Dudley Henriques wrote:
On Sat, 15 Nov 2008 23:11:33 -0600, cavelamb himself wrote: wrote: OK - got some more info. The center of mass is something like 34 inches behind the firewall and roughly 7 inches above the top engine mount point on the firewall. so roughly speeking 13 inches above the prop centerline. The prop flange with the O200 is 29.75 inches from the firewall. This means it is 63.75 inches from the prop flange to the CM.(center of mass) This means there is NO WAY the thrust line is aligned anywhere close to the center of mass. This would require a downward displacement of almost 15 degrees. THAT is not going to fly - PERIOD. We are hitting about 5.5 inches BELOW the center of mass If we aim for the middle of the rear stabilizer, about 183 inches from the prop flange, 1.5 degrees down is 5.5 inches above the prop center, which is about the middle of the rear of the fuselage and roughly 10 inches below the center of the rear horizontal stabilizer . If I want to hit the same spot with the engine down 1.5 inches, i need to change the angle to 1.875 degrees. 2 inches goes to 2 degrees. 2.5 inches would be 2.15 degrees, +/- 3 inches would be 2.31 degrees 4 inches would be 2.58 degrees. Does this make any sense?? It sounds right to me. I'd fly it. You would. But you have NEVER been known for your intelligence. ![]() ![]() -- Richard (remove the X to email) |
There is not one right answer here.
What we are looking for is predictible and managable responses. That's why the Cooper-Harper index exists and is written the way it is. http://en.wikipedia.org/wiki/Cooper-Harper_rating_scale |
On Tue, 18 Nov 2008 12:05:40 -0600, Jim Logajan
wrote: wrote: OK - got some more info. The center of mass is something like 34 inches behind the firewall and roughly 7 inches above the top engine mount point on the firewall. so roughly speeking 13 inches above the prop centerline. What is that the center of mass of, exactly? The empty airframe only (i.e. no engine)? Or is it the center of mass of a complete airplane (sans fuel, pilot, passenger, and baggage) with the engine mounted at the original point? I'm also curious as to how you determined the location in two dimensions. I can think of a few ways of determining it, but they all involve a bunch of effort. Center of mass for the completed plane when built to specs. Provided by the designer. |
On Wed, 19 Nov 2008 13:15:02 -0600, Jim Logajan
wrote: wrote: Jim Logajan wrote: wrote: OK - got some more info. The center of mass is something like 34 inches behind the firewall and roughly 7 inches above the top engine mount point on the firewall. so roughly speeking 13 inches above the prop centerline. What is that the center of mass of, exactly? The empty airframe only (i.e. no engine)? Or is it the center of mass of a complete airplane (sans fuel, pilot, passenger, and baggage) with the engine mounted at the original point? I'm also curious as to how you determined the location in two dimensions. I can think of a few ways of determining it, but they all involve a bunch of effort. Center of mass for the completed plane when built to specs. Provided by the designer. I don't suppose the designer was or is willing to provide general advice or guidance on mounting your engine? Sure beats asking total strangers on the net. :-) If I were in your position these are a few of the things I'd keep in mind: * The center of mass (CoM) of an empty airplane and full airplane are in different locations in three dimensions. In the two dimensions of interest, depending on how fuel, passengers, and baggage are loaded, it moves around in those two dimensions such that it is geometrically impossible to move engine "down" and find a single angle that yields the original moment arms for all load configurations. The one configuration I don't think I would use to compute engine mounting angle would be the empty configuration. * Moving the engine down relative to the original design specs also moves the empty airplane CoM down. Assuming the Corvair and O-200 are both the same weight of about 200 lbs, and assuming the empty weight of the plane is 815 lbs, then if the engine is moved D inches down, the CoM moves down D*200/815 inches. If D = 4, CoM moves down about 1 inch. * I don't know where the CoM of passengers and baggage would be, but they probably move CoM down (and presumably fuel moves it up). As an example, if all that usable load is about 600 lbs, then if that load's CoM is L inches below the empty airplane's CoM, the CoM of the whole airplane moves down L*600/(815+600). So if, for example, L = 5, then CoM moves down about 2 inches. So between lowering the engine and throwing in stuff, the CoM of the airplane in this configuration differs by about 3 inches from that used in the original empty airplane spec. But the load probably moved the CoM forward or backward too, affecting another variable in the equations. Fun, huh? * How much is the horizontal tail in the propwash? That and a different angle of incidence of the propwash on the fuselage might give me more down pitch than I calculated by assuming the only factor affected by the engine move and rotation was the thrust moment arm. I might also risk losing thrust efficiency because of increasing fuselage interference in the propwash. * At some point I'd realize that the CoM is variable enough that for the small amount I'd be moving the engine, it would probably be best to mount the engine so that the engine thrust line is aligned with the most natural fuselage longitudinal. Then make trim adjustments during the test flights. Thanks Jim. I just talted to a P.Eng who has a LOT of aeronautic experience and he said I likely would not notice any change, but he would cut the recommended 1.5 degrees roughly in half for my install... I don't think there will be any detrimental effect as far as propwash is concerned - might even improve very marginally. |
thrust line for engine and not mounting engine on this thrust line | tommyann | Home Built | 8 | December 15th 06 03:31 PM |
Has something changed | [email protected] | Soaring | 10 | May 3rd 05 08:34 PM |
High thrust line on canard design? | Shin Gou | Home Built | 4 | March 5th 05 03:06 AM |
Getting students to line up with the center line | BoDEAN | Piloting | 27 | April 21st 04 11:23 AM |
I want to tell you something that has changed my life! | C J Campbell | Owning | 11 | January 29th 04 11:34 PM |
