In article
, BobR wrote: On Nov 2, 5:56*pm, Alan Baker wrote: In article , *BobR wrote: snip snip Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. *The layout of the two planes being discussed is totally different. *One involved a tractor configuration with the thrust line being very near the vertical center of gravity. *The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. *This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. *This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. *The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. - Show quoted text - Well excuse the holy hell out of me for not phrasing things the way you want it. *My references were based on the specifics of the two planes involved in the discussion and if you can't gleem that fact from it, too ****ing bad. Trying to retcon your comments and say that such and such wasn't what you meant would work better if you... I said what I ment but I can't help that you read into it something else. And you made the fact that the aircraft was a pusher an issue. You were wrong. Deal with it. No, I never made the fact that the aircraft was a pusher into an issue...YOU DID. I simply pointed out different design elements of the two aircraft. You drew false conclusions from them and now try to make a issue from them. Sigh.... "The Lancair is NOT a pusher..." ...ACTUALLY SHOWED YOU UNDERSTOOD WHAT YOU'RE TALKING ABOUT... I knew exactly what I was talking about but again, you read something into it beyond what I said. *That part is your problem not mine. Nope. Because the weight of an engine has precisely the same influence on the aircraft at all times, operating or not. Gee do tell! Again you make false assumptions and then try and make some point from it. Sigh... "This is contrary to the standard configuration which requires a downward force to counter the weight of the engine." That's you attributing the engine's weight some special status when in the nose, when if fact, it is the overall position of the centre of gravity that matters. ...in your next post. You, OTOH, showed you still didn't get it and now you're getting ****y. I am getting very tired of your arrogant attitude that ONLY YOU understand. Not "only me", just -- quite obviously -- not you. And the word your tiny little mind was scratching for was "glean". Sorry but my typing isn't always the greatest and once again, your arrogance shows in thinking you are the only smart one in the group. Sorry, (and note the correct use of the comma, BTW) but the error wasn't a typo, and you can't retcon it into one. Yep, once again your arrogance rises to the occasion. My ability to understand that typing "gleem" when the word you're looking for is "glean" can't be a typo is "arrogance", now? Always happy to help the ignorant. Gee, so nice of you to come down from that tower you put yourself into and mingle with us common folk. Hey... You're more common than most. And you are a lot more arrogant than most. Looking back through your posts it was clear that you felt the necessity to correct just about everyone. Guess that puts me in the good company of a lot of other common folk. I correct things that are incorrect. Unlike you: who introduces extraneous and erroneous points into a discussion, thus clouding the issue. The only thing that matter was thrust line. You kept introducing other factors that were irrelevant. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
On Nov 2, 8:22*pm, Alan Baker wrote:
In article , *BobR wrote: On Nov 2, 5:56*pm, Alan Baker wrote: In article , *BobR wrote: snip snip Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. |
In article
, BobR wrote: On Nov 2, 8:22*pm, Alan Baker wrote: In article , *BobR wrote: On Nov 2, 5:56*pm, Alan Baker wrote: In article , *BobR wrote: snip snip Oh for gawd sake, you are talking about two totally different designs and the aerodynamics of the two are totally different. *The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down. *The two planes would not act pretty much the same at all. *The weight of the engine on the Legacy is forward of the CG and as a result always pulling the nose of the plane down. *The counter to the nose down is the horizontal stabilizer and the elevator. *Look at the angle of incedence on the Horizontal Stabilizer and you will find a slight downward angle, not an upward angle as is common on the wing. *This counteracts the force from the weight of the engine. *An engine out condition will not have a significant effect on pitch until the airspeed changes and that will result in a nose down, not nose up pull. The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Not sure what you are replying to but I never said anything about directional stability. *The discussion was regarding pitch forces. Which is essentially the same thing. Pusher or puller doesn't affect pitch forces. What affects pitch forces is the length of the moment arm between the centre of mass and the thrust line. