stemme flaperon mix control
Old October 13th 08, 02:33 AM posted to rec.aviation.soaring
bjarthur
Default stemme flaperon mix control
a few responses i've received directly:
Don't know about the stemme in particular, but it is quite common for
flap positions to affect aileron travel. This happens in my ASW27. The
flaps and ailerons move together, so if the flaps are in
"down"
position, both ailerons are "down." Then the "up" aileron may not
be
able to move to its full upward position when the stick goes all the
way in one direction. For this reason in the ASW27, when you move the
flaps to landing position, the ailerons cease to follow along and
instead move up to zero degrees, in order to give full aileron
authority. I would not be surprised if the programmers of x plane did
not include this subtlety of the flap-aileron mixer system.
I own an S10 VT and would like to know details about how to get it
into the x-plane simulator. Shall be a great way of practicing
while
at
home.
By the way, have a look at the Condor Flight Simulator. For soaring
training and competition, there is nothing similar.
In real life, I use +10 degrees for landing. This gives adequate
aileron response for landing. I do not know the technical data for
mixing of the ailerons and flaps but they will reduce roll rate as you
increase the flap position toward LAND (+16 degrees). I sometimes use
full flaps for landing "short" with light wind or wind down the
runway.
My initial advice to a new Stemme pilot is to use +10 degrees flaps
for
landing.
Yes you do have aileron control with full landing flaps. It will seem
to be a little restrictive and it does fly with a slower roll rate
with
full flaps but they do continue to control at a slower roll rate.
Old October 22nd 08, 02:23 AM posted to rec.aviation.soaring
bjarthur
you can find the x-plane model of the stemme he
http://forums.x-plane.org/index.php?...&showfile=6392
and can download a trial copy of x-plane he
http://x-plane.com/demo.html
note that you need version 8 of x-plane, not 9. if there's enough
interest, i could update the stemme model to work on 9...
while at home.
Stemme Mal[_4_] Soaring 2 June 23rd 07 03:17 AM
Stemme S10 VT Mal Soaring 1 August 29th 06 04:15 PM
Who got the dipped Stemme? Bob Kuykendall Soaring 0 November 19th 05 12:43 AM
LS3 flaperon gap seal template needed Birdbones Soaring 2 May 14th 05 12:46 AM
FS Stemme S 10V soarski Soaring 1 January 24th 05 10:09 PM
