002"... not a worn cam as that's the same as a friend's brand new Superior cam. - Propeller is stock, 60" pitch and brand new when we got the plane. I believe it's 60" as other than full-power, the POH is dead-balls on as far as airspeed and fuel burn are concerned. Any other pitch prop and those wouldn't be right. SO.... my thinking is this. I was skeptical that the dry tappet clearance could affect the intermittent power problem, since the hydraulic lifters should be able to compensate for this while running. I appeared to be in error as fixing the dry tappet clearance to spec seems to have cleared this up (took me a year to really believe that). The original overhaul on this engine happened before we bought it was definately a field overhaul... probably more or less a "service limits" overhaul. Any chance that if the lifters are mismatched from a shoddy overhaul that they'd bleed down too quickly and cause a chronic low power from insufficient valve lift? If I could buy a new set of lifters to fix the problem, I'd be a happy guy! Any other ideas to entertain? I'm open to suggestions... this has been p*ssing me off for literally *YEARS*! Thanks, -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D. Electrical Engineering, PPSEL-IA * * Research Associate, Vibrations and Acoustics Laboratory * * Mechanical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Mike Noel wrote:
: Does the best ROC indicated airspeed change with the engine and prop : upgrade? If it did and you are flying the old numbers, perhaps that is : affecting your performance. : Regards, : Mike. Nope... it didn't change with the upgrade. A -180C POH is what was included with the engine upgrade (performed by the previous owner 15 years ago, BTW), and that's what I'm following. Again though... it's not just aerodynamic results that indicate low power, although there are plenty of those: - ROC of ~500-600fpm at my max of 2200#. A stock -180 at 2400# is listed as 750... at 200lbs MORE weight - Takeoff run probably ~20% longer than the book values... again at 2200# - Top speed is about 8 mph less than book value (corrected for DA) - WOT RPM at top speed is about 150 RPM below the book "max speed" curve. The static RPM is also consistent with being probably 10-20 HP less than 180. Oh, and before anyone asks, I've checked the tachometer for accuracy with a strobe, and overhauled/calibrated the ASI and VSI, and have no leaks in the pitot or static system. Cheers, -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D. Electrical Engineering, PPSEL-IA * * Research Associate, Vibrations and Acoustics Laboratory * * Mechanical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Query on Geo Pilot GPS | Mike Isaksen | Piloting | 7 | August 8th 07 02:38 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 07:50 PM |
Tool query... | Tina Marie | Owning | 2 | July 15th 04 05:20 AM |
A query | news | Military Aviation | 2 | October 18th 03 04:27 PM |
