How does fuel (safely) get from the tank to the engine?
Old November 25th 08, 05:23 PM posted to rec.aviation.homebuilt
Oliver Arend
Default How does fuel (safely) get from the tank to the engine?
It would seem logical to just draw gas from the lowest point of the
tank into a fuel line leading to the engine. But contrary to a car, an
airplane can experience negative gs, and especially in aerobatics, for
prolonged periods of time. So a pump connected to the lowest point of
the tank would only draw fumes at some point. How is this problem
solved?
Thanks (again) for enlightening me,
Oliver
Old November 25th 08, 07:37 PM posted to rec.aviation.homebuilt
Bob Kuykendall
On Nov 25, 9:23*am, Oliver Arend wrote:
an airplane can experience negative gs...
During which times the engines of most airplanes just sputter.
Aerobatic airplanes usually have at least one tank with the fuel
pickup on a flexible hose that follows the fuel. That's usually called
a "flop tube."
Thanks, Bob K.
Old November 25th 08, 10:53 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
"Bob Kuykendall" wrote in message
a "flop tube."
Thanks, Bob K.
Do any of the experimental aircraft designs use just a simple hose with a
weight that follows the fuel. It's very successful in modeling. You just
stick a weighted fitting on the end of the hose called a "clunk".
Old November 25th 08, 11:11 PM posted to rec.aviation.homebuilt
Bob Kuykendall
weight that follows the fuel...
Yes. It's called a "flop tube."
Thanks, Bob K.
Old November 26th 08, 12:27 AM posted to rec.aviation.homebuilt
Ed
On Tue, 25 Nov 2008 15:11:12 -0800 (PST), Bob Kuykendall
Thanks, Bob K.
They are getting a little pricey lately, around $55 at Aircraft Spruce
Old November 26th 08, 02:24 AM posted to rec.aviation.homebuilt
Maxwell[_2_]
Thanks, Bob K.
Duh? I misread your post.
Although you described it as a hose, when you called it a flop "tube", I
pictured a mechanical tube or arm.
Old November 26th 08, 03:22 AM posted to rec.aviation.homebuilt
Thanks, Bob K.
In aircraft use, generally it IS a tube, not a hose.
Old November 28th 08, 03:42 AM posted to rec.aviation.homebuilt
news:e86e607e-2544-4029-814c-4d581e42e__BEGIN_MASK_n#9g02mG7!__...__END_MASK_i ...
Thanks, Bob K.
One also needs to perform similar magic with the oil system if
inversion longer than a few seconds is contemplated.
Actually, its surprising how long the engine will keep running after
forgetting to switch to the acro tank. I've made halfway into an
acro routine before being surprised by the sudden silence. ;-)
K l e i n
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg [email protected] Aviation Photos 0 April 12th 07 01:33 AM
Fuel tank balance Mxsmanic Piloting 101 October 3rd 06 07:56 AM
Engine driven fuel pump necessary with gravity feed tank?? Lycoming RonLee Home Built 2 May 8th 05 06:10 PM
fuel tank plumbing pwm Home Built 18 January 27th 05 04:54 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
