asymetric warfare
Old December 20th 03, 06:11 PM
phil hunt
On Thu, 18 Dec 2003 22:25:54 +0000, Paul J. Adam wrote:
In message , phil hunt
writes
On Thu, 18 Dec 2003 05:26:01 GMT, Kevin Brooks wrote:
That is way beyond even our capabilities. You are talking autonomous combat
systems.
Yes. The progrsamming for this isn't particularly hard, once you've
written software that can identify a vehicle (or other target) in a
picture.
Falling off a cliff isn't a problem once you've learned how to fly like
Superman.
Trouble is, that prerequisite is harder than you might expect.
Getting a machine to tell a T-72 from a M1A1 from a Leclerc is hard
enough in good conditions
You don't have to. You have to be able to tell whether it's a
vehicle or not, and if it is, is it in an area likely to be occupied
by own forces.
: doing so in the presence of camouflage,
obscurants and when the crew have run out of internal stowage (so have
hung lots of external gear) and maybe stored some spare track plates on
the glacis front ('cause they need the spare plates and they might as
well be extra armour) gets _really_ tricky. Do you err on the side of
"tank-like vehicle, kill!" or "if you're not sure don't attack"?
I'd tend to err towards the former. note that it's a lot easy to
spot a moving vehicle than a stationary one.
Would it not be embarrasing to have a successful armoured raid broken up
by your own missiles?
Indeed. Maybe some form of IFF?
Key problem is that going up against the US loses you your comms and
observation
I doubt that that is true, assuming a competent comms network.
DR is patchy at best unless you've got good inertial guidance systems
(non-trivial). Celestial only works on clear nights
Or during daytime.
- so you're limited
to fighting wars after dark on cloudless nights with no flares in the
sky. LORAN is a radio broadcast and therefore not survivable against a
US-style opponent.
If you have lots of transmitters, many of which are dummy
transmitters, and many of which are only turned on for a short time,
using frequency hopping, it's rather harder to destroy the network.
or up high where the view is better,
It's possible that a mission might require some of the flight to be
at high level and some at low level. I imagine the missiles could
be programmed for a mission by sticking a computer with an Ethernet
cable into a slot on the missile.
This has only been done for twenty years or so in the West, so hardly a
great advance.
I never said it was; it is merely the obvious way to do it.
"It's easier to find people online who openly support the KKK than
people who openly support the RIAA" -- comment on Wikipedia
(Email: , but first subtract 275 and reverse
the last two letters).
Old December 20th 03, 10:33 PM
Paul J. Adam
writes
On Thu, 18 Dec 2003 22:25:54 +0000, Paul J. Adam news@jrwlyn
by own forces.
#1 sounds easy until the enemy starts deploying decoys and disguising
targets. #2 still requires not only significant navigation, but some
noticeable amounts of real-time intelligence gathering and
communication.
_Someone_ has to reliably determine whether the 'US tanks to our front!'
message is a feint, a hasty raid or the real invasion; work out where
those tanks will be by the time the missiles arrive: and reliably get a
message back to the launch unit. This has to be reasonably proof against
deception, EW, jamming, and blunt attack.
More to the point, it rules out most resistance and makes life for
refugees short and nasty, since "general area of enemy forces" will
contain both own forces trying to fight (unless these missiles are your
only resistance) and civilians fleeing.
Own forces retreating and fleeing refugees make equally good targets. Of
course, you can implement "this way = friendly, that way = enemy" logic,
but then if the US is retreating or your own forces advancing when the
missiles arrive...
If you can get the IFF feature robust, reliable and not compromising own
forces for under $10k per missile, let everyone know!
observation
Landline telephone need landlines and exchanges, easily targeted.
Cellular telephone needs masts and repeaters, ditto. Broadcast radio is
vulnerable to jamming, eavesdropping and spoofing (or simply "bomb the
emitter".
A comms infrastructure that is robust, secure, and prompt is not easy
even for the UK or US to guarantee, let alone a Third World nation under
attack by opponent(s) with air superiority.
Or during daytime.
And if it's cloudy? Or can you only fight in good weather?
- so you're limited
US-style opponent.
You'll run out of transmitters before the US runs out of weapons. LORAN
needs _large_ transmitters and that makes it a lot easier to simply
blast everything that looks like a LORAN station.
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old December 20th 03, 11:12 PM
George William Herbert
Paul J. Adam wrote:
phil hunt writes
by own forces.
targets.
They have to deploy good-enough decoys forwards with the
advancing troops. Consider for a moment how hard it would
have been for the US to get significant quantities of good
decoys forwards of the Kuwaiti border by T+4 hrs.
communication.
A kill box from thirty kilometers north of the Iraqi border
with Kuwait, going twenty kilometers south of that border,
by T+4 hrs after the US Army breached the border, nine months
ago, would have worked quite well.
A massive invasion, and anything of regimental strength or more
is going to count, is hard to hide. The details of how far and
how fast the front line has moved may be more opaque, but any
serious attack has very real limitations on how fast it can
roll out. One can easily posit kill box limits which are
very easy to justify and will suffer very little blue-on-blue
for the defender. And more to the point, will do far more
damage than any remaining defender forces in those boxes,
and the oncoming attack will presumably wipe those forces
out promptly.
The timing and positioning of the box may require not targeting
your own FEBA of effective resistance, and not targeting the
leading invasion echelons. But that doesn't matter. It took
days for the US forces to finish crossing the border into Iraq.
Kill boxes with the description I gave would have been valid
for much more time than is needed to set up and execute the
cruise missile attack starting.
This depends on the geography. Not many Iraqi civilians were in
the kill boxes I specified above.
emitter".
