Broke Airline Pilot needs "stuff" for an ASW-15B
Old October 25th 08, 02:59 PM posted to rec.aviation.soaring
Doug Hoffman
Default Broke Airline Pilot needs "stuff" for an ASW-15B
Cats wrote:
On Oct 23, 2:06 am, wrote:
I recently bought a 1972 ASW-15B. I am on a budget to fix this up.
I'm looking for stuff that works, doesn't look flashly, but fits the
need.
I need a:
4.Gear so I can tow it by myself to the runway
Same answer as #3, but you have to take great care it will do the job
without damaging the glider.
I agree with that regarding the tow-out bar. But if one has a good
working example unit(or specifications/photo of same) then a safe
tow-out bar is easily/cheaply made. I have seen large diameter conduit
or square section aluminum extrusion used as the main structure.
Bolting that to a ball hitch coupler is a no brainer. The tricky part
is getting a secure/safe attachment of that to the glider fuse.
The tow-out wheel, which "cuffs" onto one wing, is most easily/cheaply
made and there is little chance of damaging the glider if common sense
is used. I have made several for about $25 apiece. Use a child's bicycle
front wheel (search the neighborhood on trash collection day or stop at
some garage sales), some 2x4 and 2x6 wood, a gate hinge and pipe flange
from the hardware store, a cinching latch from Production Tool Supply or
McMaster-Carr. Cut the wood wing cuff about 3/4" too large for the
airfoil. Wrap the wing section in saran for protection. Use Great
Stuff expanding insulation foam to fill the gap and provide a wing cuff
that "perfectly" fits the wing. I can provide photos of the last one I
made (for a LAK-12). Works great. Easy and quick to make. Cheap.
Regards,
-Doug
Old October 30th 08, 10:41 PM posted to rec.aviation.soaring
Doug that would be nice to see some pictures.
It looks like I'm getting most everything I need so far.
Mark Hawkins is hooking me up with a killer deal. He sold me his GPS/
PDA and a towout bar that's almost finished. What a deal. Can't wait
to get it.
Thank you Mark!
Medal of Honor pilot Ed "Too tall" Freedman dies at 80 Tiger Naval Aviation 0 August 21st 08 08:25 PM
End of an era? "FAA Issues Final Rule On Plastic Pilot Certificates" AJ Piloting 2 March 3rd 08 06:47 PM
Are there any "pilot" watches that are actually helpful for pilots? es330td Piloting 51 November 19th 07 11:01 PM
Is a "Go Around" an unfamiliar manoeuvre to a student pilot? David Wright[_2_] Piloting 77 July 20th 07 04:00 PM
Aviation Accident - No "Excellent Pilot" Mention Judah Piloting 3 February 7th 06 09:53 PM
