At 03:39 03 November 2008, 309 wrote:
Well...the VL gets run about twice a month...and had been up for a bit of time before flight or comparison with the Garmin. And I try to give it time to obtain an almanac (hoping this will update ephemeris data) before flying. This seems odd, based on the explanations above, the Garmin appears to be displaying UTC, since it lines up well with the Atomic clock and the Naval Observatory...so it has the 14 seconds added (?), or are they subtracted...or is time relative??? (pun intended). Is the VL then displaying GPS time (ahead of UTC)? ....or am I using the wrong sign convention -- leap seconds inserted into UTC make it BEHIND GPS time? Here I thought I'd found a way to make my 1-26 14 seconds faster... Or is that Slower? -Pete UTC=GPS+Leap Seconds. For a UTC (=GMT) reference try http://wwp.greenwichmeantime.com/ The Volkslogger uses 'GPS Time' in the GPS Engine, but adds Leap Seconds before recording the time. Try using the VL's Pilot Event Marker to mark the trace at a minute change as shown on the above site, download the trace and see what time is recorded for the PEV. - Tim Newport-Peace > Skype: specialist_systems http://www.spsys.demon.co.uk/icom.htm |
On Nov 3, 1:30*am, Tim Newport-Peace
wrote: UTC=GPS+Leap Seconds. For a UTC (=GMT) reference try *http://wwp.greenwichmeantime.com/ The Volkslogger uses 'GPS Time' in the GPS Engine, but adds Leap Seconds before recording the time. Thanks...I'll try the "event marker" experiment next chance I get. FYI, my watch (synchronized to the Garmin GPS unit) matches pretty damn closely to the grenwichmeantime.com link (and the US atomic clock and the US Naval Observatory clock...) and this is ~14 seconds BEHIND the reading of the VL. Using the equation above, Leap seconds would be negative (i.e., the clock with the leap second correction - GMT- reads an earlier time than one without leap seconds). So at the same moment in time, the readings are as below: Garmin = 00:01:15 = watch = GMT = US Atomic = USNO (???) VL = 00:01:30 Yes, I see the seconds in the IGC file...I'm using that for performing airspeed system calibrations. I'll try to see how the event marker synch's with GMT vs. VL vs. Watch... Now here's a different question: does anybody know how to take an IGC file (or SeeYou treatment of it) and derive north-south and east-west velocities? This would be useful in determining the pitot-static errors by flying a constant bank angle circle: Plot north-south/east west velocities and you get a circle -- the center gives you the wind and the radius is the true airspeed. If you want more info on that, say so and I'll try to find the references online. For now, I've been using the GPS-Horseshoe Heading technique...which uses more gas, but gives a good opportunity to measure cruise performance...for a tug or other power plane. -Pete |
At 08:21 04 November 2008, 309 wrote:
On Nov 3, 1:30=A0am, Tim Newport-Peace wrote: UTC=3DGPS+Leap Seconds. For a UTC (=3DGMT) reference try =A0http://wwp.greenwichmeantime.com/ The Volkslogger uses 'GPS Time' in the GPS Engine, but adds Leap Seconds before recording the time. Thanks...I'll try the "event marker" experiment next chance I get. FYI, my watch (synchronized to the Garmin GPS unit) matches pretty damn closely to the grenwichmeantime.com link (and the US atomic clock and the US Naval Observatory clock...) and this is ~14 seconds BEHIND the reading of the VL. Using the equation above, Leap seconds would be negative (i.e., the clock with the leap second correction - GMT- reads an earlier time than one without leap seconds). So at the same moment in time, the readings are as below: Garmin =3D 00:01:15 =3D watch =3D GMT =3D US Atomic =3D USNO (???) VL =3D 00:01:30 Yes, I see the seconds in the IGC file...I'm using that for performing airspeed system calibrations. I'll try to see how the event marker synch's with GMT vs. VL vs. Watch... The point to remember is that when you add in a Leap Second, it makes the minute one second longer and delays the start of the next minute. This will result in UTC being slower by one second for each Leap Second added. Now here's a different question: does anybody know how to take an IGC file (or SeeYou treatment of it) and derive north-south and east-west velocities? This would be useful in determining the pitot-static errors by flying a constant bank angle circle: Plot north-south/east west velocities and you get a circle -- the center gives you the wind and the radius is the true airspeed. If you want more info on that, say so and I'll try to find the references online. For now, I've been using the GPS-Horseshoe Heading technique...which uses more gas, but gives a good opportunity to measure cruise performance...for a tug or other power plane. -Pete This is probably better in a new thread, however... The B-record in the IGC file (records starting with the letter B) contain Time (6 bytes), Latitude (8 bytes), Longitude (Longitude (9 bytes) and a Fix Valid flag. Ignore records where the fix valid flag is "V" only use records where the fix valid flag is "A". You can now extract the Time, Latitude and Longitude differences between two records and calculate the N-S and E-W speed in degrees/second. If you want to translate degrees into metres, it is too complex to explain in a newsgroup but look at Ed Williams' Aviation Formulary at http://williams.best.vwh.net/avform.htm - Tim Newport-Peace > Skype: specialist_systems http://www.spsys.demon.co.uk/icom.htm |
Daylight Savings Time (Was: American Airlines - Last one standing) | Bob Noel | Piloting | 4 | October 1st 05 09:30 PM |
Daylight Savings Time | Bob Fry | Piloting | 0 | September 17th 05 07:27 PM |
Losing TIS Sites | Chuck | Owning | 0 | July 1st 05 09:28 PM |
Losing my Clearcoat | Robert M. Gary | Piloting | 9 | March 3rd 04 07:36 PM |
Were AC-130s used in daylight in Afghanistan? | Ron | Military Aviation | 0 | November 12th 03 12:16 AM |
