The term "Fighter"
Old December 22nd 03, 09:25 PM
Prowlus
Default The term "Fighter"
What does it mean nowadays with the introduction of multirole fighters
.. Does it mean :
(1) An aircraft tasked with destroying other enemy aircraft ie Tornado
F.3
(2) An aircraft that is tasked with destroying enemy military hardware
including: SAM sites, AA Guns , tanks and other aircraft on the ground
or in the air IE most of the USAF/USN fastjet tactical inventory with
the exception of the A-10
Has the term become diluted over the years to mean an aircraft that
can destroy most GENERAL militery hardware?
Old December 22nd 03, 10:22 PM
Cub Driver
I have seen articles and even books that include bombers such as the
B-17 under the rubric of "fighter."
To somebody utterly naive about warfare, "fighter" is just another
term for "warplane."
all the best -- Dan Ford
email:
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old December 23rd 03, 02:20 AM
Paul F Austin
_Small_warplane, generally with a small crew and no facilities for getting
up to go to the bathroom.
Old December 23rd 03, 03:14 AM
Lyle
On Mon, 22 Dec 2003 21:20:36 -0500, "Paul F Austin"
there was the xb-40, and yb-40 armed escorts
Old December 23rd 03, 08:13 AM
robert arndt
Lyle wrote in message . ..
Back in the good old days fighters had P designations (for Patrol or
Pursuit, depending on who you talk to)... but then someone decided to
strap some bombs onto the aircraft and then along came the
fighter-bombers, which today would simply be an attack aircraft.
The Germans really changed everything with the Fw 190 and Ju 88 which
were true multirole aircraft.
Post WW2 the new USAF started reclassifying aircraft for simplicity
sake:
F= Fighter
B= Bomber
A= Attack
C= Cargo
R= Recon
TR= Tactical Recon
SR= Strategic Recon
U= Utility (cover for U-2, which really was a jet sailplane)
and so on...
But as the dedicated air superiority fighters started having to double
as attack aircraft the now idiotic F/A designation is applied to
purpose-built multirole aircraft like the F/A 18 Hornet and F/A 22
Raptor while the multirole capable F-16 Falcon and F-15E Strike Eagle
remain under the F designation.
I think our designation system is in need of redefinition. Why not use
an MR designation for MultiRole aircraft? I suggest the following
changes:
AS= Air Superiority
B= Bomber
S= Strike
MR= MultiRole
C= Cargo
R= Recon
TR= Tactical Recon
SR= Strategic Recon
GR= Global Recon
FX= Field-Effects craft
NFX= Nuclear Field-Effects craft
UAV= Unmanned Aerial Vehicle
AAV= Autonomous Aerial Vehicle
UCAV= Unmanned Combat Aerial Vehicle
ACAV= Autonomous Combat Aerial Vehicle
MAV= Micro Aerial Vehicle
Rob
Old December 23rd 03, 09:34 AM
Errol Cavit
"robert arndt" wrote in message
om...
snip
No, it needs for the system to be followed. There is an excuse for the
F/A-18, but not for F/A-22 (_reason_ yes, excuse no). AIUI the system
defines aircraft with F and A roles as F's
Why not use
You mean like the M? e.g. MH-53E, MH-60R, MH-60S. Don't know if it can be
used as the 'primary' letter, and can't be bothered looking in the FAQ to
check.
changes:
snip suggested over-long designation system
Currently Q is drone. Some changes in this area would probably be useful
before too long.
Errol Cavit |
I've heard a tape of collected kakapo noises, and it's almost impossible to
believe that it all just comes from a bird, or indeed any kind of animal.
Pink Floyd studio out-takes perhaps, but not a parrot.
Douglas Adams, _Last Chance to See_
Old December 23rd 03, 04:23 PM
robert arndt
"Errol Cavit" wrote in message ...
om...
snip
That's my point. A Fighter should be an F and stick to air superiority
only. Strike aircraft should be an A (Attack) and be tasked with
hitting ground targets. Any aircraft that performs dual roles should
fall under the MR designation denoting MultiRole. I think MR is much
better than F/A. It was just annoying when they started using that on
the Hornet but now it seems idiotic with the Raptor. The Raptor was
supposed to be THE air superiority fighter of the USAF with a simple
F-22 designation. Then when the program started slipping and proving
costly they switched the designation over to F/A-22 in an effort to
sell us a multirole aircraft to justify the costs. Soon, there will be
the even more idiotic FB-22 which is puzzling since they drop the
slash when a fighter is transformed into a bomber. Then, of course, is
the other designation problem of the F-117, which is actually a strike
aircraft and should be A-117. This stealth craft has NO fighter
capability at all. And you say we need to enforce the current
designations?
Why not use
check.
Doubling of letters doesn't eliminate that combo. What about the
CH-53?
changes:
before too long.
There HAS to be as unmanned aircraft come in a complex variety of
forms: drone (towed or remote piloted), true RPVs, true UAVs, the
coming UCAVs, and those UAVs designed for global loitering. The Q
designation doesn't make a lot of sense here. The unmanned nature of
all these should produce another designation either in general not
just lump all of them into the UAV category. UAVs and UCAVs are
evolving into different types. Ordinary UAVs perform a mission,
usually recon and are controlled. What happens when the UAVs are given
autonomous capability to search where they want, loiter, and return to
an area of their choosing?
