K13 Opinions
Old October 29th 08, 04:54 AM posted to rec.aviation.soaring
noel.wade
Default K13 Opinions
Frank -
Good point! Whether your group rigs and de-rigs the two-seaters often
is another important consideration.
This, of course, depends not only on your hangar/trailer/tie-down
situation and your local weather patterns, but ALSO in how you run
your operations and what kind of flying you intend to do with your 2-
seat ships (for example, XC training entails a slightly higher risk of
a 2-seater landout and the resulting de-rig to trailer it home).
Take care,
--Noel
Old October 29th 08, 07:15 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
My club in the UK has 9 of the things that have all made many tens of
thousands of launches, mostly by winch. They are tough, easy to repair and
relatively cheap to buy compared with modern glass. They are a good, safe,
all round trainer, but are rather slow and have low performance by modern
standards. Unlike its successor the K21, it can be persuaded to spin and
doesn't quickly loose vast amounts of height doing so, unlike some other
modern glass trainers. We are starting to replace them with K21s and
DG1000s.
Derek Copeland
At 04:54 29 October 2008, noel.wade wrote:
Frank -
Take care,
--Noel
Old October 29th 08, 09:46 AM posted to rec.aviation.soaring
stephanevdv
The ASK-13 is much appreciated as a trainer. There is one serious
catch however: a very limited maximum cockpit load. We have two 13's,
one with 168 kg max. weight for two pilots. This means problems with
your load and balance...
Old October 29th 08, 11:56 AM posted to rec.aviation.soaring
Mike125
Thanks for all the replies. I overlooked the obvious need for hanger
space. This pretty much rules out a 13 for our club. Dang.
MIke
Old October 29th 08, 12:45 PM posted to rec.aviation.soaring
Derek Copeland[_2_]
The Yanks should eat less burgers and fries and do a bit more walking.
Then there wouldn't be a problem!
The UK K13s have a BGA approved MAUW increase that makes them non
aerobatic , but normally allows two 200lb middle aged males to fly them.
We are just hoping that EASA (European Aviation Safety Agency, otherwise
known as Europe Against Soaring Anything) wouldn't re-impose the original
limits.
Derek Copeland
Opinions on ASW-17 Thomas Mærsk Pedersen Soaring 10 October 14th 04 02:04 PM
opinions on a K13 Scott Macleman Soaring 32 April 29th 04 05:52 PM
Your opinions, please! Jay Honeck Home Built 65 December 16th 03 05:52 PM
Your opinions, please! Jay Honeck Owning 63 December 15th 03 05:25 PM
Opinions? Chris Aerobatics 2 November 2nd 03 09:42 PM