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. - Show quoted text - Again Alan, I never indicated any issue with pusher vs tractor. *The layout of the two planes being discussed is totally different. *One involved a tractor configuration with the thrust line being very near the vertical center of gravity. *The second involved an plane with the engine mounted on a pylon with a thrust line well above the vertical center of gravity. *This configuration, rather it be a tractor or pusher will induce nose down forces that must be countered by the horizontal stabilizer with an upward force. *This is contrary to the standard configuration which requires a downward force to counter the weight of the engine. *The post I was replying to was trying to link the characteristic of the pylon mounted configuration to the Legacy. Sorry, man, but you made specific reference to the plane being a pusher as if it was a relevant factor: "The Lancair is NOT a pusher and the engine is mounted forward of the CG instead of on top of it. *When the engine quits it will not pitch upward. *The plane you flew had the engine well above the center of gravity with a pusher prop and as a result produced a force that pushed the nose of the aircraft down." When you include extraneous details, you make the essence of the situation harder to glean. And you're doing it again. You're conflating thrust line induced pitch changes with weight of engine. One is changing, one is constant. The only part that you had to talk about was the fact that the thrust line was significantly above the centre of mass. The weight of the engine doesn't matter (in an aircraft that has it's centre of gravity appropriately located), nor does pusher vs. puller. - Show quoted text - Well excuse the holy hell out of me for not phrasing things the way you want it. *My references were based on the specifics of the two planes involved in the discussion and if you can't gleem that fact from it, too ****ing bad. Trying to retcon your comments and say that such and such wasn't what you meant would work better if you... I said what I ment but I can't help that you read into it something else. And you made the fact that the aircraft was a pusher an issue. You were wrong. Deal with it. No, I never made the fact that the aircraft was a pusher into an issue...YOU DID. *I simply pointed out different design elements of the two aircraft. *You drew false conclusions from them and now try to make a issue from them. Sigh.... "The Lancair is NOT a pusher..." AND THAT IS WHERE YOU MIND WENT BLANK AND YOU STOPPED COMPREHENDING ANYTHING ELSE. Nope. I comprehended the rest fine. You, OTOH, led of your reply with what you now claim was an irrelevancy... ...ACTUALLY SHOWED YOU UNDERSTOOD WHAT YOU'RE TALKING ABOUT... I knew exactly what I was talking about but again, you read something into it beyond what I said. *That part is your problem not mine. Nope. Because the weight of an engine has precisely the same influence on the aircraft at all times, operating or not. Gee do tell! *Again you make false assumptions and then try and make some point from it. Sigh... "This is contrary to the standard configuration which requires a downward force to counter the weight of the engine." That's you attributing the engine's weight some special status when in the nose, when if fact, it is the overall position of the centre of gravity that matters. Yep, the fact that it is FORWARD of the CG doesn't matter at all. Damn but you can't seem to understand anything that is not said exactly like you want it to be. Take one part out of context and try and make an entire argument from it. Precisely correct. The fact that it is forward of the centre of *mass* doesn't matter at all, because whatever the location of the engine, its effect is the same whether its operating or not. ...in your next post. You, OTOH, showed you still didn't get it and now you're getting ****y. I am getting very tired of your arrogant attitude that ONLY YOU understand. Not "only me", just -- quite obviously -- not you. And the word your tiny little mind was scratching for was "glean". Sorry but my typing isn't always the greatest and once again, your arrogance shows in thinking you are the only smart one in the group. Sorry, (and note the correct use of the comma, BTW) but the error wasn't a typo, and you can't retcon it into one. Yep, once again your arrogance rises to the occasion. My ability to understand that typing "gleem" when the word you're looking for is "glean" can't be a typo is "arrogance", now? So I didn't spell the word correctly...big fking deal. You want to be my english teacher now too? The arrogance is that you couldn't help yourself and had to make an issue of that too. But you didn't claim it was a spelling error. You claimed it was a typo... Always happy to help the ignorant. Gee, so nice of you to come down from that tower you put yourself into and mingle with us common folk. Hey... You're more common than most. And you are a lot more arrogant than