Charles Vincent wrote:
There are also several acids that will attack steel and not aluminum. I have used that dodge many years ago to remove a busted tap from an aluminum part that I had a lot of time invested in. I used plain battery acid that time, but I think I recall that nitric acid could work better. This would likely attack the valve seats and liner, but would not harm the head or piston. You would want to degrease everything before trying the acid. On reflection, forget I said that. To much risk that the acid would have some long term effect and I simply don't know enough about it to recommend it for an aircraft part. Charles |
How to Remove Piston from Cylinder | Paul Dow (Remove Caps in mail address) | Owning | 20 | October 6th 08 10:01 PM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Owning | 8 | May 27th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Jim Burns[_3_] | Owning | 2 | May 24th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Piloting | 0 | May 23rd 07 10:44 PM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Owning | 0 | May 23rd 07 10:44 PM |
