HpH 304S JET Videos now on Youtube!
Old December 9th 08, 12:15 AM posted to rec.aviation.soaring
Default HpH 304S JET Videos now on Youtube!
On Dec 8, 2:30*pm, "Tim Mara" wrote:
keep in mind Jet engines move a LOT of air....a LOT of air and only a very
small amount of the air being moved is actually used in combustion so what
you have is a lot of air....and a small % of (fire) combustion...
tim
Tim already knows this, but just to clarify -- the above description
is true for turbofans, but not for turbojets, the difference being
that a turbofan has (ready for this?) a big fan on the front that
bypasses the compressor, combustor and turbine sections. It is
normally driven by an additional turbine section at the very end of
the engine. The higher the "bypass ratio" the more air goes around the
hot section of the engine. Generally the higher the bypass, the more
static thrust and better specific fuel consumption (lbs of fuel per lb
of thrust per hour) you get, particularly at low speeds and lower
altitudes. Most of these smaller engines are simple turbojets because
you can get away with a single stage compressor and a single turbine.
Lots cheaper to build. I don't have the specs for what Hph is using,
but from Tim's comment perhaps they are already using a turbofan - the
self-launch capable engine certainly is fan with a high(er) bypass.
In any event the simple fact that they have something flying is proof
that you don't need a titanium vertical fin for this to work.
9B
Old December 9th 08, 12:39 AM posted to rec.aviation.soaring
On Dec 8, 4:15*pm, wrote:
On Dec 8, 2:30*pm, "Tim Mara" wrote: keep in mind Jet engines move a LOT of air....a LOT of air and only a very
tim
altitudes. *Most of these smaller engines are simple turbojets because
9B
According to the spec sheet from Turbinenbau Schuberth for the
TBS-400, the engine uses a single compressor and a single-stage
turbine with no fan. The maximum EGT is 720 degrees C. I'm sure things
cool down sufficiently by the time you get to the fin, but I wouldn't
put my hand behind directly behind the engine to see if it's running.
I think in the end jets will replace props for sailplane self-launch,
the greater simplicity and lower weight, plus more favorable
operational considerations count in their favor and the efficiency
tradeoff isn't much of a concern unless you want to go significant
distances.
9B
Old Silentflight videos now on Youtube [email protected] Soaring 0 December 31st 07 11:18 PM
HpH 304S news Tim Mara Soaring 2 July 15th 07 04:43 PM
youtube gliding videos Mal[_3_] Soaring 3 March 17th 07 04:55 AM
Hey Tim! HpH 304S Mike Soaring 5 October 1st 06 03:46 PM
NEW HpH 304S HORNET II Tim Mara Soaring 3 April 29th 04 02:41 AM