most. *Looking back through your posts it was clear that you felt the necessity to correct just about everyone. *Guess that puts me in the good company of a lot of other common folk. I correct things that are incorrect. Unlike you: who introduces extraneous and erroneous points into a discussion, thus clouding the issue. No, you make issues where there were no issues and your arrogance doesn't allow any one else room to say anything. You had to pick apart my response without even trying to understand the point I was trying to get across. You still don't get it and never will. You did the same to everyone else who responded as well. Sorry, but no. You make issues out of hwat (BTW, *that* is what a typo looks like) are not issues. The only thing that matter was thrust line. You kept introducing other factors that were irrelevant. That was clearly the only thing YOU BELIEVED mattered and clearly I didn't say it exactly the way you wanted. TOO BAD! Yes, in this particular case, the thrust line was important and I indicated such but not in those words. But what I was more interested in was pointing out that the two planes had totally different configurations and would react differently. You can't and will never accept that because you can't get beyond your own intrepretations an insist on talking down to everybody. The thrust line was *all* that was important in this discussion. And clearly, you still don't understand that. The only difference in their configuration that matter in the case of loss of engine power was where the thrust line was in relation to the centre of mass. The whole pusher/puller and position of the engine's weight were completely irrelevant. Simple fact, and I'm sorry you can't get it. So at this point, I will simply yield to your superior knowledge of all things and say that you are always right. From this point on I will not try to make any posts unless you proof read them first. I will also encourage everyone else to do the same. Great. The group will be better off for it. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
The only thing that matter was thrust line. You've managed to make the same incorrect claim at least twice (that I've counted) in one thread. Are you sure you aren't overlooking something? |
Jim Logajan wrote: Alan Baker wrote: The only thing that matter was thrust line. You've managed to make the same incorrect claim at least twice (that I've counted) in one thread. Are you sure you aren't overlooking something? I'm will to entertain that possibility. What do you think I'm overlooking? -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
In article , Jim Logajan wrote: Alan Baker wrote: The only thing that matter was thrust line. You've managed to make the same incorrect claim at least twice (that I've counted) in one thread. Are you sure you aren't overlooking something? I'm will to entertain that possibility. What do you think I'm overlooking? That the aircraft are moving through a fluid, not a vacuum. So things like propwash affect a tractor differently than a pusher. In my own analysis of the two types and their engine on versus engine off dynamics, the thrust line has not been "the only thing that matter[s]." It is more complex, and the texts I have handy do not make the situation appear as simple as you claim. If thrust line moment arm (relative to the c.g.) were all that mattered, then the following two bottle rocket firework designs would fly the same paths, mass, impulse curve, c.g., and thrust moment arm being held the same: (A) ----------------+-----+ |=====] (B) +-----+---------------- |=====] The attachments to the sticks are made so that the moment arms relative to the c.g. are otherwise identical, but in (B) the thrust is opposite its usual direction. Now in a vacuum I would expect them to fly the same paths and would be surprised if they didn't do that. But in a fluid like the atmosphere? Would you expect them to fly the same or different paths? Frankly, I would be surprised if they did fly the same - but as I don't have any fireworks handy at the moment I haven't gone outside to have fun, er, run experiments to observe their behavior. |
Jim Logajan wrote: Alan Baker wrote: In article , Jim Logajan wrote: Alan Baker wrote: The only thing that matter was thrust line. You've managed to make the same incorrect claim at least twice (that I've counted) in one thread. Are you sure you aren't overlooking something? I'm will to entertain that possibility. What do you think I'm overlooking? That the aircraft are moving through a fluid, not a vacuum. So things like propwash affect a tractor differently than a pusher. In my own analysis of the two types and their engine on versus engine off dynamics, the thrust line has not been "the only thing that matter[s]." It is more complex, and the texts I have handy do not make the situation appear as simple as you claim. If thrust line moment arm (relative to the c.g.) were all that mattered, then the following two bottle rocket