At 23:45 17 November 2008, Tuno wrote:
I am trying to parse ESRI shapefiles that describe FAA TFRs. But they are in NAD83 projections, with accompanying .prj files that look like this: PROJCS["North_America_Lambert_Conformal_Conic", GEOGCS["GCS_North_American_1983", DATUM["D_North_American_1983",SPHEROID["GRS_1980", 6378137.0,298.257222101]], PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]], PROJECTION["Lambert_Conformal_Conic"], PARAMETER["False_Easting",0.0], PARAMETER["False_Northing",0.0], PARAMETER["Central_Meridian",-93.13333333333335], PARAMETER["Standard_Parallel_1",47.41333914430852], PARAMETER["Standard_Parallel_2",47.43554955001912], PARAMETER["Latitude_Of_Origin",40.0],UNIT["Meter",1.0] ] A partial text dump of the corresponding .shp file looks like this: Shape:8 (Polygon) nVertices=37, nParts=1 Bounds ![]() to ( 3703.999933,830843.274058, 0, 0) ( 0.00000000,830843.27405814, 0, 0) Ring (643.19289130,830787.00193647, 0, 0) (1266.84264658,830619.89536055, 0, 0) (1852.00012149,830347.03211620, 0, 0) (2380.88541892,829976.70258255, 0, 0) ... I have not been able to figure out how to use .prj parameters to transform the coordinates in the shapefiles to WGS84 (lat/lon) format. Seems to me it should be a rather simple formula. Anyone out there familiar with this problem? -ted/2NO I'm no guru, I don't know the inner workings of the shapefile format, but I think I can be of some help. It appears to me that your data is in datum NAD83, projected in Lambert Conformal Conic. I'm guessing that converting from LCC to WGS84 is not a simple formula. The question is, what do you actually want done? Converting a list of points like waypoints or track log from LCC to WGS84 is easy, converting airspace features and outputting as a coordinate list is another. (Maybe it is easy and I just don't know how and someone else can fill you in) But I recommend converting formats of entire files or parts of files using conventional instruments like MapWindow, a free and quite capable GIS program. Among other things, it can buffer (add rings at selected distances) points, maybe that is all you need to do with that TFR file... With a $25 added application it will convert text file coordinates to google earth files too! That and the "GPS Converter" page people have mentioned here before gets my data from anything to just about anything else. http://www.gpsvisualizer.com/convert_input Global Mapper for $200 is the do it all converter. I have it too but I use MapWindow most of the time. If it's just a one time conversion and you have a specific output format, you could send me the data I can convert it for you. |
Thanks Jim but that doesn't help either ... anything interactive (GUI
or otherwise) doesn't help; I need source code that I can compile in Linux and Windows (cygwin) environments... |
Digital airspace data question -- any FAA data gurus out there? | Tuno | Piloting | 2 | December 27th 07 05:06 PM |
CFII question for Approach Gurus | BillJ | Instrument Flight Rules | 57 | September 1st 07 04:59 PM |
question for tactics gurus | Moe | Naval Aviation | 7 | July 31st 06 06:38 PM |
Question for Net Gurus My New Aviation Videos | Jay Honeck | Piloting | 24 | December 19th 03 07:35 PM |