And what about Germany's UAV hunting trio Brevel, Mucke, Taifun? The
Germans, who will introduce this system by 2005/6 use the Brevel for
recon, Mucke then jams the target, while the armed Taifun kamikaze
dives onto it. All are current considered UAVs independently but form
a UCAV system as a trio. The Taifun then in reality isn't even a UCAV
since it is not intended to survive- it is a KV (KillVehicle).
Think about that.
Rob
Old December 23rd 03, 09:24 PM
Emmanuel.Gustin
Prowlus wrote:
: Has the term become diluted over the years to mean an aircraft that
: can destroy most GENERAL militery hardware?
No. The reality has always been that an aircraft designed
to do air combat efficiently must be have good handling
qualities, high power reserves, good armament, robustness,
and spare lifting capacity. Ever since WWI, this has meant
that a good fighter can be very useful in other roles too.
Sopwith Camels made good attack aircraft and even
dive-bombers...
As fighters are the essential aircraft of an air force,
which is is almost impossible to do without, cuts tend
to be made in the other categories. The real onset of this
was during WWII, when fighters became so big and powerful
that they replaced first light and then also medium bombers,
although this process was not completed until after the
war. Naval air forces, that had to parcel out the limited
space on a carrier, were particularly quick to recognize
that a good fighter could be a decent bomber. In the 1930s
dual-role fighters-and-dive-bomber types were fashionable.
With few exceptions, pure fighters have been defensive
interceptors, often all-weather intereceptors with
expensive and fragile electronic systems. Even Spitfires
and Sabres were fitted with bomb racks as soon as their
operators could find the opportunity. These days, equipping
aircraft purely as fighters make little sense, even for
a rich air force such as the USAF; why not exploit all
the capabilities of a very expensive airframe?
Emmanuel Gustin
Old December 24th 03, 12:18 AM
Errol Cavit
(robert arndt) wrote in message . com...
om...
snip
You can physically hang a bomb any almost any fighter if you want to.
Remember the F-15 was "not a pound for air-to-ground"? Then some time
later came the F-15E.
I think MR is much
better than F/A.
Try reading what I wrote. This is not a problem with the designation
system, it's a problem with people doing non-sensical things based on
(but outside) the system. Redefining the system won't help much with
the issue of political fiddling.
capability at all.
There is also the tendency to not give new series letters, so we have
CC-130J rather than something sensible like C-130K, and significant
changes to the F-16 being shown by block numbers. Don't get me started
on the F-35.
designations?
I didn't say that. I say the issues would be far fewer if you enforced
the current _system_. Listing examples were people have done things
outside the system isn't an argument for changing the system.
Why not use
check.
CH-53?
The cargo-only versions of the H-53, as opposed to the Mine warfare +
cargo versions? What about them?
You would call the current CH-53E's MRH-53E? The current MH-53E's
would be MRH-53F or something?
changes:
before too long.
What's wrong with using Q as vehicle type = unmanned? If you make it
much more specific, you risk modifications to software or control
methods changing the primary designation for what is the same physical
vehicle. Perhaps a different letter if it is capable of fully
autonomous operation? Makes far more sense than
your TRUAV-1 for the Predator (currently it's RQ-1, you could argue
that the armed ones should be AQ-1 or ARQ-1).
Can the Taifun be recovered if it isn't 'fired'? If so, RQ-xxA,
EQ-xxB, and AQ-xxC. Or treat the Taifun as a guided missile and
designate accordingly. Why is this worse than your suggestion?
Think about that.
Think about how aircraft designs can develop, and all the
possibilities that have to be taken into account. Using 3 or 4 letter
acronyms parts of designations just doesn't make sense. That's why
code letters are used in the most current systems, not the
buzz-acronym of the moment.
Errol Cavit | "Pressures are put on governments to
satisfy their public's demand for immediate action. The intervention
in
Somalia was undoubtedly media led. It was disastrous. There is a
connection
between those two statements." Hudson & Stanier, 'War and the Media'
1997
Old December 24th 03, 03:54 AM
David L. Pulver
(Prowlus) wrote in message . com...
. Does it mean :
F.3
These days, "fighter" usually means "A single or dual-seat fast mover
capable or at least originally designed in some variant or other for
reasonably effectively performing an air superiority or intercept
mission, regardless of what else it can do" the reasonably-effectively
part translating into "at least mach 1, carries air-to-air missiles,
and ideally supersonic with a air-intercept radar" and the "what else"
usually being strike, recon, and SEAD.
There are instances when an aircraft receives a fighter *designation*
for unusual reasons (the F-117), but these are anomalies. Also F-111,
which was supposed to be a fighter but didn't work out as one, and
such.
Also, USAF tactical aviation doesn't like calling anything an "attack"
aircraft so aside from the A-10 (clearly not a real modern fighter,
being subsonic, even if it can carry a few sidewinders!) we get things
like F-105 ("It's a fighter because it's got a gun and is supersonic,
even if it's not used as one"). The Harrier and such get in the way a
bit, but Sea Harrier at least has an air-intercept radar, while the
other types are more attack aircraft
Questions Regarding Becoming a Marine Fighter Pilot. ? Thanks! Lee Shores Military Aviation 23 December 11th 03 10:49 PM
Veteran fighter pilots try to help close training gap Otis Willie Military Aviation 0 December 2nd 03 10:09 PM
Legendary fighter ace inspires young troops during Kunsan visit Otis Willie Military Aviation 1 October 9th 03 06:01 PM
48th Fighter Wing adds JDAM to F-15 arsenal Otis Willie Military Aviation 0 July 22nd 03 09:18 PM
Joint Russian-French 5th generation fighter? lihakirves Military Aviation 1 July 5th 03 01:36 AM
