On Sun, 21 Dec 2003 21:00:20 +0000, phil hunt wrote:
On Sat, 20 Dec 2003 12:34:10 -0800, pervect wrote: On Sat, 20 Dec 2003 18:15:56 +0000, ess (phil hunt) wrote: If you don't go to spread-spectrum, your radio links will probably be jammed. (Solution - go to spread spectrum). Indeed. Then you need to use relatively high frequencies, and your radio navigation system will be line-of-sight only. This then means you need lots of closely-spaced transmitters, especially if you want to be able to navigate while flying at low altitude. I'd still rate a radio location system using spread spectrum transmitters as rather vulnerable, because the transmitters have to remain in a fixed location for the system to work, and would be prime targets. What if most of the transimtters are turned off most of the time? If there are fake transmitters, there to soak up hits, and (hopefully) entice enemy aircraft to put themselves in danger? Then your radio navigation system has gotten a lot more complicated. You can't just set up transmitters at arbitrary locations broadcasting at arbitrary times -- to work, a radio navigation system needs known transmitters at precisely known locations. Say 80 percent of your transmitters are turned off at any one time. Then you need five times as many transmitters in total, so that you can get complete coverage in the area where you want to navigate with only 20 percent of them. If you set up fake transmitters to attract attention away from the real ones, you also need to somehow avoid spoofing your own weapons. It would kind of suck if all of your HLCCMs flew off to the wrong place because they were navigating using signals from a fake transmitter. ljd |
Australia F111 to be scrapped!! | John Cook | Military Aviation | 35 | November 10th 03 11:46 PM |
