radio interference with transmission/reception with Solo 2625-01running
I own a Ventus 2CXM built 2007 with a factory installed Walter Dittle
FSG 2T radio. I use the Sennheiser headphones (factory installation) during the engine running procedures. Unfortunately, I have always had severe interference with the radio tramsmission/reception during the engine run. During the engine run, whether idle or full power, the reception is weak and garbled with a great deal of backround white noise. My transmissions are totally garbled, weak, and uninterpretable even to other aircraft 50 yards away. When the engine is not running I have not problems and my fellow pilots report that my transmissions are strong and clear. This is becoming a safety problem while taxing onto the active runway, as our glider airport is now very busy with power traffic and a new flight school. Has anyone encountered this problem and know of a list of things to check before sending the aircraft to an aviation radio specialist? John Iacobucci Grand Rapids, Michigan USA +1 (616) 485-3980 |
radio interference with transmission/reception with Solo 2625-01 running
"November Bravo" wrote in message ... Has anyone encountered this problem and know of a list of things to check before sending the aircraft to an aviation radio specialist? Off the top of my head, you are probably receiving interference via the power system or your engine is radiating interference that being picked up by the antenna and drowning out reception. The first problem might be solved with some filtering and careful attention to your aircraft's ground system, and the second problem might respond to an antenna relocation and/or engine electrical shielding. Make sure that the antenna coaxial cable is not accidentally serving as the power ground for the radio (unplug antenna and make sure that radio still has power) Two things you can easily check that would provide important troubleshooting clues: 1) If you use a portable radio inside the cockpit with the engine running, do you have the same problem? and... 2) If you power the Dittle from a temporary battery (not connected to the glider's electrical system) does it make any difference in the transmission and/or reception? Vaughn |
November Bravo wrote:
I own a Ventus 2CXM built 2007 with a factory installed Walter Dittle FSG 2T radio. I use the Sennheiser headphones (factory installation) during the engine running procedures. Unfortunately, I have always had severe interference with the radio tramsmission/reception during the engine run. During the engine run, whether idle or full power, the reception is weak and garbled with a great deal of backround white noise. My transmissions are totally garbled, weak, and uninterpretable even to other aircraft 50 yards away. When the engine is not running I have not problems and my fellow pilots report that my transmissions are strong and clear. This is becoming a safety problem while taxing onto the active runway, as our glider airport is now very busy with power traffic and a new flight school. Has anyone encountered this problem and know of a list of things to check before sending the aircraft to an aviation radio specialist? Have you tried one of the owners groups? Other people with Solo engine self-launchers have had problems like yours. From the ASA website (motorglider.org) "Links and Newsgroups": http://groups.yahoo.com/group/DGSoloUsersGroup/ http://groups.yahoo.com/group/Ventus_2CM/ -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Similar Threads | ||||
Ventus 2cxM Solo 2625 01 EGT Installation | Chris Woolley | Soaring | 2 | April 4th 08 04:09 AM |
SOLO 2625-02 engine drawings | Maciek | Soaring | 2 | April 5th 07 01:15 PM |
FM radio interference from planes | rb | Piloting | 34 | July 19th 06 05:53 PM |
GPS / radio interference | Cub Driver | Piloting | 2 | October 31st 04 10:57 PM |
radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 06:09 AM |
