On Oct 20, 10:45*am, Ian wrote:
On 20 Oct, 09:01, (Michel Talon) wrote: Does "effectively stealing" means no stealing at all? Schleicher has nothing to do with the Pegasus. Strange as such lies are long living. I thought the Pegase fuselage was a direct copy of the ASW-19 - easily done, since Centrair were building the ASW-19F at the time. Then to add insult to injury they gave the Pegase a better wing than the ASW-19 had ... That's my understanding - and I also thought the ASW19 & ASW20 had almost identical fuselages. But I also thought it was all sorted out 20 years ago or so, and there was nothing ongoing. |
On 20 Oct, 10:59, Cats wrote:
On Oct 20, 10:45*am, Ian wrote: On 20 Oct, 09:01, (Michel Talon) wrote: Does "effectively stealing" means no stealing at all? Schleicher has nothing to do with the Pegasus. Strange as such lies are long living. I thought the Pegase fuselage was a direct copy of the ASW-19 - easily done, since Centrair were building the ASW-19F at the time. Then to add insult to injury they gave the Pegase a better wing than the ASW-19 had ... That's my understanding - and I also thought the ASW19 & ASW20 had almost identical fuselages. *But I also thought it was all sorted out 20 years ago or so, and there was nothing ongoing. An ASW-20 is more-or-less just a flapped ASW-19, isn't it? I, too, had the impression that the Schleicher-Centrair fight was settled years ago ... but I'd be very surprised indeed if Schleicher had any responsibility at all for Pegase airworthiness issues. Ian PS Wikipedia suggests that the Pegase uses the ASW-20 fuselage. |
On Oct 20, 12:16*pm, Ian wrote:
snip PS Wikipedia suggests that the Pegase uses the ASW-20 fuselage. Wikipedia also suggests: "The ASW 20 is an FAI 15 metre Class glider designed by Gerhard Waibel and built by Alexander Schleicher GmbH & Co. Its fuselage is nearly identical to the ASW19's, mated to newly designed wings for the 15 metre Class." So I suspect the three gliders are all very similar in most of the fuselage. |
On Mon, 20 Oct 2008 02:59:28 -0700, Cats wrote:
That's my understanding - and I also thought the ASW19 & ASW20 had almost identical fuselages. But I also thought it was all sorted out 20 years ago or so, and there was nothing ongoing. Centrair were building the ASW-20 under license, not the ASW-19. All ASW-20Fs were built by Centrair. The Pegase fuselage is almost identical to the 20: the boom is slightly bigger diameter (an ASW-20 tail dolly won't quite fit a Pegase) and the underwing cockpit vent intakes on the 20 were blocked and replaced by a nose intake. If you look carefully at a Pegase you can just see where the the 20's intakes were by looking for waviness in reflections off the gelcoat. I believe that the 19 and 20 have almost identical fuselages - probably the biggest difference between all three are the wing roots, since all three gliders have different wing sections. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 20 Oct, 12:36, Martin Gregorie
wrote: On Mon, 20 Oct 2008 02:59:28 -0700, Cats wrote: That's my understanding - and I also thought the ASW19 & ASW20 had almost identical fuselages. *But I also thought it was all sorted out 20 years ago or so, and there was nothing ongoing. Centrair were building the ASW-20 under license, not the ASW-19. All ASW-20Fs were built by Centrair. The Pegase fuselage is almost identical to the 20: the boom is slightly bigger diameter (an ASW-20 tail dolly won't quite fit a Pegase) ... I'm pretty sure that when I was flying at Le Blanc we used tail dollies interchangeably between Pegases and ASW-20s. Of course, they might all have been Pegase ones, on reflection ... Ian |
On Mon, 20 Oct 2008 08:01:15 -0700, Ian wrote:
I'm pretty sure that when I was flying at Le Blanc we used tail dollies interchangeably between Pegases and ASW-20s. Of course, they might all have been Pegase ones, on reflection ... The difference was pretty small. The difference wasn't apparent to the eye, but I'd read that Centrair had increased the boom diameter, so we tried my ASW-20 dolly on it to see if there really was a difference. I'd say the Pegase tail boom diameter was 3mm bigger at most. From memory the dolly fitted onto the boom OK, but the catches wouldn't go over centre with the normal amount of pressure. My dolly was a good snug fit on the '20 and had a fairly thin, firm lining. With a larger diameter moulding and a thicker, softer lining it may have fit on the Pegase too. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Airworthiness Certificate Replacement? | [email protected] | Soaring | 6 | June 26th 08 07:11 PM |
TBO and airworthiness | Jim Stewart | Owning | 26 | April 17th 07 05:05 PM |
USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 05:04 AM |
Exhibition/Racing Airworthiness Certificate Question | bsquared | Soaring | 5 | June 22nd 04 06:24 PM |
Airworthiness Directives for Jantar Standard 3 | Miguel Lavalle | Soaring | 5 | January 24th 04 10:55 AM |
