![]() Martin Gregorie wrote: * * * "Thats why you NEVER push a glider by its wingtips." From DG: Pulling an aircraft von friedelweber am Do Okt 25, 2007 1:36 pm Is it okay to pull an aircraft on the wingtips? The question tends to pop up in the gliding society. There is always a concern that wings could suffer damage if the ground crew pulls on the wingtips. Therefore we’d like to give you a short insight – without going into too much detail – on the force that can be applied in a longitudinal direction. Water tanks and other specific items are left out in this abbreviated description. The length of the lever enable to calculate the max. force a wing has to withstand without suffering any damages. The building describes a force of 400N as specification for every glider. This will result in a force of 40kp (longitudinal). A normal adult will commonly not be able to develop a force of 40kp in a longitudinal direction without any problems. In other words – it is save to pull a plane on its wingtips. |
This March while at the Marfa Wave Camp, I was helping Dick Johnson move his
glider and he said just grab the tip and we will move it. Someone said something about that and he said, "you can't put enough load on it to hurt it"; if Dick says it is ok, it is ok in my book. Fred "brianDG303" wrote in message ... Martin Gregorie wrote: "Thats why you NEVER push a glider by its wingtips." From DG: Pulling an aircraft von friedelweber am Do Okt 25, 2007 1:36 pm Is it okay to pull an aircraft on the wingtips? The question tends to pop up in the gliding society. There is always a concern that wings could suffer damage if the ground crew pulls on the wingtips. Therefore we’d like to give you a short insight – without going into too much detail – on the force that can be applied in a longitudinal direction. Water tanks and other specific items are left out in this abbreviated description. The length of the lever enable to calculate the max. force a wing has to withstand without suffering any damages. The building describes a force of 400N as specification for every glider. This will result in a force of 40kp (longitudinal). A normal adult will commonly not be able to develop a force of 40kp in a longitudinal direction without any problems. In other words – it is save to pull a plane on its wingtips. |
Duo Discus Wing Wheel -- not Dolly | [email protected] | Soaring | 0 | November 1st 07 03:57 AM |
Schweizer 2-33 Wing Tip Wheel Mounts | Mike McCarron | Soaring | 1 | October 7th 07 06:05 PM |
Tow-Out Wing Wheel | [email protected] | Soaring | 0 | July 13th 06 11:49 PM |
Ventus 2 wing wheel | [email protected] | Soaring | 4 | May 9th 06 08:58 PM |
Winter project | [email protected] | Soaring | 10 | January 2nd 05 01:11 PM |
