DRN wrote:
On Nov 26, 11:32 am, Andy wrote: http://www.nadler.com/public/ventus2...ke%20cable.htm Man that's ugly! Why would anyone ruin a great hydraulic disc brake by actuating the master cylinder with a bicycle cable? Andy That is a very good question. Antares uses a direct mechanical connection from spoiler pushrod to master-cylinder actuation lever, no Bowden cable. A Bowden cable is a SPRING, and bicycle-grade is really silly in these applications (especially 8 foot long with a Tost "wheel brake"). I believe SH has upgraded new production to use Beringer parts; hopefully they have stopped doing this on the actuation side... See ya, Dave "YO electric" No, still using the bicycle cable with the Beringer system. See the installation instructions he http://schempp-hirth.com/fileadmin/t...49-33-2444.pdf |
On Nov 26, 12:27*pm, Greg Arnold wrote:
DRN wrote: On Nov 26, 11:32 am, Andy wrote: http://www.nadler.com/public/ventus2...ke%20cable.htm Man that's ugly! Why would anyone ruin a great hydraulic disc brake by actuating the master cylinder with a bicycle cable? Andy That is a very good question. Antares uses a direct mechanical connection from spoiler pushrod to master-cylinder actuation lever, no Bowden cable. A Bowden cable is a SPRING, and bicycle-grade is really silly in these applications (especially 8 foot long with a Tost "wheel brake"). I believe SH has upgraded new production to use Beringer parts; hopefully they have stopped doing this on the actuation side... See ya, Dave "YO electric" No, still using the bicycle cable with the Beringer system. *See the installation instructions he http://schempp-hirth.com/fileadmin/t...49-33-2444.pdf Aaarggg - It does work adequately with a beefier Bowden cable... |
DRN wrote:
On Nov 26, 12:27 pm, Greg Arnold wrote: DRN wrote: On Nov 26, 11:32 am, Andy wrote: http://www.nadler.com/public/ventus2...ke%20cable.htm Man that's ugly! Why would anyone ruin a great hydraulic disc brake by actuating the master cylinder with a bicycle cable? Andy That is a very good question. Antares uses a direct mechanical connection from spoiler pushrod to master-cylinder actuation lever, no Bowden cable. A Bowden cable is a SPRING, and bicycle-grade is really silly in these applications (especially 8 foot long with a Tost "wheel brake"). I believe SH has upgraded new production to use Beringer parts; hopefully they have stopped doing this on the actuation side... See ya, Dave "YO electric" No, still using the bicycle cable with the Beringer system. See the installation instructions he http://schempp-hirth.com/fileadmin/t...49-33-2444.pdf Aaarggg - It does work adequately with a beefier Bowden cable... I upgraded to a disc brake on my 20-year-old Discus. I have the very same issues there, and haven't had any good ideas about how to upgrade to a beefier Bowden cable (motorcycle cable?) that still will work with the fittings designed for the bicycle cable. Also, I have wondered how a stiffer cable would affect the feel at the stick -- seems it would be stiffer in pitch. |
On Nov 26, 12:42*pm, Greg Arnold wrote:
I upgraded to a disc brake on my 20-year-old Discus. *I have the very same issues there, and haven't had any good ideas about how to upgrade to a beefier Bowden cable (motorcycle cable?) that still will work with the fittings designed for the bicycle cable. * You do need to change a few fittings. Also, I have wondered how a stiffer cable would affect the feel at the stick -- seems it would be stiffer in pitch. No change if the cable is routed carefully... If you feel any change don't fly it ! Hope that helps, Best Regards, Dave "YO electric" |
I upgraded the cable on my 38 year old Std Cirrus.
