On Sat, 20 Dec 2003 15:41:47 GMT, Ed Rasimus
wrote: On Sat, 20 Dec 2003 09:31:05 GMT, Scott Ferrin wrote: In this month's "Combat Aircraft" there is an article on the F-22 and in it one of the people invloved in flight testing says "Flying at the edge of the envelope pushes this aircraft harder than any operational F/A-22 will ever be pushed." Is that hyperbole? There are instances in the past where aircraft have gone FAR beyond the brochure numbers. So do they go *beyond* the brochure numbers or are they saying they go to the typical +9 -3 g's and the flight system prohibits anything more? Obviously they aren't going to test it to failure in *flight* but every componant has a design spec and a safety factor. Do they go *beyond* spec but not beyond the safety factor? Just curious. The "envelope" is a lot more than simple structural limits. Flight test is an extended process of gradually expanding the allowable operating limitations of the system. First flights, for example, often are done without cycling the landing gear, IOW, a takeoff, low speed climb to altitude and basic exploration of approach and landing airspeed. As testing proceeds, airspeed, bank angles, altitudes, AOA ranges and accelerations are expanded. Pushing the envelope involves moving those lines on the performance charts gradually outward to expand the capabilities of the airframe. As for structural limits, those are typically explored to failure in static ground tests. They used to have a big hangar down at Eglin (probably at Edwards as well) that they would load up an airframe and keep increasing the load until flex limits or destruction. Fascinating stuff. Yeah, on one of those Discovery shows they showed either a 747 or 777 wing being bent to failure. It was quite a bang. It didn't bend, it pretty much blew apart. Then I remember reading that the machine that was testing the that box-like structure the wings attach to on the Tomcat busted before the Tomcat did. Neat stuff. |
Scott Ferrin wrote:
Ed Rasimus wrote: The "envelope" is a lot more than simple structural limits. Flight test is an extended process of gradually expanding the allowable operating limitations of the system. First flights, for example, often are done without cycling the landing gear, IOW, a takeoff, low speed climb to altitude and basic exploration of approach and landing airspeed. As testing proceeds, airspeed, bank angles, altitudes, AOA ranges and accelerations are expanded. Pushing the envelope involves moving those lines on the performance charts gradually outward to expand the capabilities of the airframe. As for structural limits, those are typically explored to failure in static ground tests. They used to have a big hangar down at Eglin (probably at Edwards as well) that they would load up an airframe and keep increasing the load until flex limits or destruction. Fascinating stuff. Yeah, on one of those Discovery shows they showed either a 747 or 777 wing being bent to failure. It was quite a bang. It didn't bend, it pretty much blew apart. Then I remember reading that the machine that was testing the that box-like structure the wings attach to on the Tomcat busted before the Tomcat did. Neat stuff. Neat stuff, indeed. In fact, coinciding with the 100th anniversary of the world's first powered, heavier-than-air flight, an exciting new chapter in flight testing standards is being written as we speak. Given the amazing success of Unmanned Combat Air Vehicles (UCAV's) such as Predator and Global Hawk, the aviation industry is currently working on flight testing standards for these unmanned aircraft that are very similiar to those Ed described above for manned aircraft. The FAA has acknowledged the stunning growth of ultralight aircraft in recent years and has found those of us involved in ultralights to be a valuable resource for flight testing standards of pilotless military and civilian aircraft. The goal is to allow unmanned military and civilian airplanes to safely fly into the National Airspace System in the near future. As I mentioned above, flight testing an ultralight is not unlike flight testing a sophisticated military jet. Once the design is finalized, it has to conform to a given standard. For an ultralight, this means it has to be loadtested to 6-G positive and 3-G negative. Flight tests are also performed and documented. Some of the flight tests include longitudinal stability tests, takeoff performance, gradient of climb, dynamic stability, descent rate and landing distance. All are done minimum/maximum weights and at the different center of gravity positions available. Several load tests must be performed in both positive and negative. The limit load test must show that the wing is able to be held off the ground indefinitely without suffering any permanent deformation (the positive limit test on one wing I flew showed a measured load of 3,671 pounds). For example, here are the calculations for the 6-G positive load test on the example I flew: Aircraft, pilot, and passenger weight (less wing) =882 pounds Multiplied by 6 = 5,292 pounds Add wing at test weight = 105 pounds Load to be applied = 5,397 pounds The load has to be applied to a specific distribution which is laid out by the controlling authority (e.g: the FAA). An aeronautical engineer must witness the testing as is the signatory on the documents. A grid reference is drawn onto the wing. In this way the load can be applied exactly according to the standard. Bags loaded with steel ball bearings are used for the load. The bags have Velcro sewn in as does the sail on the wing in order to prevent the bags from sliding off as the wing is lifted. For the positive load test, the wing is placed on the ground upside down or undersurface up. A forklift is used to lift the wing from the point where it normally attaches to the fuselage. A calibrated load cell is used to measure the load (the measured load usually varies slightly from the applied load). In the case of the wing I tested in the example above, the final measured load for the ultimate positive test was a whopping 5,345 pounds (remember, the wing only weighed 105 pounds so you can imagine just how strong modern ultralight wings are!) The wing must be lifted completely off the ground and held for more than three seconds remaining intact. I've seen photos of other wings that have literally exploded like the Boeing 747 or 777 wing you mentioned above so if you fly a certified ultralight these days you can fly with confidence knowing that the wing has been thoroughly tested just like the wings the military and the "big boys" fly. |
