At 05:23 02 November 2008, 309 wrote:
Well, it's time to set clocks back...and I noticed something interesting today. My VolksLogger's clock seems to run 15 seconds ahead of other GPS units...and the US Atomic clock (which appears to be synchronized with GPS time -- or vice verse -- per the readout from a Garmin GPS90). I say the VL seems ahead...and this is based on seeing the minute readout roll over ahead of the other GPS units...since the VL display doesn't show seconds. Normally, this isn't a real concern, but I've been using the VL to do some performance flight testing on a power plane...and I noticed that the events I recorded didn't match up with the trace on the VL. Has anybody else seen this type of "synchronization" error? -Pete #309 The probably explanation is that the difference you are seeing is 14 seconds and there have been 14 leap seconds since GPS started up. Leap Seconds are introduced because the earth does not rotate in exactly 24 hours and GPS relies on exact time. Satellites transmit the leap-second correction in ephemeris data which is broadcast every 12.5 minutes, so if your VL had had sight of the sky until the next correction came in, it would show correct time. Read http://www.u-blox.com/customersuppor...apSeconds.html for a manufacturer's explanation. Had your VL been without power for a long period? I would have expected the RTC in the VL to keep a record of the current correction under normal circumstances. - Tim Newport-Peace > Skype: specialist_systems http://www.spsys.demon.co.uk/icom.htm |
Daylight Savings Time (Was: American Airlines - Last one standing) | Bob Noel | Piloting | 4 | October 1st 05 09:30 PM |
Daylight Savings Time | Bob Fry | Piloting | 0 | September 17th 05 07:27 PM |
Losing TIS Sites | Chuck | Owning | 0 | July 1st 05 09:28 PM |
Losing my Clearcoat | Robert M. Gary | Piloting | 9 | March 3rd 04 07:36 PM |
Were AC-130s used in daylight in Afghanistan? | Ron | Military Aviation | 0 | November 12th 03 12:16 AM |
