How does fuel (safely) get from the tank to the engine?
Old November 25th 08, 11:11 PM posted to rec.aviation.homebuilt
Bob Kuykendall
Default How does fuel (safely) get from the tank to the engine?
On Nov 25, 2:53*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
Do any of the experimental aircraft designs use just a simple hose with a
weight that follows the fuel...
Yes. It's called a "flop tube."
Thanks, Bob K.
Old November 26th 08, 12:27 AM posted to rec.aviation.homebuilt
Ed
On Tue, 25 Nov 2008 15:11:12 -0800 (PST), Bob Kuykendall
Thanks, Bob K.
They are getting a little pricey lately, around $55 at Aircraft Spruce
Old November 26th 08, 02:24 AM posted to rec.aviation.homebuilt
Maxwell[_2_]
"Bob Kuykendall" wrote in message
Thanks, Bob K.
Duh? I misread your post.
Although you described it as a hose, when you called it a flop "tube", I
pictured a mechanical tube or arm.
Old November 26th 08, 03:22 AM posted to rec.aviation.homebuilt
Thanks, Bob K.
In aircraft use, generally it IS a tube, not a hose.
Old November 28th 08, 03:42 AM posted to rec.aviation.homebuilt
news:e86e607e-2544-4029-814c-4d581e42e__BEGIN_MASK_n#9g02mG7!__...__END_MASK_i ...
Thanks, Bob K.
One also needs to perform similar magic with the oil system if
inversion longer than a few seconds is contemplated.
Actually, its surprising how long the engine will keep running after
forgetting to switch to the acro tank. I've made halfway into an
acro routine before being surprised by the sudden silence. ;-)
K l e i n
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg [email protected] Aviation Photos 0 April 12th 07 01:33 AM
Fuel tank balance Mxsmanic Piloting 101 October 3rd 06 07:56 AM
Engine driven fuel pump necessary with gravity feed tank?? Lycoming RonLee Home Built 2 May 8th 05 06:10 PM
fuel tank plumbing pwm Home Built 18 January 27th 05 04:54 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
