Paul Dow (Remove Caps in mail address) wrote:
(So no explosives, please!) Thanks, Paul How do expect any help if you tie our hands? |
Gig 601Xl Builder wrote:
Paul Dow (Remove Caps in mail address) wrote: (So no explosives, please!) Thanks, Paul How do expect any help if you tie our hands? "There are very few of man's problems that can't be solved by the proper application of the appropriate explosives." - Ragnar "oops" Benson Dan, U.S. Air Force, retired |
![]() "Dan" wrote in message ... "There are very few of man's problems that can't be solved by the proper application of the appropriate explosives." - Ragnar "oops" Benson "Blo-Jell ! The plastic explosive you use at home. Great for those pesky stuck window frames; better than a string and a doorknob for removing Junior's loose tooth" (As remembered from the Prairie Home Companion show) Vaughn |
Vaughn Simon wrote:
"Dan" wrote in message ... "There are very few of man's problems that can't be solved by the proper application of the appropriate explosives." - Ragnar "oops" Benson "Blo-Jell ! The plastic explosive you use at home. Great for those pesky stuck window frames; better than a string and a doorknob for removing Junior's loose tooth" (As remembered from the Prairie Home Companion show) Vaughn I prefer hand grenades. They can be used for fishing, removing walls from fingerprints, getting your neighbour to stop mowing the lawn too early..etc. Hand grenades are also very effective for painting rooms. One opens a can of paint, places it on the floor in the geometric centre of the room, pulls the pin from the grenade, drops it into the, vacates the room, and voi ci, a painted room. Dan, U.S. Air Force, retired |
Oil in cylinder, other cylinder issues | Robert M. Gary | Piloting | 7 | May 27th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Owning | 8 | May 27th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Jim Burns[_3_] | Owning | 2 | May 24th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Piloting | 0 | May 23rd 07 10:44 PM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Owning | 0 | May 23rd 07 10:44 PM |
