In article
, BobR wrote: On Oct 31, 2:59*pm, Alan Baker wrote: In article , *BobR wrote: On Oct 31, 2:09*pm, Alan Baker wrote: In article , *BobR wrote: On Oct 30, 5:12*pm, "Gregory Hall" wrote: "Vaughn Simon" wrote in message ... "Gregory Hall" wrote in message ... It looks too much like an irresponsible, hot rod, stunt plane to me. * Well, you sucked me in at first, so on a troll scale of zero-to-10 you rate at least a five. *How are things in France? Vaughn France? *I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the wind with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. -- Gregory Hall Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. The layout of the two planes being discussed is totally different. One involved a tractor configuration with the thrust line being very near the vertical center of gravity. The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
On Nov 1, 12:09*am, Alan Baker wrote:
In article , *BobR wrote: On Oct 31, 2:59*pm, Alan Baker wrote: In article , *BobR wrote: On Oct 31, 2:09*pm, Alan Baker wrote: In article , *BobR wrote: On Oct 30, 5:12*pm, "Gregory Hall" wrote: "Vaughn Simon" wrote in message .... "Gregory Hall" wrote in message ... It looks too much like an irresponsible, hot rod, stunt plane to me. * Well, you sucked me in at first, so on a troll scale of zero-to-10 you rate at least a five. *How are things in France? Vaughn France? *I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the wind with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. -- Gregory Hall Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces.. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing.. This is not so. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. *The layout of the two planes being discussed is totally different. *One involved a tractor configuration with the thrust line being very near the vertical center of gravity. *The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. *This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. *This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. *The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - Well excuse the holy hell out of me for not phrasing things the way you want it. My references were based on the specifics of the two planes involved in the discussion and if you can't gleem that fact from it, too ****ing bad. |
In article
, BobR wrote: On Nov 1, 12:09*am, Alan Baker wrote: In article , *BobR wrote: On Oct 31, 2:59*pm, Alan Baker wrote: In article , *BobR wrote: On Oct 31, 2:09*pm, Alan Baker wrote: In article , *BobR wrote: On Oct 30, 5:12*pm, "Gregory Hall" wrote: "Vaughn Simon" wrote in message ... "Gregory Hall" wrote in message ... It looks too much like an irresponsible, hot rod, stunt plane to me. * Well, you sucked me in at first, so on a troll scale of zero-to-10 you rate at least a five. *How are things in France? Vaughn France? *I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the wind with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. -- Gregory Hall Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. *The layout of the two planes being discussed is totally different. *One involved a tractor configuration with the thrust line being very near the vertical center of gravity. *The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. *This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. *This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. *The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - Well excuse the holy hell out of me for not phrasing things the way you want it. My references were based on the specifics of the two planes involved in the discussion and if you can't gleem that fact from it, too ****ing bad. Trying to retcon your comments and say that such and such wasn't what you meant would work better if you... ....ACTUALLY SHOWED YOU UNDERSTOOD WHAT YOU'RE TALKING ABOUT... ....in your next post. You, OTOH, showed you still didn't get it and now you're getting ****y. And the word your tiny little mind was scratching for was "glean". Always happy to help the ignorant. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
On Nov 1, 9:40*pm, Alan Baker wrote:
In article , *BobR wrote: On Nov 1, 12:09*am, Alan Baker wrote: In article , *BobR wrote: On Oct 31, 2:59*pm, Alan Baker wrote: In article , *BobR wrote: On Oct 31, 2:09*pm, Alan Baker wrote: In article , *BobR wrote: On Oct 30, 5:12*pm, "Gregory Hall" wrote: "Vaughn Simon" wrote in message ... "Gregory Hall" wrote in message ... It looks too much like an irresponsible, hot rod, stunt plane to me. * Well, you sucked me in at first, so on a troll scale of zero-to-10 you rate at least a five. *How are things in France? Vaughn France? *I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the wind with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. -- Gregory Hall Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator.. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. *The layout of the two planes being discussed is totally different. *One involved a tractor configuration with the thrust line being very near the vertical center of gravity. *The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. *This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. *This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. *The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy.. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - Well excuse the holy hell out of me for not phrasing things the way you want it. *My references were based on the specifics of the two planes involved in the discussion and if you can't gleem that fact from it, too ****ing bad. Trying to retcon your comments and say that such and such wasn't what you meant would work better if you... I said what I ment but I can't help that you read into it something else. ...ACTUALLY SHOWED YOU UNDERSTOOD WHAT YOU'RE TALKING ABOUT... I knew exactly what I was talking about but again, you read something into it beyond what I said. That part is your problem not mine. ...in your next post. You, OTOH, showed you still didn't get it and now you're getting ****y. I am getting very tired of your arrogant attitude that ONLY YOU understand. And the word your tiny little mind was scratching for was "glean". Sorry but my typing isn't always the greatest and once again, your arrogance shows in thinking you are the only smart one in the group. Always happy to help the ignorant. Gee, so nice of you to come down from that tower you put yourself into and mingle with us common folk. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text - - Show quoted text - |
In article
, BobR wrote: snip It looks too much like an irresponsible, hot rod, stunt plane to me. * Well, you sucked me in at first, so on a troll scale of zero-to-10 you rate at least a five. *How are things in France? Vaughn France? *I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the wind with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. -- Gregory Hall Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. *The layout of the two planes being discussed is totally different. *One involved a tractor configuration with the thrust line being very near the vertical center of gravity. *The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. *This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. *This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. *The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. - Show quoted text - Well excuse the holy hell out of me for not phrasing things the way you want it. *My references were based on the specifics of the two planes involved in the discussion and if you can't gleem that fact from it, too ****ing bad. Trying to retcon your comments and say that such and such wasn't what you meant would work better if you... I said what I ment but I can't help that you read into it something else. And you made the fact that the aircraft was a pusher an issue. You were wrong. Deal with it. ...ACTUALLY SHOWED YOU UNDERSTOOD WHAT YOU'RE TALKING ABOUT... I knew exactly what I was talking about but again, you read something into it beyond what I said. That part is your problem not mine. Nope. Because the weight of an engine has precisely the same influence on the aircraft at all times, operating or not. ...in your next post. You, OTOH, showed you still didn't get it and now you're getting ****y. I am getting very tired of your arrogant attitude that ONLY YOU understand. Not "only me", just -- quite obviously -- not you. And the word your tiny little mind was scratching for was "glean". Sorry but my typing isn't always the greatest and once again, your arrogance shows in thinking you are the only smart one in the group. Sorry, (and note the correct use of the comma, BTW) but the error wasn't a typo, and you can't retcon it into one. Always happy to help the ignorant. Gee, so nice of you to come down from that tower you put yourself into and mingle with us common folk. Hey... You're more common than most. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
If I may save Jim the trouble....
On Nov 2, 5:56*pm, Alan Baker wrote:
In article , *BobR wrote: snip It looks too much like an irresponsible, hot rod, stunt plane to me. * Well, you sucked me in at first, so on a troll scale of zero-to-10 you rate at least a five. *How are things in France? Vaughn France? *I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the wind with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. -- Gregory Hall Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. *The layout of the two planes being discussed is totally different. *One involved a tractor configuration with the thrust line being very near the vertical center of gravity. *The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. *This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. *This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. *The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. - Show quoted text - Well excuse the holy hell out of me for not phrasing things the way you want it. *My references were based on the specifics of the two planes involved in the discussion and if you can't gleem that fact from it, too ****ing bad. Trying to retcon your comments and say that such and such wasn't what you meant would work better if you... I said what I ment but I can't help that you read into it something else. And you made the fact that the aircraft was a pusher an issue. You were wrong. Deal with it. No, I never made the fact that the aircraft was a pusher into an issue...YOU DID. I simply pointed out different design elements of the two aircraft. You drew false conclusions from them and now try to make a issue from them. ...ACTUALLY SHOWED YOU UNDERSTOOD WHAT YOU'RE TALKING ABOUT... I knew exactly what I was talking about but again, you read something into it beyond what I said. *That part is your problem not mine. Nope. Because the weight of an engine has precisely the same influence on the aircraft