We have two types of communications that have to happen successfully,
plus a decision loop.
The reports of the invasion have to make it back to the designated
authority over the missile firings. As stated earlier, it's very
hard to credit any scenario under which it takes even twelve hours
for a country to know the US has invaded.
Then the leader has to make up his mind to fire some or all of the
cruise missiles.
Then the word has to make it back out to the missile sites.
Even without good landlines, the word getting out to the missile
sites doesn't have to be any more sophisticated than an emergency
action message. A single code word, which shifts over time, may be
enough. To suggest that the US can reliably disrupt significant
two way communications is no leap. To suggest that we can reliably
prevent *any* communications, even a broadcast one way message
which can be very brief, is unrealistic.
-george william herbert
Old December 21st 03, 01:20 AM
enough.
Yes, you are correct, many of these things are *conceptually* simple.
But moving from concept to execution, even without the overkill
practiced by the West, contains many hidden and non-obvious snags.
For a 'simple EAM' to work, you need a system manned 24/7. If you
don't want to do that, you need a reliable way of 'pre-alerting' your
forces to stand-to. You need to securely create, distribute, and
store the code words. (And an alternate supply of the same in case of
compromise.) You need to procure, supply (spares), train, test, and
maintain the individual components as well as the whole system. (And
complicating the whole affair in many third tier nations are political
issues.)
It is doable, probably even on the cheap, but if you want a useful
system you cannot skimp on the details.
It's made a lot simpler by the operational environment;
an ICBM strike really could come out of the blue, but a divisional
strength US Army invasion is not going to suprise anyone.
The 24/7 requirement only applies to known crisies.
That said, you have to have the capability to operate on that
basis, with those fundamental system capabilities and reasonable
reliability. It doesn't need to be 100%, if you have tens of
thousands of cruise missiles... some firing late is not going
to be the sort of disaster that ICBM partial failures to launch
on warning or partial failures to launch in a pre-emptive first
strike would be.
Doing it on the cheap is probably doable. Doing it on the stupid
would leave it vulnerable to US breaking the command and control
system down.
Old December 21st 03, 10:38 PM
Paul J. Adam
In message , George William Herbert
writes
targets.
As compared to deploying significant quantities of main battle tanks,
infantry fighting vehicles, and the _major_ logistics needed to support
them? If you can do that, adding decoys isn't that bad.
communication.
Hindsight is 20/20.
Again, are you assuming the enemy will be unresisted and your missiles
are the only defence?
Think back to Desert Sabre - if you'd launched your missiles at the
Kuwaiti border, you'd have inflicted casualties but completely missed
the main thrust.
The idea of "don't give the enemy easy DFs" is hardly new.
"US tanks overrunning our position, they're killing everyone, we can't
stop them!" is about all you'll get. Is that a raid on an outpost or the
main thrust smashing through your main line of resistance? (Given a
dependence on 'kill anything vehicle-like' missiles, do you even _have_
a MLR?) How long do you have to decide, given the time of flight of
these postulated missiles and how fast US forces can move when
unopposed? Killing some of their logistics will hurt, but having the
troops flying their flag over your palace be tired and hungry isn't much
of a victory.
roll out.
True, but then missiles have flyout times too, and the further they are
from their target the longer that is.
for the defender.
Equally, that will waste many munitions in fruitless combing of
target-devoid terrain.
out promptly.
The problem with this scenario is that it makes more conventional
resistance suicidal since the lethal drones will kill indiscriminately.
How do you intend to fix your foe for other arms to kill?
The previous conflict was over in 96 hours, from first border breach to
ceasefire.
They wouldn't be war-winners either.
Not many countries are as blessed in their geography and politics as
Iraq was in OIF. Iraq was nowhere near as fortunate in Desert Sabre.
emitter".
Sure. Now, _where_ have they invaded? Where's the focus of effort and
what's a diversion? "Enemy troops overrunning us!" is not a great guide
as to where the key point is, to say nothing of where it will be.
Desert Sabre is a good example. So is Overlord, with the Wehrmacht
dismissing Normandy as a diversion because Patton is going to lead a
huge army across the Dover Strait Really Soon Now.
And this is before feints are used to find out what gets broadcast on
what frequencies, and deception is used to put false messages out.
Can the US reliably, completely and reliably deny this link? No. Can it
make it too risky to stake the defence of the People's Republic on? Yes.
cruise missiles.
enough.
Provided you have a clear and unambiguous target. If you don't, you need
_lots_ of codewords because you'll have a lot of "4th, 7th and 12th
Regiments, launch one unit of fire each at a 50 x 50km box centred on
Grid 123456; 1st, 2nd, 9th and 14th make ready one unit of fire, other
regiments disperse and camouflage" type codes. Which all need to be
promulgated and must not be compromised. Not impossible, but not immune
to espionage either.
True, but that suggests that there's no intelligence and no warning. And
the US doesn't have to completely block that link... just make it
unreliable in combat. The defenders need it to work perfectly: the more
doubt that can be injected as to the utility of the comms, the less use
this system is.
W S Churchill
Old December 23rd 03, 03:52 AM
Pete
"phil hunt" wrote in message
writes
combat
systems.
picture.
Superman.
by own forces.
That 'area' changes hourly. And may not be known until the weapon gets over
the target area.
Do you waste a missile on a dark green Chevy Suburban, or a tank? Do you
have enough missiles for *every* vehicle in front of you?
Even the US/NATO gets that wrong sometimes.
Pete
Australia F111 to be scrapped!! John Cook Military Aviation 35 November 10th 03 11:46 PM
