#281
On 21 Dec 2003 17:57:58 -0800, George William Herbert wrote:
phil hunt wrote: Which requirements am I underestimating? (Bear in mind I'm considering missiles for several different roles). Let me give you an example... assume that you need a certain pixel width of an object to successfully identify it (say, 10 pixels across) with a certain contrast ratio. You also have certain limitations on the maneuverability of the airframe this is all one. It can't pull more than a certain number of G's etc. I can imaigne a small, light wooden airframe, designed for low detectability, pulling much lower Gs than a faster airframe, which might be made of metal. To successfully design the homing mechanism, you need to assess the distance and light or background noise conditions of the frequencies you're looking at (visual, IIR, whatever) and the magnification of the imaging system and its optical resolution. You need to have a wide enough field of view that you can see the targets as you fly along searching, but not so wide that you won't be able to discriminate a target until it's so close that maneuvering to hit it becomes a serious problem. I think that examining how nature has solved similar problems is useful. The human eye has lots of closely-placed pixels at the center, and in the periphery pixels are much more widely spread. Perhaps the system could use one (or more) wide angle lenses, and a (possibly movable) telephoto lens for giving more detailed attention to an object. You need to assess the impact on the sensor and field of view of the background coloration across the target areas, etc. Human eyes have 3 colours. There no reason in principle why an artificial eye would have that number. (Though if we are using cheap hardware, it probably would). If a vehicle is stationary, and camoflaged, it's going to be a *lot* harder to spot than a moving one. I think going for the ability to spot moving vehicles well, and stationary vehicles a lot less well, is adequate performance. With a much simpler system, laser spot homing, But who shines the laser on the right spot? Or are you assuming there's a human with a laser designator in the loop? I spent some months working out that nested set of problems. Taking one shortcut made the weapon not lock on if the ballistic miss trajectory was too far off. Taking another meant that it typically locked on early in a portion of its flight that led to it flying out of control as it lost energy trying to track the laser spot as it flew out. I'm not with you there... could you explain? It would scrub too much forwards velocity off early and then start to come down too short of the target and stall out trying to correct for that. Because it was manouvring too much at the start? You actually have to sit down, design a notional design, put a notional sensor on it, figure out what the parameters are, and simulate it for a while to see what the gotchas are. That makes sense -- I'm sure lots of things wouldn't work right first time. That requires models of the sensor, guidance, optics or transmitter, target behaviour, aerodynamics, and trajectory / movement dynamics of the weapon. Even getting a rough first pass of that to tell you what the roughly right answers are is nontrivial, can easily be months of work, and requires experience across a very wide range of diciplines (or a keen ability to figure out what you don't know and find it via research). How much are simulated environments used in designing missile homing systems? By a simulated environment, I mean the missile software is working as it would be on the real missile, but output instead of going to control surfaces, goes to a flight simulation program, and input, instead of coming from a visula sensor (or whatever) comes from a program which simulates what the output of that sensor would be under those conditions? But few of those have progressed to production. The new Marines/Navy Spike missile is one exception, This is the Israeli ATGM, isn't it? No, there are two missiles named Spike, And two named Javelin, incidently. and I'm referring to the US Navy / China Lake one. http://www.nawcwpns.navy.mil/~pao/pg...es/SpikeND.htm I can't load that URL. -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: , but first subtract 275 and reverse the last two letters). |
#282
Simon Morden wrote in message k...
Which is what I would suggest. No country could currently defeat the USA in a stand-up fight. So disperse your army globally and take out US-interest soft targets: embassies, companies, tourists, registered shipping, anything that flies a US flag. The losses would be sickening, and it makes me nauseous to think about the scenario. Especially if army elements managed to get on US soil. I see serious problems regarding command, control, communications, and morale of the dispersed army in such a situation. I also see another serious problem, in that you are buying yourself potential war with _every_ country that your dispersed army is operating on -- other countries are unlikely to take a very positive attitude towards your "soldiers" (they would more likely be viewed as "terrorists" or "homicidal maniacs") blowing themselves up on their soil to attack Americans. What is likely is that most of your "army" would defect or desert, a few attacks would be carried out alienating virtually the whole world against one, and your regime would finish their lives as criminals wanted by pretty much every country on Earth. Sincerely Yours, Jordan |
#283
![]() "George William Herbert" wrote Done properly, especially with one time pad encryption, one can handle this sort of situation. Consider... the use of CD-R's for pads. They give you 650 megabytes of storage. Assume one message of 1k contents per minute is sent; that works out to a bit over 43 megabytes of pad per month, or about 518 megabytes per year. Each receiving station can have its own pad and its own recipient keying. And then when one of those CD's gets lost or captured... Pete |
#284
"Carl Alex Friis Nielsen" wrote: The entire idea behind assymetric warfare is to refuse to play by the enemy's rules - so if fighting the US use a doctrine not reqirering an C3I infrastructure, which can be attacked - have lots of small dispersed units capable of operating on their own initiative. One problem here; totalitarian regimes tend not to tolerate lots of initiative in their underlings, which makes preparing for this sort of fighting somewhat harder. |
