What is garnet?
Old November 1st 08, 10:08 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default What is garnet?
With reference to sandblasting, what is garnet? - Mike
Old November 1st 08, 11:01 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"Michael Horowitz" wrote in message
It is a mineral that is very hard, and is one of the more common choices of
grit found on sandpaper.
I'm no expert on sandblasting, but I believe it is only used when the job
calls for very aggressive removal, such as very rusty or heavily painted
THICK steel.
Typically NOT aircraft. :-)
Jim in NC
Old November 1st 08, 12:05 PM posted to rec.aviation.homebuilt
Michael Horowitz
we;;, there goes the planned visit to TSC
I'm wondering if I' m just not using this handheld blaster correctly;
sand works but oh, so slow - Mike
On Sat, 1 Nov 2008 06:01:12 -0500, "Morgans"
THICK steel.
Old November 1st 08, 12:37 PM posted to rec.aviation.homebuilt
Morgans[_2_]
You using a unit run off of a 3 HP or smaller air compressor? That is just
a toy, meant for small parts.
Like another poster said, the garnet leaves stress in parts, especially
aluminum, so I have heard.
Jim in NC
Old November 1st 08, 05:18 PM posted to rec.aviation.homebuilt
Michael Horowitz
Hello Jim - Craftsman 5 HP, 20 gal tank capable of 150 psi but I've
only been able to get it to 125.
Do you think I'm fooling myself? I know SB takes a lot of air - Mike
On Sat, 1 Nov 2008 07:37:10 -0500, "Morgans"
Old November 1st 08, 07:35 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
news
Real horsepower or Sears horsepower? If it runs on 110 volts, you aren't
getting 5 HP.
The maximum pressure is irrelevent.
You can do some sandblasting on a 110 volt compressor, but it's pretty much
limited to small parts and you have to take a break every now and again to
let the compressor catch up.
What are you trying to clean up?
Geoff
Old November 1st 08, 09:38 PM posted to rec.aviation.homebuilt
Morgans[_2_]
news
Yep, 'fraid so.
Craftsman ALWAYS over rates their power tools. It probably uses 13 - 15 amps
at 110 V. That's 2 HP to most others.
Any blasting with that is low volume and low pressure, with lots of waiting.
Jim in NC
Old November 2nd 08, 11:25 AM posted to rec.aviation.homebuilt
Michael Horowitz
This isn't electric; Honda engine ; does that make a diff? = Mike
On Sat, 1 Nov 2008 15:35:33 -0400, "Capt. Geoffrey Thorpe" The Sea
news
getting 5 HP.
Michael Horowitz
On Sat, 1 Nov 2008 16:38:17 -0500, "Morgans"
news
Yep, 'fraid so.
Old November 2nd 08, 12:33 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Probably a little, but it is still in the "small compressor" class.
Real sandblasting systems are usually run by 4 cylinder or larger engines,
and move many times more CFM. They also shoot a lot more blasting media per
minute, most likely.
If you are really wanting to do a large job, rent one, or hire a
sandblasting outfit. You will be ahead on aggravation and time.
If you are only going to do small parts and such, take your time, and enjoy!
g
Jim in NC
