Why are low-revving, high torque engines preferred?
Old December 23rd 08, 05:59 AM posted to rec.aviation.homebuilt
Highflyer
Default Why are low-revving, high torque engines preferred?
On Fri, 28 Nov 2008 08:30:06 -0500, Dana M. Hague
On Thu, 27 Nov 2008 09:37:54 -0500, "Peter Dohm"
IIRC, snowmobiles are/were derived from chain saws--which required an
engine
light enough for a man to carry and use as a hand held tool. That made
them
an obvious choice for another application were light weight was the most
critical factor--even at the cost of reliability and maintenance
intervals...
I've never heard that, seems unlikely... they are really very
different, except for both (along with outboard motors) being
2-strokes. All for the same reason of light weight.
-Dana
Some of the first ultralights DID run chainsaw motors - just like the
go-cart crowd. Some of the small aircooled outboard engines were also
used - and some early snowmobiles also used a converted aircooled
outboard. (horizontal twin Johnson Snow Cruiser and OMC)
I seem to recall that my first powered ultralight was an Easy Riser
powered by a 10 HP West Bend Chain Saw engine with a belt
reduction made and marketed by our own Chuck Slusarcyk. :-)
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
  #32
Old December 23rd 08, 06:08 AM posted to rec.aviation.homebuilt
Highflyer
I think if you look at the engine cutaways or blueprints, you will see
in the drive train a torsion shaft that functioned as a torsion bar to
keep the gears engaged in the same direction and soak up some of
the inevitable torque variations around the revolution of the crank.
Engines that didn't have that were a bit fussier to run and had some
blanked out RPM ranges where you got extreme gearbox wear.
That was a problem with the ill fated Cessna 175 with its GO-300
engine. It performed a LOT better than the 172 that it shared an
airframe with, but got a reputation for eating gearboxes. The
gearbox also got a reputation for being as expensive as the engine
to overhaul. The main problem was running them in the same RPM
range as the O-300 they were used to from their 170/172. The
GO-300 was good from 2800 to 3200 RPM. Below 2800 it was
best to go all the way to idle. Then the gearbox only transitioned
once from driving to driven. People tried to run them at 2400 RPM,
which just "felt" better to an old 172 pilot. At that RPM the gearbox
would beat back and forth from driving to driven every time a cylinder
fired. A few hundred hours of that would destroy a set of
gears! :-)
Highflyer
"Morgans" wrote in message
"Charlie" wrote
You don't often see that because any torsional resonance problems get
amplified at an even-multiple ratio, like the cam's 2:1 ratio. Note the
final drive ratio of almost any reduction gear train & it will be some
odd number like 2.17:1, 2.85:1, etc.
Perhaps an even larger factor is to get different teeth meshing together
in a cycle, each time around. it is better to not have the same mesh,
time after time, although what you say about harmonics is also a factor.
In the really big "warbird"engines, the gearboxes had to be built so
hell-for-stout to deal with the HP levels, the harmonics were not as much
of an issue because the resonance was hard to achieve with the components
being so stiff.
Jim in NC
Preheating engines: Airplane engines versus auto engines Peter R. Owning 86 January 2nd 08 07:48 PM
Torque wrenches... .Blueskies. Home Built 3 January 11th 06 02:20 PM
Autogas and high end engines John Skorczewski Home Built 10 August 17th 04 05:19 PM
High-Strength Aluminum Helps 2-Stroke Engines sanman Home Built 4 April 29th 04 12:32 AM
High-Strength Aluminum Helps 2-Stroke Engines sanman Rotorcraft 4 April 29th 04 12:32 AM
