Need base station antenna for RV
Old December 29th 08, 03:24 AM posted to rec.aviation.soaring
Tuno
Default Need base station antenna for RV
Andy,
I decided to go with a bigger ground plane and followed your
suggestion.
There is now a patio on top of my RV g. It's a little top heavy (a
hot tub and 5-burner grill will do that), but wtf, there will be
killer stargazing at Parowan, where applicants outnumber the 18M
nationals 42 to 1, 182 days out.
~tuno (really ... not counting the days)
Old December 29th 08, 05:47 AM posted to rec.aviation.soaring
Alan[_6_]
In article Tuno writes:
Saying it is' a "whip" does not tell us much.
It's a 64 inch whip on a Radiall/Larson magnetic base that contains
the frequency matching coil, from Tim@W&W.
What frequency are you planning on operating on?
If it is around 123 MHz, and a 1/4 wave, it should be about 23 inches
long. For a 5/8 wave, I calculate 59 inches in length.
If I understand you, the ground plane *radius* has to be at least 64
inches. That's one big piece of sheet metal! I'll have to make due
with 12, unless that's going to bother my radio when I xmit.
The ground plane radius should be about 1/4 wavelength plus about 5%
(these figures from radials such as wire). The wavelength at 123 MHz is
about 96 inches, so 1/4 wavelength would be 24 inches. Add 5 % and you
would build with radials of 25.2 inches. Planting the magmount somewhere
near the middle of the roof should do just fine.
Note: this is for a 1/4 wave antenna. For a 5/8 wave antenna, the
ground current should be lower due to the higher base impedance, so the
ground plane will have less impact. I suspect that the 64 inch whip was
added to a 5/8 wave base transformer, and may be just a bit long for the
aircraft band.
On top of a motor home, a 64 inch whip will hit a lot of things as you
drive.
Alan
wa6azp
FS Dittle radio base station Bob Epp Soaring 0 October 9th 08 11:06 PM
Mobile base station radio Bernie[_3_] Soaring 4 June 7th 07 03:14 PM
Using an old RT385A as a base station. Avery Wagg Home Built 2 June 22nd 06 01:08 AM
FA: VHF 760 COM Base Station: 3 hours left! EOC Aviation Marketplace 0 August 22nd 05 09:08 PM
FA: VHF Unicom Base Station Radio 25W 760ch VC Aviation Marketplace 0 July 9th 03 04:01 PM
