On Dec 8, 4:15*pm, wrote:
On Dec 8, 2:30*pm, "Tim Mara" wrote: keep in mind Jet engines move a LOT of air....a LOT of air and only a very small amount of the air being moved is actually used in combustion so what you have is a lot of air....and a small % of (fire) combustion... tim Tim already knows this, but just to clarify -- the above description is true for turbofans, but not for turbojets, the difference being that a turbofan has (ready for this?) a big fan on the front that bypasses the compressor, combustor and turbine sections. It is normally driven by an additional turbine section at the very end of the engine. The higher the "bypass ratio" the more air goes around the hot section of the engine. Generally the higher the bypass, the more static thrust and better specific fuel consumption (lbs of fuel per lb of thrust per hour) you get, particularly at low speeds and lower altitudes. *Most of these smaller engines are simple turbojets because you can get away with a single stage compressor and a single turbine. Lots cheaper to build. I don't have the specs for what Hph is using, but from Tim's comment perhaps they are already using a turbofan - the self-launch capable engine certainly is fan with a high(er) bypass. In any event the simple fact that they have something flying is proof that you don't need a titanium vertical fin for this to work. 9B According to the spec sheet from Turbinenbau Schuberth for the TBS-400, the engine uses a single compressor and a single-stage turbine with no fan. The maximum EGT is 720 degrees C. I'm sure things cool down sufficiently by the time you get to the fin, but I wouldn't put my hand behind directly behind the engine to see if it's running. I think in the end jets will replace props for sailplane self-launch, the greater simplicity and lower weight, plus more favorable operational considerations count in their favor and the efficiency tradeoff isn't much of a concern unless you want to go significant distances. 9B |
Old Silentflight videos now on Youtube | [email protected] | Soaring | 0 | December 31st 07 11:18 PM |
HpH 304S news | Tim Mara | Soaring | 2 | July 15th 07 04:43 PM |
youtube gliding videos | Mal[_3_] | Soaring | 3 | March 17th 07 04:55 AM |
Hey Tim! HpH 304S | Mike | Soaring | 5 | October 1st 06 03:46 PM |
NEW HpH 304S HORNET II | Tim Mara | Soaring | 3 | April 29th 04 02:41 AM |
