Anyone preserved a bare fuselage? Cosmoline?
Old November 23rd 08, 12:47 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Anyone preserved a bare fuselage? Cosmoline?
On Sun, 23 Nov 2008 20:41:51 +0900, Stealth Pilot
On Sat, 22 Nov 2008 17:29:37 -0500, Michael Horowitz
On Sun, 01 Jun 2008 22:05:40 +0800, Stealth Pilot
but ummmm. isnt the surface a dark rusted colour anyway.
Stealth Pilot
Stealth - recall that what I'm doing is sandblasting/wirebrushing a
small section at a time and coming back to it a month later to do
another small section. The turp/oil mix is to protect the surface
until the whole fuselage is blasted/brushed at which time I'll remove
the turp/oil mix and apply (probably) two part epoxy. So to answer
your query, after blasting/brushing, no, it will be frosty steel color
- Mike
Old November 23rd 08, 06:56 PM posted to rec.aviation.homebuilt
On Sun, 23 Nov 2008 07:47:33 -0500, Michael Horowitz
Stealth Pilot
- Mike
Use a light wash of cheap rust paint. Aluminum TremClad will wash off
with thinners or gasoline even after several years.Colours are not
much better.
Mix it with your Turps/linseed if you like
Old November 23rd 08, 07:07 PM posted to rec.aviation.homebuilt
John Kimmel
- Mike
If you're blasting a small section at a time, why don't you just prime it as you go along, then touch it up when it's done? The paint
will stick a lot better to freshly blasted metal and you'll save yourself a lot of work.
John Kimmel
I think it will be quiet around here now. So long.
Old November 24th 08, 09:47 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sun, 23 Nov 2008 11:07:14 -0800, John Kimmel
- Mike
that advise is probably the best.
you can mix the epoxy primer in small amounts quite easily.
I used a small revell aeromodellers airbrush to spray on the primer.
almost no overspray, minimal solvent smells, and no slower than any
other technique.
Stealth Pilot
Looking for a fuselage Jay Honeck Home Built 79 March 7th 05 01:42 PM
Bare Bones X-C Cub Driver Piloting 3 August 3rd 04 09:17 AM
Brand New Bell 47 Spider Still Packed in Cosmoline ---- What's It Worth? Larry Smith Rotorcraft 1 December 25th 03 12:45 PM
Preserved Asso 500 engines - pictures Vicente Vazquez Restoration 0 November 21st 03 07:20 PM