firework designs would fly the same paths, mass, impulse curve, c.g., and thrust moment arm being held the same: (A) ----------------+-----+ |=====] (B) +-----+---------------- |=====] The attachments to the sticks are made so that the moment arms relative to the c.g. are otherwise identical, but in (B) the thrust is opposite its usual direction. Now in a vacuum I would expect them to fly the same paths and would be surprised if they didn't do that. But in a fluid like the atmosphere? Would you expect them to fly the same or different paths? Frankly, I would be surprised if they did fly the same - but as I don't have any fireworks handy at the moment I haven't gone outside to have fun, er, run experiments to observe their behavior. Sorry, but you're proceeding from two wrong assumptions. 1. Your A and B examples would both behave the same in flight if their centres of mass were both the same. It is the aerodynamic centre of pressure moving ahead of the centre of mass that would cause B to be unstable and A stable, if we operate from the assumption that the only parts involved are the rocket and the stick. 2. In specific, both of the aircraft in this case are stable. They are both stable because the aerodynamic centre of pressure is behind the centre of mass and because the centre of lift of the main wing is behind the centre of gravity. Thus, your assumption that a change in the engines location matters is based on the erroneous assumption that such a change is being made in isolation. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
Jim Logajan wrote: Alan Baker wrote: Jim Logajan wrote: Alan Baker wrote: The only thing that matter was thrust line. You've managed to make the same incorrect claim at least twice (that I've counted) in one thread. Are you sure you aren't overlooking something? I'm will to entertain that possibility. What do you think I'm overlooking? That the aircraft are moving through a fluid, not a vacuum. So things like propwash affect a tractor differently than a pusher. In my own analysis of the two types and their engine on versus engine off dynamics, the thrust line has not been "the only thing that matter[s]." It is more complex, and the texts I have handy do not make the situation appear as simple as you claim. If thrust line moment arm (relative to the c.g.) were all that mattered, then the following two bottle rocket firework designs would fly the same paths, mass, impulse curve, c.g., and thrust moment arm being held the same: (A) ----------------+-----+ |=====] (B) +-----+---------------- |=====] The attachments to the sticks are made so that the moment arms relative to the c.g. are otherwise identical, but in (B) the thrust is opposite its usual direction. Now in a vacuum I would expect them to fly the same paths and would be surprised if they didn't do that. But in a fluid like the atmosphere? Would you expect them to fly the same or different paths? Frankly, I would be surprised if they did fly the same - but as I don't have any fireworks handy at the moment I haven't gone outside to have fun, er, run experiments to observe their behavior. Sorry, but you're proceeding from two wrong assumptions. There is no dispute on your two points below. I'm glad to see you understand about dynamic pressure - it was not evident (to me at least) in your earlier posts. The problem still remains that your claim that the "only thing that matter[s] was thrust line" is incompatible with the aerodynamic differences between a tractor and pusher. You either read past my second sentence "So things like propwash..." and it didn't register or you did read it but still don't understand what you "overlooked." So here is again (in expanded form) what I think you overlooked: Because tractor propwash generates forces on any aircraft surfaces in its wake, so far as I know, no amount of thrust line adjustment can ever eliminate the flight character differences between tractor and pusher airplanes. 1. Your A and B examples would both behave the same in flight if their centres of mass were both the same. It is the aerodynamic centre of pressure moving ahead of the centre of mass that would cause B to be unstable and A stable, if we operate from the assumption that the only parts involved are the rocket and the stick. 2. In specific, both of the aircraft in this case are stable. They are both stable because the aerodynamic centre of pressure is behind the centre of mass and because the centre of lift of the main wing is behind the centre of gravity. Thus, your assumption that a change in the engines location matters is based on the erroneous assumption that such a change is being made in isolation. |
Shaw Flaw | The Old Guy | Aviation Photos | 0 | September 16th 08 05:18 AM |
Lancair Legacy | Joaquin | Home Built | 22 | November 13th 06 09:06 AM |
BWB has finished his Lancair Legacy... | John Ammeter | Home Built | 1 | June 6th 06 04:11 AM |
Lancair Legacy 2000 | Randy L. | Simulators | 6 | October 9th 03 09:56 PM |
