On Thu, 25 Dec 2003 19:15:58 GMT, Mike Marron
wrote: Just don't forget to issue me one when I board, then. (I've never fired a handgun, so I'll have a sawed-off shotgun please and thank you! ![]() Not on my airplane, I hope. Nice tidy little bullets are one thing, but a handful of shot is another entirely. Pressurization systems are good, but there is a limit. Or were you planning on loading those little supposedly-nonlethal bean bags? I don't think I like that any better. How about a flammenwerfer if you don't want a handgun? Mary -- Mary Shafer Retired aerospace research engineer |
"Mary Shafer" wrote...
Not on my airplane, I hope. Nice tidy little bullets are one thing, but a handful of shot is another entirely. Pressurization systems are good, but there is a limit. As in most things, "it depends"... If you are thinking about a 10 or 12 gauge shotgun loaded with #4 buck or larger in normal loads, you are probably right (though I haven't done or seen any analysis). With "bird shot" (#7 or 8 lead), though, the trade-off would be the close-range "column of shot" effect vs lesser penetration. Even with a cylinder bore in a 18 1/2" or sawed-off (highly illegal in most cases) barrel, the shot does not disperse significantly until some finite distance from the barrel. Until then, the shot is effectively a .72 cal (for 12 gauge) slug with muzzle energy of 2000-3000 ft-lb. OTOH, a short .410 gauge shotgun will likely have less muzzle energy (650 ft-lb typical for slugs) than a max .45 Colt (410-840 ft-lb -- using comparative figures for a multi-purpose [.45 Colt/.410 shotshell] Thompson/Center Contender handgun) or typical .44 magnum (1100-1600 ft-lb) load, and slightly more than a ..45 auto (350-530 ft-lb). A 16 or 20 gauge shotgun will, obviously, be somewhere in between (1400-2000 ft-lb). I suppose I would worry most about a short-range "clean miss" with a 12-gauge and buckshot -- it would make a BIG hole. Also, I would worry about ANY miss with ANY firearm -- the potential for injuring innocent passengers is high (though more acceptable than crashing the airplane and killing everyone). However, longer-range "misses" with smaller-size shot would be less likely to be lethal or damage-producing, and may be stopped by a seat back or partition. OTOOH, I have seen evaluations of shotshells in .357 and .45 Auto caliber in handgun loads. They are much less effective than any solid bullet load against clothed bodies. |
After an exhausting session with Victoria's Secret Police, "John R
Weiss" blurted out: OTOH, a short .410 gauge shotgun will likely have less muzzle energy (650 ft-lb typical for slugs) than a max .45 Colt (410-840 ft-lb -- using comparative figures for a multi-purpose [.45 Colt/.410 shotshell] Thompson/Center Contender handgun) or typical .44 magnum (1100-1600 ft-lb) load, and slightly more than a .45 auto (350-530 ft-lb). A 16 or 20 gauge shotgun will, obviously, be somewhere in between (1400-2000 ft-lb). What kind of numbers are you looking at with a H&K USP 40 Compact LEM? Just curious...and out of pocket for five days. Juvat |
"B2431" wrote...
Bear in mind most people use muzzle velocity as opposed to impact velocity. Though muzzle velocity/energy is appropriate in this discussion because of the close ranges, hunters definitely consider down-range velocity (and accompanying bullet drop) and energy! Winter clothes tend to clog the cavity of a hollow point and reduce or eliminate expansion. High velocity solid bullets may go through the target and hit something not intended. The latter is why Mag-Safe, Glaser Safety Slugs etc are made. That is one reason I answered the post regarding shotguns. At very close range, the "column of shot" may closely resemble a "Safety Slug" in terminal ballistics, especially with small shot. |
"Juvat" wrote...
What kind of numbers are you looking at with a H&K USP 40 Compact LEM? The .40 S&W has about 400-500 ft-lb muzzle energy. |
"B2431" wrote...
Even with a cylinder bore in a 18 1/2" or sawed-off (highly illegal in most cases) barrel, Under federal law the minimum barrel lengths are 18" for shotguns and 16" for rifles. I know of no state law that furthe restricts length. That's why I tried to differentiate between a 18 1/2" (legal) and a sawed-off (illegal) barrel. The OP mentioned "sawed-off," which would normally be illegal in any case (don't know if they are legal under Class III regs). |
In article Jb0Hb.141848$8y1.422519@attbi_s52,
"John R Weiss" wrote: That's why I tried to differentiate between a 18 1/2" (legal) and a sawed-off (illegal) barrel. The OP mentioned "sawed-off," which would normally be illegal in any case (don't know if they are legal under Class III regs). That's a funny thing... It's generally illegal to cut a normal shotgun down to a short barrel length, but it *is* legal to manufacture a short-barreled shotgun and sell it as an "All Other Weapons" Class III firearm, with a $5 tax stamp. There are some *very* neat little three-shot 12 gauge shotguns with 9" barrels out there (with a folding handle on the slide to help control the little monster). Based on the Mossberg action. I've seen them go for as little as $250 used on some gun auction sites. They don't have as much punch as a regular 12 gauge, but hey, if you have a Class III license, it's practically an impulse buy... and a *serious* short-range low collateral-damage weapon. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
Bush Pilots Fly-In. South Africa. | Bush Air | Home Built | 0 | May 25th 04 06:18 AM |
Joint German-Israeli airforce excersie (Israeli airforce beats German pilots) | Quant | Military Aviation | 8 | September 25th 03 05:41 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Israeli Air Force to lose Middle East Air Superiority Capability to the Saudis in the near future | Jack White | Military Aviation | 71 | September 21st 03 02:58 PM |
