GLIDING INTERNATIONAL - JANUARY 2009 ISSUE
Old December 19th 08, 08:58 PM posted to rec.aviation.soaring
Bob Kuykendall
Default GLIDING INTERNATIONAL - JANUARY 2009 ISSUE
On Dec 19, 6:11*am, JJ Sinclair wrote:
Hey, I'm impressed! When is your next Akafieg?
As you know getting enough goo in the right places
has been a problem ever since we started making
plastic sailplanes...
Akaflieg Douglas Flat (ADF) VIII will probably be sometime between mid-
January and mid-February. I'll post an announcement in this forum when
we know for sure.
Absolutely we are concerned about bondline gap and matching that to
shmoo volume and viscocity. We'll be doing tests such as you suggest,
and I'll also be doing a couple of tuning closures to get the correct
depth of the main spar and drag spar. Our spider tooling is capable of
setting that stuff to pretty close tolerances once we calibrate it as
you suggest.
Thanks again, Bob K.
GLIDING INTERNATIONAL - (The magazine) john Soaring 0 September 7th 08 05:24 AM
Gliding International john Soaring 0 May 4th 08 12:29 AM
Southern California Soaring -- November/December/January issue isonline Editor@SoCalSoaring Soaring 0 November 8th 06 07:14 AM
January Issue of Soaring [email protected] Soaring 2 January 10th 05 06:02 PM
January/February 2004 issue of Southern California Soaring is on-line [email protected] Soaring 8 January 4th 04 09:37 PM
