Plane Accidentally Starts Moving With 6-Year-Old Inside
Old December 31st 08, 10:01 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Robert M. Gary
Default Plane Accidentally Starts Moving With 6-Year-Old Inside
On Dec 31, 1:34*pm, B A R R Y wrote:
Robert M. Gary wrote:
One
thing that "electric" pilots do not realize is that its very, very
hard to guess how much power the engine will develop when it first
starts. Sometimes it will just be idling, other times it will start
with a big roar.
I seem to remember a rule about a licensed pilot at the controls when
hand propping.
Am I dreaming?
In the US you are. That is a Canadian rule. I can't ever remember
having a licensed pilot when I was hand proping. In truth its only
scarry to those that haven't done it. In fact you have to stop
yourself every once-in-a-while because it becomes so common its easy
to let your guard down. If I had to have another pilot around that
would have killed 90% of my flights.
-Robert
Old December 31st 08, 10:03 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
BT
On Dec 29, 9:48 pm, "BT" wrote:
It may have been an "accident" when the unpiloted aircraft hit the trees.
But it the airplane did not accidentally start moving.. that would be
negligence on the grandfathers part
Wouldn't that still be an accident? Are you suggesting that if the
plane was not tied down it was a "on purpose"?
If one does not follow known procedure and safety guidelines and causes
injury.
Is it an accident that you did not do as instructed?
Or is it negligence.
Old December 31st 08, 10:04 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Mike Gaskins[_2_]
hand propping.
Am I dreaming?
I know some airports require it. I can't find anything FAR's
regarding it in a quick web search.
The FAA's Airplane Handbook however (which is not a set of rules but
rather a textbook) suggests a person "familiar with the controls" to
be inside the plane.
The few guys I know at the airport who have planes that need to be
hand propped generally just find anyone nearby. Several times I've
seen one guy who owns a pretty nice J-3 let one of the younger
teenagers that hangs around the airport sit inside while he propped
the plane, and as a "present" he let the kid taxi it over to the fuel
pumps.
Of course he's not much for regulations even if that was illegal. I've
seen the same guy take that little plane off from the parking ramp
rather than taxi out to the runway O.O.
Mike Gaskins
Old December 31st 08, 10:21 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
B A R R Y[_2_]
One
with a big roar.
hand propping.
Am I dreaming?
In the US you are.
Maybe I'm thinking of an airport rule...
Old December 31st 08, 11:05 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
vaughn
"BT" wrote in message
The two are not mutually exclusive, so your answer is "both". We are all
capable of doing dumb things. (though some of us may be more capable than
others)
Vaughn
Old December 31st 08, 11:19 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Anyolmouse
trees.
In anycase, its not always practical to tie down the tail (especially
in areas without tiedown). I had 3 ways to secure the Aeronca and J-3.
Brakes, chock, tail tiedown. I would always use 2 of those 3. Many,
many times I started the plane when no tie down was available but then
I would use a chock and the aircraft brake (which was marginal). One
with a big roar. Once you've started the plane you can walk around,
put it in a low idle, and then unsecure the airplane.
-Robert
Back in the mid 70's I witnessed brake failure on a Luscombe during
rollout of a landing. The airplane ground looped and went into a fence.
The FAA inspector classified it as an incident. He said that incidents
did not result in injuries requiring hospital treatment. Accidents did
require hospital treatment. I don't know if that was his own policy or
the FAA's at the time.
Anyolmouse
Old December 31st 08, 11:21 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Peter Dohm
"B A R R Y" wrote in message
One
with a big roar.
hand propping.
Am I dreaming?
In the US you are.
Yes, you are--and occasionally a municipal rule. I won't even try to hazard
a guess as to whether either of those are enforceable, or under what
circumstances.
Peter
Old December 31st 08, 11:32 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
vaughn
"Anyolmouse" wrote in message
See FARs Part 830.2 (definitions)
Vaughn
Old December 31st 08, 11:33 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Anyolmouse
| trees.
be
| -Robert
fence.
| Anyolmouse
Here is the definition taken from:
http://www.nolan-law.com/practice-ar...ghts/#Incident
An aviation accident is the most serious and may be defined as such if
at least one person is killed or hospitalized for longer than 24 hours
and/or the aircraft is destroyed or substantially damaged. Thus, it is
possible to have an aviation accident in which no people are seriously
injured but the aircraft is lost as was the case early in 2008 with the
loss of a British Airways B777 at Heathrow Airport. Also meeting the
test of an aviation accident was the 1997 loss of a TWA B747 flying out
of New York when a fuel tank exploded and all 230 persons aboard were
killed and the aircraft was destroyed.
I guess negligence could come into play either for accidents or
incidents.
Anyolmouse
Old December 31st 08, 11:38 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Anyolmouse
"vaughn" wrote in message
fence.
incidents
did
or
| Vaughn
I did so. Thanks-
Anyolmouse
Two 14 year old boys steal plane and then crash John Doe Piloting 102 March 11th 06 05:03 AM
16 year old steals a plane Jeff Piloting 25 February 8th 06 11:14 PM
I want to buy a plane by year-end but they're not making it easy. T.Roger Owning 134 December 15th 04 11:02 PM
I want to buy a plane by year-end but they're not making it easy. T.Roger Piloting 132 December 15th 04 10:09 PM
Looking for helicopter flight training (and advice) - Sacramento now, and moving to Phoenix next year JonTheRookie Rotorcraft 5 June 7th 04 04:16 AM
