Plane Accidentally Starts Moving With 6-Year-Old Inside
Old January 1st 09, 12:10 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default Plane Accidentally Starts Moving With 6-Year-Old Inside
On Dec 31, 3:01*pm, "Robert M. Gary" wrote:
Am I dreaming?
In the US you are. That is a Canadian rule. I can't ever remember
having a licensed pilot when I was hand proping. In truth its only
scarry to those that haven't done it. In fact you have to stop
yourself every once-in-a-while because it becomes so common its easy
to let your guard down. If I had to have another pilot around that
would have killed 90% of my flights.
Canadian rule does not require a competent person at the controls
if the airplane is prevented from moving. Here's the reg:
Starting and Ground Running of Aircraft Engines
602.10 (1) No person shall start an engine of an aircraft unless
(a) a pilot's seat is occupied by a person who is competent to control
the aircraft;
(b) precautions have been taken to prevent the aircraft from moving;
or
(c) in the case of a seaplane, the aircraft is in a location from
which any movement of the aircraft will not endanger persons or
property.
In my case, I have a really strong parking brake. And if I have
to use more than fully-closed throttle, I tie the tail down.
Dan
Plane Accidentally Starts Moving With 6-Year-Old Inside Monk Piloting 24 January 2nd 09 01:09 AM
16 year old steals a plane Jeff Piloting 25 February 8th 06 11:14 PM
I want to buy a plane by year-end but they're not making it easy. T.Roger Owning 134 December 15th 04 11:02 PM
I want to buy a plane by year-end but they're not making it easy. T.Roger Piloting 132 December 15th 04 10:09 PM
Looking for helicopter flight training (and advice) - Sacramento now, and moving to Phoenix next year JonTheRookie Rotorcraft 5 June 7th 04 04:16 AM
