Ventus 2cx brake
Old November 26th 08, 11:00 PM posted to rec.aviation.soaring
Andy[_1_]
Default Ventus 2cx brake
On Nov 26, 11:05*am, Bob Kuykendall wrote:
When I was building a brake system for the center stick controls of my
HP-18, I decided I wanted the stick to have as little inertia, and as
little mass aft of the ptich pivot, as practical. Hence my decision to
use a mountain bike brake lever on the stick driving a fixed master
cylinder through a low-friction sheathed cable. That's why this
sailplane developer developed such a system.
Did you consider using a mountain bike hydraulic brake lever? Perhaps
they were not available then. Is the mass of the lever even
significant compared to the mass of the pilot's hand and arm that are
also usually, and certainly during a PIO, attached to the stick?
Andy
Old November 26th 08, 11:39 PM posted to rec.aviation.soaring
Bob Kuykendall
On Nov 26, 3:00*pm, Andy wrote:
Did you consider using a mountain bike hydraulic brake lever? *Perhaps
Yes, I tested a promising one at the time. As little displacement as
my Cleveland caliper requires under typical conditions, it still took
a couple pumps of the lever before it pressured up.
Is the mass of the lever even significant compared to the mass of the
pilot's hand and arm that are also usually, and certainly during a
PIO, *attached to the stick?
Not known. I do know that the available hydraulic master cylinders
with attached reservoir are around a pound or so. I also know that the
human hand and arm has a lot of inherent damping, and also that only
about half the mass of the forearm counts as sprung weight. In this
case at least I decided to develop conservatively and move on.
Thanks, Bob K.
brake fittings [email protected] Home Built 6 April 30th 07 01:33 AM
K21 brake parts Stuart Kinnear Soaring 10 June 26th 06 09:54 PM
looking for a 75 to 100 ton press brake about 8/10 ft Adrian eyre Home Built 1 January 6th 05 05:28 AM
BRAKE FLUID Ventus B Soaring 9 October 17th 04 07:25 PM
My squishy brake JFLEISC Owning 0 June 30th 04 01:44 AM