at all times, operating or not. Gee do tell! Again you make false assumptions and then try and make some point from it. ...in your next post. You, OTOH, showed you still didn't get it and now you're getting ****y. I am getting very tired of your arrogant attitude that ONLY YOU understand. Not "only me", just -- quite obviously -- not you. And the word your tiny little mind was scratching for was "glean". Sorry but my typing isn't always the greatest and once again, your arrogance shows in thinking you are the only smart one in the group. Sorry, (and note the correct use of the comma, BTW) but the error wasn't a typo, and you can't retcon it into one. Yep, once again your arrogance rises to the occasion. Always happy to help the ignorant. Gee, so nice of you to come down from that tower you put yourself into and mingle with us common folk. Hey... You're more common than most. And you are a lot more arrogant than most. Looking back through your posts it was clear that you felt the necessity to correct just about everyone. Guess that puts me in the good company of a lot of other common folk. |
In article
, BobR wrote: On Nov 2, 5:56*pm, Alan Baker wrote: In article , *BobR wrote: snip snip Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. *The layout of the two planes being discussed is totally different. *One involved a tractor configuration with the thrust line being very near the vertical center of gravity. *The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. *This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. *This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. *The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. - Show quoted text - Well excuse the holy hell out of me for not phrasing things the way you want it. *My references were based on the specifics of the two planes involved in the discussion and if you can't gleem that fact from it, too ****ing bad. Trying to retcon your comments and say that such and such wasn't what you meant would work better if you... I said what I ment but I can't help that you read into it something else. And you made the fact that the aircraft was a pusher an issue. You were wrong. Deal with it. No, I never made the fact that the aircraft was a pusher into an issue...YOU DID. I simply pointed out different design elements of the two aircraft. You drew false conclusions from them and now try to make a issue from them. Sigh.... "The Lancair is NOT a pusher..." ...ACTUALLY SHOWED YOU UNDERSTOOD WHAT YOU'RE TALKING ABOUT... I knew exactly what I was talking about but again, you read something into it beyond what I said. *That part is your problem not mine. Nope. Because the weight of an engine has precisely the same influence on the aircraft at all times, operating or not. Gee do tell! Again you make false assumptions and then try and make some point from it. Sigh... "This is contrary to the standard configuration which requires a downward force to counter the weight of the engine." That's you attributing the engine's weight some special status when in the nose, when if fact, it is the overall position of the centre of gravity that matters. ...in your next post. You, OTOH, showed you still didn't get it and now you're getting ****y. I am getting very tired of your arrogant attitude that ONLY YOU understand. Not "only me", just -- quite obviously -- not you. And the word your tiny little mind was scratching for was "glean". Sorry but my typing isn't always the greatest and once again, your arrogance shows in thinking you are the only smart one in the group. Sorry, (and note the correct use of the comma, BTW) but the error wasn't a typo, and you can't retcon it into one. Yep, once again your arrogance rises to the occasion. My ability to understand that typing "gleem" when the word you're looking for is "glean" can't be a typo is "arrogance", now? Always happy to help the ignorant. Gee, so nice of you to come down from that tower you put yourself into and mingle with us common folk. Hey... You're more common than most. And you are a lot more arrogant than most. Looking back through your posts it was clear that you felt the necessity to correct just about everyone. Guess that puts me in the good company of a lot of other common folk. I correct things that are incorrect. Unlike you: who introduces extraneous and erroneous points into a discussion, thus clouding the issue. The only thing that matter was thrust line. You kept introducing other factors that were irrelevant. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Bryan Martin wrote: In article , BobR wrote: I said what I ment but I can't help that you read into it something else. I for one understood exactly what you meant, but then, I also read the post that you were replying to. Apparently, Alan didn't bother to do that. On the other hand, he is from a foreign country, maybe there's some language barrier issues involved. ![]() I understood what he meant, and it included the idea that the pusher vs tractor element played a role. "The Lancair is NOT a pusher..." He's the one who included a completely irrelevant fact as his very first discriminator. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Shaw Flaw | The Old Guy | Aviation Photos | 0 | September 16th 08 05:18 AM |
Lancair Legacy | Joaquin | Home Built | 22 | November 13th 06 09:06 AM |
BWB has finished his Lancair Legacy... | John Ammeter | Home Built | 1 | June 6th 06 04:11 AM |
Lancair Legacy 2000 | Randy L. | Simulators | 6 | October 9th 03 09:56 PM |