![]() "Mike Marron" wrote in message ... Scott Ferrin wrote: Ed Rasimus wrote: The "envelope" is a lot more than simple structural limits. Flight test is an extended process of gradually expanding the allowable operating limitations of the system. First flights, for example, often are done without cycling the landing gear, IOW, a takeoff, low speed climb to altitude and basic exploration of approach and landing airspeed. As testing proceeds, airspeed, bank angles, altitudes, AOA ranges and accelerations are expanded. Pushing the envelope involves moving those lines on the performance charts gradually outward to expand the capabilities of the airframe. As for structural limits, those are typically explored to failure in static ground tests. They used to have a big hangar down at Eglin (probably at Edwards as well) that they would load up an airframe and keep increasing the load until flex limits or destruction. Fascinating stuff. Yeah, on one of those Discovery shows they showed either a 747 or 777 wing being bent to failure. It was quite a bang. It didn't bend, it pretty much blew apart. Then I remember reading that the machine that was testing the that box-like structure the wings attach to on the Tomcat busted before the Tomcat did. Neat stuff. Neat stuff, indeed. In fact, coinciding with the 100th anniversary of the world's first powered, heavier-than-air flight, an exciting new chapter in flight testing standards is being written as we speak. Given the amazing success of Unmanned Combat Air Vehicles (UCAV's) such as Predator and Global Hawk, the aviation industry is currently working on flight testing standards for these unmanned aircraft that are very similiar to those Ed described above for manned aircraft. The FAA has acknowledged the stunning growth of ultralight aircraft in recent years and has found those of us involved in ultralights to be a valuable resource for flight testing standards of pilotless military and civilian aircraft. The goal is to allow unmanned military and civilian airplanes to safely fly into the National Airspace System in the near future. As I mentioned above, flight testing an ultralight is not unlike flight testing a sophisticated military jet. Once the design is finalized, it has to conform to a given standard. For an ultralight, this means it has to be loadtested to 6-G positive and 3-G negative. Flight tests are also performed and documented. Some of the flight tests include longitudinal stability tests, takeoff performance, gradient of climb, dynamic stability, descent rate and landing distance. All are done minimum/maximum weights and at the different center of gravity positions available. Several load tests must be performed in both positive and negative. The limit load test must show that the wing is able to be held off the ground indefinitely without suffering any permanent deformation (the positive limit test on one wing I flew showed a measured load of 3,671 pounds). For example, here are the calculations for the 6-G positive load test on the example I flew: Aircraft, pilot, and passenger weight (less wing) =882 pounds Multiplied by 6 = 5,292 pounds Add wing at test weight = 105 pounds Load to be applied = 5,397 pounds The load has to be applied to a specific distribution which is laid out by the controlling authority (e.g: the FAA). An aeronautical engineer must witness the testing as is the signatory on the documents. A grid reference is drawn onto the wing. In this way the load can be applied exactly according to the standard. Bags loaded with steel ball bearings are used for the load. The bags have Velcro sewn in as does the sail on the wing in order to prevent the bags from sliding off as the wing is lifted. For the positive load test, the wing is placed on the ground upside down or undersurface up. A forklift is used to lift the wing from the point where it normally attaches to the fuselage. A calibrated load cell is used to measure the load (the measured load usually varies slightly from the applied load). In the case of the wing I tested in the example above, the final measured load for the ultimate positive test was a whopping 5,345 pounds (remember, the wing only weighed 105 pounds so you can imagine just how strong modern ultralight wings are!) The wing must be lifted completely off the ground and held for more than three seconds remaining intact. I've seen photos of other wings that have literally exploded like the Boeing 747 or 777 wing you mentioned above so if you fly a certified ultralight these days you can fly with confidence knowing that the wing has been thoroughly tested just like the wings the military and the "big boys" fly. Interesting process Mike. Reminds me of a while back when Bellanca was demonstrating their Super Viking at some of the shows we were flying. Bellanca has always been known (at least until they had a major AD on the Decathlon's spar anyway :-) for fantastic strength in their airframes. They had apparently hired a bunch of professional Sumo wrestlers. They had these people standing on the wings from the root to the tail as the airplane stood on the ramp behind the guy telling everyone how strong the Viking was .. Very effective sales technique....although I don't remember anyone buying the exact airplane they were using for the demo :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
(UCAV's) such as Predator and Global Hawk Neither are *true* UCAV since neither was designed to employ weapons. The Predator has been modified to carry a single (or is it a pair?) Hellfire(s), but that still doesn't make it a UCAV. BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
It was a 777 and the wing bent something on the order of 28 feet before
failure. 28 feet...ahhh, that's nothin' ![]() BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
