On Oct 2, 9:41*am, Jerry Wass wrote:
wrote: On Oct 1, 11:29 am, "Paul Dow (Remove Caps in mail address)" wrote: Does anyone have a technique to get the piston out? Preferably while doing the least amount of damage. (So no explosives, please!) ---------------------------------------------------------------------------*---------------------- I don't see any easy-out for this one. I assume you're willing to sacrifice the piston in order to salvage the cylinder, in which case you might try soaking the piston with liquid nitrogen or other cryogenic that should allow you to shatter the piston along the ring-groove. Depending on how much of the upper portion of the piston is obscured by the wrist pin, you might consider fabricating a fixture of some sort bearing a number of high-gauss rare-earth magnets, the idea being to cause the ring to be drawn back into its groove whilst the assembly is under tension. In a similar vein, the suggestion about using the piston to remove the cylinder liner would appear to have merit. *You should be able to rig the assembly so as to create considerable tension between the cylinder and the piston. *The manual should give you some idea as to the required temperature difference, which would be obtained by raising the whole assembly to a given temperature then hitting the piston AND liner with liquid nitrogen. -R.S.Hoover This idea is the best so far--I would recommend hanging the assy. by the rod, and attaching heavy weight to cyl head.. Then apply heat to barrel of Cylinder. I keep some old Coleman thermos bottle liners (vacuum bottles) then go out to propane storage tank, crack the liquid line ,and after the valve & line has chilled, introduce *liquid into vacuum bottle...Careful-- the temp is -42°C-(-62°F)AND of course the vapor is highly flammable,and 1.5 times as dense as air--so it settles in low places. Extinguish all fires & pilot lights---WEAR GOGGLES---The liquid will boil violently upon contact with the hot metal---You have to do this when you live 50 miles from Mr.Linde--& he might not have any liquid N2 that day anyhow.. Jerry- Hide quoted text - - Show quoted text - Is there any reason why the pistons head can’t be drilled out and an insert fabricated to slip inside it through the top for use as a puller? You can use a chemical fire extinguisher to super cool the cylinder head for shrinkage and then follow up with a series of sharp pulls to extract the piston. If the piston shatters then remove it, or its top pulls loose than fabricated another top insert to friction fit inside the piston walls and try the whole chill/pull process again. Of course this is just my .02 worth folks along with the admonition that I’m more of a parts changer than mechanic. Joe Stevenson |
How to Remove Piston from Cylinder | Paul Dow (Remove Caps in mail address) | Owning | 20 | October 6th 08 10:01 PM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Owning | 8 | May 27th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Jim Burns[_3_] | Owning | 2 | May 24th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Piloting | 0 | May 23rd 07 10:44 PM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Owning | 0 | May 23rd 07 10:44 PM |
