How to Remove Piston from Cylinder
Old October 3rd 08, 04:53 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Walter Kronester[_3_]
Default How to Remove Piston from Cylinder
Hi Paul,
do you know this document, mainly the drawing around page 2-40 or at 2-35?
http://www.franklin.ioi.pl/dokumenty...ts_Catalog.pdf
http://www.franklin.ioi.pl/dokumenty/IPC_4A235_B4.pdf
It seems the cylinder liner can be pulled if the lock pin is removed.
Much luck
Walter
Old October 6th 08, 04:22 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Paul Dow (Remove Caps in mail address)
Hello Walter,
Thank you for that link. I wasn't aware that it is on the web. My friend
didn't have the parts manual. He does have the 6 cylinder model, so that
information should be very useful to us.
Also, it looks like your posting did appear in the newsgroup. I think
some newsgroup servers don't update very quickly.
It looks like the messages on the newsgroup have migrated to a
discussion about explosives now :-)
Paul
Walter Kronester wrote:
Hi Paul,
Much luck
Walter
Old October 6th 08, 10:01 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Dan[_12_]
Paul Dow (Remove Caps in mail address) wrote:
Hello Walter,
Paul
You say that like it's a bad thing. Explosives can come in handy.
Example your starter dies, hand propping isn't working and you want to
crank the engine, just remove a spark plug, put a handful of black
powder in the cylinder, insert fuse and rag to act as a plug, light fuse
and hop in. Explosives can also be used for emergency tire inflation.
Dan, U.S. Air Force, retired
Old October 7th 08, 02:22 AM posted to rec.aviation.homebuilt
Tech Support
Hello Walter,
Paul
Dan
Why can't you put in cylinder and use plug to light off????
Big John
Old October 7th 08, 03:55 AM posted to rec.aviation.homebuilt
Dan[_12_]
Hello Walter,
Paul
Dan
Big John
I'm assuming the think won't turn over in the first place. If it can
be turned enough to obtain a spark one can add saltpeter, sulfur,
aluminum powder and confectioner's sugar in the proper proportions if
one is out of black powder. Not that I know anything about the
particulars, you understand.
Old October 8th 08, 06:13 AM posted to rec.aviation.homebuilt
Tech Support
Hello Walter,
Paul
Dan
Big John
Dan
As a teenager I used potasum clorate and sulpher.
Poured a spot on cement and kicked with heel plate and went off.
Also put in a CO2 cartridge and set off with home made fuse. Made a
powerful rocket (half a city block).
How I ever survived growing up I don't know looking back.
Big John
Old October 8th 08, 07:26 AM posted to rec.aviation.homebuilt
Dan[_12_]
Hello Walter,
Paul
Dan
Big John
Dan
Big John
Looking back I can see several occasions where I should have been
injured or killed with some things I did. I proved launching a plastic
model Saturn V is possible with off the shelf C engines. I also proved
that didn't include going in the intended direction.
How to Remove Piston from Cylinder Paul Dow (Remove Caps in mail address) Owning 20 October 6th 08 10:01 PM
Oil in cylinder, other cylinder issues Robert M. Gary Owning 8 May 27th 07 05:26 AM
Oil in cylinder, other cylinder issues Jim Burns[_3_] Owning 2 May 24th 07 05:26 AM
Oil in cylinder, other cylinder issues Robert M. Gary Piloting 0 May 23rd 07 10:44 PM
Oil in cylinder, other cylinder issues Robert M. Gary Owning 0 May 23rd 07 10:44 PM
