Actually, your premise about babying an engine may not be true. Is there
data that supports this "gentle" use of an engine adds to longevity? My own plane, as well as others with the same type (an Extra 300) are essentially operated in an on/off mode. It generally is full power (2700RPM and full throttle) on TO, cruise to the practice area, and then on/off, with no regard to shock cooling or heating- full power straight up, power off to spin, then full power on the recovery. Gyroscopic maneuvers (with a composite prop)- no problem with cranks. Yet, with 400 hours of this operation on my plane (and many/many others according to the reps), none have required an overhaul, with some up to 1,000h of similar operation. Likewise, Lycoming and Continental always gave some hand waving response to questions about running LOP, yet, Cirrus, with now many thousands of hours of LOP operations now mandate operating in this realm. So, a lot of what is considered "safe and prudent" operating may be more of an old wive's tale, and not supported by actual data. |
On Jan 3, 9:21*am, "Viperdoc" wrote:
Actually, your premise about babying an engine may not be true. Is there data that supports this "gentle" use of an engine adds to longevity? My own plane, as well as others with the same type (an Extra 300) are essentially operated in an on/off mode. It generally is full power (2700RPM and full throttle) on TO, cruise to the practice area, and then on/off, with no regard to shock cooling or heating- full power straight up, power off to spin, then full power on the recovery. Gyroscopic maneuvers (with a composite prop)- no problem with cranks. Yet, with 400 hours of this operation on my plane (and many/many others according to the reps), none have required an overhaul, with some up to 1,000h of similar operation. Likewise, Lycoming and Continental always gave some hand waving response to questions about running LOP, yet, Cirrus, with now many thousands of hours of *LOP operations now mandate operating *in this realm. So, a lot of what is considered "safe and prudent" operating may be more of an old wive's tale, and not supported by actual data. You could be right. Never the less, our TBO is determined by tach hours, and we are happy to run at 1950 at altitude instead of 2600. It could be a old wives tale, but rapid temp change does different things to metals than does more gradual changes as well. We'll continue to fly with a gentle hand -- it pleases us to do so, even if there's a possibility it doesn't prolong engine life or reliability. I am pretty persuaded it does, but can offer no evidence. It would be interesting to have a mechanic examine enough engines flown with different flight algrithyms to see if he could detect a difference or estimate service life -- a single blind protocol, if you will. |
![]() On 3-Jan-2009, "Viperdoc" wrote: Likewise, Lycoming and Continental always gave some hand waving response to questions about running LOP, yet, Cirrus, with now many thousands of hours of LOP operations now mandate operating in this realm. So, a lot of what is considered "safe and prudent" operating may be more of an old wive's tale, and not supported by actual data. You might want to read through this article: http://www.lycoming.textron.com/supp...es/SSP700A.pdf Scott Wilson |
There is a lot of "may", or "can" in their article, but no data. On the
other hand, Cirrus as well as the folks at TAT actually present data, something that Lycoming and Continental have yet to produce. I suspect that both companies are not interested in doing any testing or changing their many year old operating instructions in order to limit their liability exposure. |
![]() On 3-Jan-2009, "Viperdoc" wrote: I suspect that both companies are not interested in doing any testing or changing their many year old operating instructions in order to limit their liability exposure. You may be exactly right. Somewhat irrelevant for me, since my 1978 Cessna 172N doesn't have an EGT gauge or cylinder head temp gauges. My POH says to lean until the tach drops 25 to 50 RPM, which I've read is supposedly somewhere slightly lean of peak. My partners say they lean until the tach drops off, then twist the mixture knob back rich a couple of turns. I do the 25 RPM drop-off method, but I've always been worried I might be causing damage to the engine, based on what I've read in some of the on-line articles people on this group recommended. Or maybe my partners are damaging the engine by doing it their way, if not just wasting some gas. I wish there was a way to be absolutely sure. Scott Wilson |
.. . On 3-Jan-2009, "Viperdoc" wrote: I suspect that both companies are not interested in doing any testing or changing their many year old operating instructions in order to limit their liability exposure. You may be exactly right. Somewhat irrelevant for me, since my 1978 Cessna 172N doesn't have an EGT gauge or cylinder head temp gauges. My POH says to lean until the tach drops 25 to 50 RPM, which I've read is supposedly somewhere slightly lean of peak. My partners say they lean until the tach drops off, then twist the mixture knob back rich a couple of turns. I do the 25 RPM drop-off method, but I've always been worried I might be causing damage to the engine, based on what I've read in some of the on-line articles people on this group recommended. Or maybe my partners are damaging the engine by doing it their way, if not just wasting some gas. I wish there was a way to be absolutely sure. Scott Wilson I don't know about the 172N, but the manual for the 152 had a very similar recommendation for lean operation--but it was stated for 60% power (and was obviously appropriate for less than 60% as well). What does your POH say about the power setting? Peter |
On Jan 3, 10:10 am, wrote:
You may be exactly right. Somewhat irrelevant for me, since my 1978 Cessna 172N doesn't have an EGT gauge or cylinder head temp gauges. My POH says to lean until the tach drops 25 to 50 RPM, which I've read is supposedly somewhere slightly lean of peak. My partners say they lean until the tach drops off, then twist the mixture knob back rich a couple of turns. I do the 25 RPM drop-off method, but I've always been worried I might be causing damage to the engine, based on what I've read in some of the on-line articles people on this group recommended. Or maybe my partners are damaging the engine by doing it their way, if not just wasting some gas. I wish there was a way to be absolutely sure. Lycoming says you can lean your normally-aspirated engine anyway you like if you're at or below 75% power without damaging it. See your cruise charts. Detonation is seldom any risk at 75% or less. Dan |
Full Stalls Power Off | w3n-a | Soaring | 5 | December 4th 08 10:29 PM |
Full Stalls Power On | w3n-a | Piloting | 0 | December 4th 08 02:30 PM |
Can hydraulic lifters cause inadequate full power? | [email protected] | Owning | 13 | October 23rd 08 07:40 PM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
4--O-470 pistons,used | jerry Wass | Aviation Marketplace | 0 | August 17th 04 05:07 PM |