My replacement is the rear brake cable from a Honda motorcycle. Had to cut the fitting off one end and fit a ferrule after threading through the whole system. Reward is a noticeable improvement. i.e. there is some retardation from the ridiculous Tost Lilliput wheel. Generally good for two good stops between adjustments... Greg Arnold wrote: DRN wrote: On Nov 26, 12:27 pm, Greg Arnold wrote: DRN wrote: On Nov 26, 11:32 am, Andy wrote: http://www.nadler.com/public/ventus2...ke%20cable.htm Man that's ugly! Why would anyone ruin a great hydraulic disc brake by actuating the master cylinder with a bicycle cable? Andy That is a very good question. Antares uses a direct mechanical connection from spoiler pushrod to master-cylinder actuation lever, no Bowden cable. A Bowden cable is a SPRING, and bicycle-grade is really silly in these applications (especially 8 foot long with a Tost "wheel brake"). I believe SH has upgraded new production to use Beringer parts; hopefully they have stopped doing this on the actuation side... See ya, Dave "YO electric" No, still using the bicycle cable with the Beringer system. See the installation instructions he http://schempp-hirth.com/fileadmin/t...49-33-2444.pdf Aaarggg - It does work adequately with a beefier Bowden cable... I upgraded to a disc brake on my 20-year-old Discus. I have the very same issues there, and haven't had any good ideas about how to upgrade to a beefier Bowden cable (motorcycle cable?) that still will work with the fittings designed for the bicycle cable. Also, I have wondered how a stiffer cable would affect the feel at the stick -- seems it would be stiffer in pitch. |
On Nov 26, 1:28*pm, Bruce wrote:
I upgraded the cable on my 38 year old Std Cirrus. My replacement is the rear brake cable from a Honda motorcycle. Had to cut the fitting off one end and fit a ferrule after threading through the whole system. Reward is a noticeable improvement. i.e. there is some retardation from the ridiculous Tost Lilliput wheel. Generally good for two good stops between adjustments... Greg Arnold wrote: DRN wrote: On Nov 26, 12:27 pm, Greg Arnold wrote: DRN wrote: On Nov 26, 11:32 am, Andy wrote: http://www.nadler.com/public/ventus2...ke%20cable.htm Man that's ugly! Why would anyone ruin a great hydraulic disc brake by actuating the master cylinder with a bicycle cable? Andy That is a very good question. Antares uses a direct mechanical connection from spoiler pushrod to master-cylinder actuation lever, no Bowden cable. A Bowden cable is a SPRING, and bicycle-grade is really silly in these applications (especially 8 foot long with a Tost "wheel brake"). I believe SH has upgraded new production to use Beringer parts; hopefully they have stopped doing this on the actuation side... See ya, Dave "YO electric" No, still using the bicycle cable with the Beringer system. *See the installation instructions he http://schempp-hirth.com/fileadmin/t...49-33-2444.pdf Aaarggg - It does work adequately with a beefier Bowden cable... I upgraded to a disc brake on my 20-year-old Discus. *I have the very same issues there, and haven't had any good ideas about how to upgrade to a beefier Bowden cable (motorcycle cable?) that still will work with the fittings designed for the bicycle cable. *Also, I have wondered how a stiffer cable would affect the feel at the stick -- seems it would be stiffer in pitch.- Hide quoted text - - Show quoted text - Heheh all this talk about overly complex brakes makes me happy to have the flintstone brakes on my Ka-6. Simple piece of sheetmetal that gets pulled over the wheel, and It works. I haven't landed out in it yet, but the combo of full top and bottom surface brakes, plus the wheel brake make it stop in a pretty small area. Pete |
vontresc wrote:
Heheh all this talk about overly complex brakes makes me happy to have the flintstone brakes on my Ka-6. Simple piece of sheetmetal that gets pulled over the wheel, and It works. I haven't landed out in it yet, but the combo of full top and bottom surface brakes, plus the wheel brake make it stop in a pretty small area. Be *really* careful landing on a wet or damp runway. Water is a wonderful lubricant between tire tread and sheet metal. Your "pretty small area" will slide by in a flash! Been there, did that, fortunately stopped short of the fence near the end of the runway. When it was dry, it did an excellent job. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Nov 26, 10:27*am, Greg Arnold wrote:
DRN wrote: On Nov 26, 11:32 am, Andy wrote: http://www.nadler.com/public/ventus2...ke%20cable.htm Man that's ugly! Why would anyone ruin a great hydraulic disc brake by actuating the master cylinder with a bicycle cable? Andy That is a very good question. Antares uses a direct mechanical connection from spoiler pushrod to master-cylinder actuation lever, no Bowden cable. A Bowden cable is a SPRING, and bicycle-grade is really silly in these applications (especially 8 foot long with a Tost "wheel brake"). I believe SH has upgraded new production to use Beringer parts; hopefully they have stopped doing this on the actuation side... See ya, Dave "YO electric" No, still using the bicycle cable with the Beringer system. *See the installation instructions he http://schempp-hirth.com/fileadmin/t...9-33-2444.pdf- Hide quoted text - - Show quoted text - |
No, still using the bicycle cable with the Beringer system. *See the installation instructions he http://schempp-hirth.com/fileadmin/t...9-33-2444.pdf- Hide quoted text - Not only cable but clamp screw type cable nipples. Makes me appreciate even more the direct actuated Cleveland system used by Schleicher. Andy |
brake fittings | [email protected] | Home Built | 6 | April 30th 07 01:33 AM |
K21 brake parts | Stuart Kinnear | Soaring | 10 | June 26th 06 09:54 PM |
looking for a 75 to 100 ton press brake about 8/10 ft | Adrian eyre | Home Built | 1 | January 6th 05 05:28 AM |
BRAKE FLUID | Ventus B | Soaring | 9 | October 17th 04 07:25 PM |
My squishy brake | JFLEISC | Owning | 0 | June 30th 04 01:44 AM |