#285
On Mon, 22 Dec 2003 15:48:46 GMT, Fred J. McCall
wrote: pervect wrote: :On Mon, 22 Dec 2003 08:45:07 GMT, (Derek :Lyons) wrote: : (George William Herbert) wrote: : :This is all pretty easy to jam, since the frequencies are :all known beforehand, but that general *approach* is very :hard to penetrate with traffic analysis. : :note: This is more-or-less how the SSBN comm system works in fact. : :It's hard to penetrate with traffic analysis, yes. However a station :transmitting 24/7 is a station that's easily located, and a station :that will eat a gross of ordinance at H hour + .01 second. : :So everyobody goes on red alert as soon as the primary station stops :broadcasting, and the targetting information has to be sent by the :second backup station. Then we're back to traffic analysis. If they stay up, they get killed. If they don't stay up, coming up tells you something is going on. No way around that. Actually there's something I forgot to mention - using similar spread spectrum techniques as, for instance, GPS, it will in general be fairly hard to tell that a high tech wide bandwidth low power transmitter is "up" at all. So even the 24 hour radiating link might not be terribly conspicuous from an emissions point of view. And the backup links will be even less conspicuous. OTOH I would guess that good (high altitude with good field of view) locations for antenna systems will be bombed as a matter of principle, including anything that even looks like an antenna farm. In any event, one of the first profitable investments for Elbonia might be a modern C&C infrastructure that will be hard to monitor, spoof, or take down. |
#286
#287
pervect wrote:
:Actually there's something I forgot to mention - using similar spread :spectrum techniques as, for instance, GPS, it will in general be :fairly hard to tell that a high tech wide bandwidth low power :transmitter is "up" at all. So we've established the following so far in this discussion: 1) Tanks can't kill anything, since it can dodge. 2) ECM doesn't work. There was another equally silly one, but I forget what it was. No matter. Even trolls should know more about their subject than we're seeing demonstrated here. -- "Nekubi o kaite was ikenai" ["It does not do to slit the throat of a sleeping man."] -- Admiral Yamamoto |
#288
"John" writes: "Duke of URL" macbenahATkdsiDOTnet wrote John's cutesy-pie combat methods were interesting, slightly, but suited to a 1930's Boys' Book of How to Have a War. Everything after the SUV/otto-76 was a bit tongue in cheek though. Peter did a fine job of dismissing them all. In the case of the SUVs Peter didn't.. To dodge a tank round all you need do is side-step half the width of your vehicle. Claiming that the tanks will close to ploint blank range is stupid when they are facing concentrated AT fire. I'm also not sure he understood the potential of the Otto-76 to shoot down smart munitions. Actually, John, you don't seem to have much of an understanding of how tanks work, or what the typical engangement ranges are. Five miles is right out. The longest range kill achieved by a tank to date is a 3,000m (roughlt 1.5 Statute Mile shot by a British Challenger II vs. an Iraqi T72 in the 1990-91 Gulf War. Even in open country like Iraq, the usual longest range for a Main Gun shot on an opposing tank was 2000m. In a European rural environment, the most likely engagement range would be 1000m. In more closed country, like, say, the Northeastern U.S., or Maritime Canada, engagement ranges as close as 50-100m are not unlikely. (Lots of irregular terrain, lots of trees & brush - European forests are like gardens in comparison.) Engagement ranges within urban areas are very short - usually on the order of 200m or so. Time of Flight for a main gun round to 2000m is about 1.2 seconds. Time of Flight to 200m, is (Wait for it - 0.12 seconds. Now, Sport, How much are you going to be dodging your SUV in 1.2 seconds. Be aware that you'll have to shave at least 0.5 seconds off of that for the driver's reaction time. Also consider that your millimeter-wave emitting SUV is ligking itself up like a neon sign in a part of the radio spectrum that nothing else is on. A couple of sinple horn antannae on the turret sides (Sort of like the old coincidence rangefinder ears) for DFing, and an omnidirectional antenna up with the Wind Sensor on the turret roof for general detection, and you won't, say, be able to hide your Tank-Killer SUV in Madman Morris's SUV Dealership's parking lot. And I especially agree with the last one - countries where all the citizens are heavily armed are not countries like Iraq, where people the ruler doesn't like get fed alive into shredding machines. So they aren't the kind of country we'd be needing to invade. However the question wasn't about poor countries, but middle-ranking ones, which I took to mean ones comparable to most european nations. Of such I'd say only Britian or France had the capacity to blunt a US attack, and only because they can both MIRV task-forces whilst they cross the atlantic. Nuclear buckshot will kill most things, and doesn't need to be too accurate either. Time of Flight of IRBM, 30 minutes. Speed of CVBG, 25 kts. Detection of launch, instantaneous. DSP Sats, y'know. Radius of circle that could contain the target - 12.5 Nautical Miles. U.S. Supply Convoys hump along at 20 kts, these days, so you're looking at a 10 NM circle there. Time of arrival of U.S. ICBM ('cause we're Nice Guys, and aren't going to unleacsh somethig on the order of 10 Trident MIRVs on your country, and only take out single targets, roughtly 1.0-1.5 hours after launch. Your Command Centers and missile bases, or Missile Sub ports don't move, and you made the mistake of going Nuclear first. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#289
On Sun, 21 Dec 2003 15:46:29 GMT, Fred J. McCall
wrote: "Pete" wrote: : :"phil hunt" wrote : : I imagine the missiles could : be programmed for a mission by sticking a computer with an Ethernet : cable into a slot on the missile. : :Here ya go. Code to this explanation, and you're all set. : :http://www.techblvd.com/Rvideo/Guidance.wav : :Easy. What's really spooky is that this isn't all that bad a description of how ProNav works. :-) what's ProNav? |
Australia F111 to be scrapped!! | John Cook | Military Aviation | 35 | November 10th 03 11:46 PM |
