On Nov 27, 7:00*pm, Nyal Williams wrote:
Which gliders add flaps when spoilers are activated? IIRC, LS, DG, Lange... |
DRN wrote:
On Nov 27, 7:00 pm, Nyal Williams wrote: Which gliders add flaps when spoilers are activated? IIRC, LS, DG, Lange... Those are just brand names, eh? The LS-8 and the DG-400 don't add flaps! I believe the Nimbus 4 adds flaps with spoiler acutuation. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() Which gliders add flaps when spoilers are activated? IIRC, LS, DG, Lange... Those are just brand names, eh? The LS-8 and the DG-400 don't add flaps! My LS6-b does. Tony V. |
Eric Greenwell wrote:
DRN wrote: On Nov 27, 7:00 pm, Nyal Williams wrote: Which gliders add flaps when spoilers are activated? IIRC, LS, DG, Lange... Those are just brand names, eh? The LS-8 and the DG-400 don't add flaps! I believe the Nimbus 4 adds flaps with spoiler acutuation. DuoDiscus x and later have interlinked airbrake and landing flap. |
On Nov 27, 8:48*pm, DRN wrote:
On Nov 27, 7:00*pm, Nyal Williams wrote: Which gliders add flaps when spoilers are activated? IIRC, LS, DG, Lange... I should have been a bit more precise. Some readers are not confused by models that have no flaps, but... ;-) The issue is when the SPOILER CONTROL moves the FLAP CONTROL. There's no problem with putting the wheel-brake on the spoiler with ships like the Ventus A/B, as the inboard flaps are pushed down by the trailing-edge spoilers with-out moving the flap control. If you select negative flaps for take-off or landing, then pull full spoiler, the flap CONTROL is unaffected and the outer control surfaces remain reflexed up as you pull the spoiler handle. The SPOILER CONTROL moves the FLAP CONTROL back in many FLAPPED gliders, for example recent FLAPPED gliders from LS, Lange, and I believe DG. This creates a bit of an operational issue with wheel-brake on spoilers only. In Antares, it is not necessary to use negative flap for powered takeoff or for landing roll-out as roll control is extremely good at low speeds (and in general). It does create a nuisance if you want to use negative flap for aerotow takeoff, only necessary with a wing- runner. For Antares my preference is no wing runner even for aerotow, which may seem odd but works extremely well. Even with full, water, its no problem. Hope that's a bit more clear ! Best Regards, Dave "YO electric" |
brake fittings | [email protected] | Home Built | 6 | April 30th 07 01:33 AM |
K21 brake parts | Stuart Kinnear | Soaring | 10 | June 26th 06 09:54 PM |
looking for a 75 to 100 ton press brake about 8/10 ft | Adrian eyre | Home Built | 1 | January 6th 05 05:28 AM |
BRAKE FLUID | Ventus B | Soaring | 9 | October 17th 04 07:25 PM |
My squishy brake | JFLEISC | Owning | 0 | June 30th 04 01:44 AM |
